Jose, got it working. It started working after lunch. ????
Thanks for your help.
Case closed.
Sent: Friday, April 24, 2015 11:37 AM
To: 'vantage@yahoogroups.com'
Subject: RE: [Vantage] R-Click a field and get the OPEN WITH --> capability on UD's
Thanks for your prompt response.
I am trying this but can’t get it to work.
Here is what I am doing:
1. Selecting UD10.Character02
2. Entering JobHead in the Like Area
3. Entering JobNum in the Like Field
4. Save
5. Log out of E9 and back in
6. Go to the Form to test and nothing in the R-Click.
I see the Additional Information in the Extended Properties, but nothing is populated.
Any idea’s. I am sure I am missing a step. Do you have any documentation on this?
vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]
Sent: Friday, April 24, 2015 10:47 AM
To: Vantage
Subject: Re: [Vantage] R-Click a field and get the OPEN WITH --> capability on UD's
Use Extended Properties Maintenance to do the same thing. In 9x, 10x the CustomLike stuff works much better from there.
Jose C Gomez
Software Engineer
T:
904.469.1524 mobile
On Fri, Apr 24, 2015 at 11:44 AM, William King wking@... [vantage] <vantage@yahoogroups.com> wrote:
I was able to create the functionality of R-Click a text field of a UD field on 8.03.409C by
1. Set Form on customization.
2. R-Click and customize
3. Tools à Data Tools
4. Custom Column Like
a. Select UD View and column (i.e. UD08.ShortChar01)
b. Like column Value (i.e. JobHead.JobNum)
c. Apply Like Property
5. OK
6. Select the appropriate textbox with the UD field (i.e. UD field, I created to have jobnum showing)
7. Change EpiContextMenuKey to same as Like column value entered earlier (step 4.b)
8. Save
9. Close form and Open and R-Click jobnum (viola it works)
I do this on E9.05.702A. The is populated EpiContextMenuKey field is correct, but the Data Tools change is not saved.
Has anyone ran into this problem and found a solution?
William R. King
IT Analyst
Topura America Fastener, Inc.
1070 Monterey Court - Bowling Green, KY 42101
Voice: 270-901-1579
