GL Account Segment Order
Our Finance team have notice on the Chart of Account listing in Kinetic that the GL Accounts are displayed as Chart-Department-Division whereas in E9 they are displayed as Division-Chart- Department. Is there a config setting somewhere to re-order these as the report is OOB.
E9
Kinetic
Thanks.
Check your COA setup under GL/Setups/COA. You can determine the display order of your segments by using up and down arrows. Also check to make sure the segments are set to print on summary and detail checkboxes
I have re-ordered them but the COA Listing is still coming out as it was previously setup.
Interestingly in GL Account Maintenance it has re-ordered the correctly.
Did you run this?
You need to run the rebuild display GL Accounts from GL/General Operations
Thanks guys, all sorted.
