GLPeriodBal BAQ
Hello everyone, i have been dealing with a BAQ but haven´t been able to figure it out how to solve it.
What I need to do is to gather the open balance, debit, credit and balance amount for each GLAccount, based on the “MAYOR” account segment.
as for now, I´ve been capable of gathering the information for each one of the fiscal periods, but the thing is that I need to have the “FiscalPeriod = 0” balance amount as the “openAmount” for “FiscalPeriod = 1” and so on.
attached is a copy of what I have been working with.
with [CUENTAS] as
(select
	[GLPeriodBal].[Company] as [GLPeriodBal_Company],
	[GLPeriodBal].[BookID] as [GLPeriodBal_BookID],
	[GLPeriodBal].[FiscalYear] as [GLPeriodBal_FiscalYear],
	[GLPeriodBal].[FiscalPeriod] as [GLPeriodBal_FiscalPeriod],
	[GLPeriodBal].[SegValue1] as [GLPeriodBal_SegValue1],
	[GLPeriodBal].[BalanceAcct] as [GLPeriodBal_BalanceAcct],
	[COASegValues].[SegmentDesc] as [COASegValues_SegmentDesc]
from Erp.GLPeriodBal as GLPeriodBal
inner join Erp.GLAccount as GLAccount on
	GLPeriodBal.Company = GLAccount.Company
	and GLPeriodBal.SegValue1 = GLAccount.SegValue1
inner join Erp.COASegValues as COASegValues on
	GLAccount.SegValue1 = COASegValues.SegmentCode
where (GLPeriodBal.BookID = 'MXN'  and GLPeriodBal.FiscalYear = 2015)
group by [GLPeriodBal].[Company],
	[GLPeriodBal].[BookID],
	[GLPeriodBal].[FiscalYear],
	[GLPeriodBal].[FiscalPeriod],
	[GLPeriodBal].[SegValue1],
	[GLPeriodBal].[BalanceAcct],
	[COASegValues].[SegmentDesc])
select
	[CUENTAS].[GLPeriodBal_Company] as [GLPeriodBal_Company],
	[CUENTAS].[GLPeriodBal_FiscalYear] as [GLPeriodBal_FiscalYear],
	[CUENTAS].[GLPeriodBal_FiscalPeriod] as [GLPeriodBal_FiscalPeriod],
	[CUENTAS].[GLPeriodBal_SegValue1] as [GLPeriodBal_SegValue1],
	[CUENTAS].[GLPeriodBal_BalanceAcct] as [GLPeriodBal_BalanceAcct],
	[CUENTAS].[COASegValues_SegmentDesc] as [COASegValues_SegmentDesc],
	(((select
	(sum( SALDO_INICIAL.OpenBalance )) as [Calculated_SALDO_INICIAL]
from Erp.GLPeriodBal as SALDO_INICIAL
where SALDO_INICIAL.BookID = CUENTAS.GLPeriodBal_BookID  and SALDO_INICIAL.FiscalYear = CUENTAS.GLPeriodBal_FiscalYear  and SALDO_INICIAL.SegValue1 = CUENTAS.GLPeriodBal_SegValue1  and SALDO_INICIAL.FiscalPeriod = CUENTAS.GLPeriodBal_FiscalPeriod))) as [Calculated_OPEN_BALANCE],
	(((select
	(sum( DEBIT.DebitAmt )) as [Calculated_DEBIT]
from Erp.GLPeriodBal as DEBIT
where DEBIT.BookID = CUENTAS.GLPeriodBal_BookID  and DEBIT.FiscalYear = CUENTAS.GLPeriodBal_FiscalYear  and DEBIT.FiscalPeriod = CUENTAS.GLPeriodBal_FiscalPeriod  and DEBIT.SegValue1 = CUENTAS.GLPeriodBal_SegValue1))) as [Calculated_DEBIT],
	(((select
	(sum( CREDIT.CreditAmt )) as [Calculated_CREDIT]
from Erp.GLPeriodBal as CREDIT
where CREDIT.BookID = CUENTAS.GLPeriodBal_BookID  and CREDIT.FiscalYear = CUENTAS.GLPeriodBal_FiscalYear  and CREDIT.FiscalPeriod = CUENTAS.GLPeriodBal_FiscalPeriod  and CREDIT.SegValue1 = CUENTAS.GLPeriodBal_SegValue1))) as [Calculated_CREDIT],
	(((select
	(sum( SALDO_FINAL.BalanceAmt )) as [Calculated_SALDO_FINAL]
from Erp.GLPeriodBal as SALDO_FINAL
where SALDO_FINAL.BookID = CUENTAS.GLPeriodBal_BookID  and SALDO_FINAL.FiscalYear = CUENTAS.GLPeriodBal_FiscalYear  and SALDO_FINAL.FiscalPeriod = CUENTAS.GLPeriodBal_FiscalPeriod  and SALDO_FINAL.SegValue1 = CUENTAS.GLPeriodBal_SegValue1))) as [Calculated_BALANCE_AMNT]
from  CUENTAS  as CUENTAS
where (CUENTAS.GLPeriodBal_BookID = 'MXN'  and CUENTAS.GLPeriodBal_SegValue1 = '1120121')
and this is what I´m getting as result, which is partially correct:
Company Fical Year Fiscal Period Segment Value 1 Balance Account Description OPEN_BALANCE DEBIT CREDIT BALANCE_AMNT
GSW01 2015 0 1120121 1120121-00-010-000-00 102.01 611759.65 0 0 611759.65
GSW01 2015 1 1120121 1120121-00-010-000-00 102.01 0 458452.88 -326901.27 131551.61
GSW01 2015 2 1120121 1120121-00-010-000-00 102.01 0 442306.84 -438123.36 4183.48
GSW01 2015 3 1120121 1120121-00-010-000-00 102.01 0 468788.48 -436076.72 32711.76
GSW01 2015 4 1120121 1120121-00-010-000-00 102.01 0 452980 -421332.6 31647.4
GSW01 2015 5 1120121 1120121-00-010-000-00 102.01 0 30458128.15 -30532793.94 -74665.79
GSW01 2015 6 1120121 1120121-00-010-000-00 102.01 0 642108.81 -941242.93 -299134.12
GSW01 2015 7 1120121 1120121-00-010-000-00 102.01 0 640716.12 -571548.64 69167.48
GSW01 2015 8 1120121 1120121-00-010-000-00 102.01 0 647579.4 -579311.94 68267.46
GSW01 2015 9 1120121 1120121-00-010-000-00 102.01 0 644084.2 -1180863.41 -536779.21
GSW01 2015 10 1120121 1120121-00-010-000-00 102.01 0 844606.93 -577874.27 266732.66
GSW01 2015 11 1120121 1120121-00-010-000-00 102.01 0 645648.64 -588256.49 57392.15
GSW01 2015 12 1120121 1120121-00-010-000-00 102.01 0 645136.31 -584743.86 60392.45
As I tried to explain earlier, I need the BALANCE_AMNT from FiscalPeriod 0 to be the OPEN_BALANCE in FiscalPeriod 1, then, FiscalPeriod1 BALANCE_AMNT needs to be the OPEN_BALANCE + DEBIT + CREDIT and then use it as OPEN_BALANCE in the next FiscalPeriod… and so on…
I will be so thankful if someone has an idea on what I´m missing or what I´m doing wrong.
in the attached BAQ file, I´m filtering for a specific year and for a specific GL account, but suddenly those filters should be removed so a Dashboard can be generated based on the BAQ. BALANZA_CONTA_ELEC2.baq (100.4 KB)
I only needed to back off a few days to figure it out, it was only necessary to modify my Subquery criterias to get the proper result in the SUM() function.
here is the final result of my Query with no filters…
if someone find a better way to do this and/or have any suggestions to get this improved please do not hesitate in reply to this post.
with [CUENTAS] as
(select
where (GLPeriodBal.BookID = 'MXN')
select
	(((select
where SALDO_FINAL.BookID = CUENTAS.GLPeriodBal_BookID  and SALDO_FINAL.FiscalYear = CUENTAS.GLPeriodBal_FiscalYear  and SALDO_FINAL.FiscalPeriod <= CUENTAS.GLPeriodBal_FiscalPeriod  and SALDO_FINAL.SegValue1 = CUENTAS.GLPeriodBal_SegValue1))-((select
where DEBIT.BookID = CUENTAS.GLPeriodBal_BookID  and DEBIT.FiscalYear = CUENTAS.GLPeriodBal_FiscalYear  and DEBIT.FiscalPeriod = CUENTAS.GLPeriodBal_FiscalPeriod  and DEBIT.SegValue1 = CUENTAS.GLPeriodBal_SegValue1))-((select
where CREDIT.BookID = CUENTAS.GLPeriodBal_BookID  and CREDIT.FiscalYear = CUENTAS.GLPeriodBal_FiscalYear  and CREDIT.FiscalPeriod = CUENTAS.GLPeriodBal_FiscalPeriod  and CREDIT.SegValue1 = CUENTAS.GLPeriodBal_SegValue1))) as [Calculated_OPEN_BALANCE],
	(((select
	(((select
	(((select
where SALDO_FINAL.BookID = CUENTAS.GLPeriodBal_BookID  and SALDO_FINAL.FiscalYear = CUENTAS.GLPeriodBal_FiscalYear  and SALDO_FINAL.FiscalPeriod <= CUENTAS.GLPeriodBal_FiscalPeriod  and SALDO_FINAL.SegValue1 = CUENTAS.GLPeriodBal_SegValue1))) as [Calculated_BALANCE_AMNT]
here is the final baq file. BALANZA_CONTA_ELEC.baq (100.1 KB)
