Help in adding Subreport to Epicor Report 905.702
Have you tried using Linked Tables in RDD.
If I look at InvcDtl in the RDD – there is a linked table PackNum.
There you can arrow over the fields you need.
I used this to add the main tracking number to the AR invoice.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of mnumbers@...
Sent: Tuesday, May 06, 2014 1:32 PM
Subject: [Vantage] Help in adding Subreport to Epicor Report 905.702
I am trying to add a subreport to Epicor's ARFORM.  I am trying to add information from Shiphead.  I have duplicated RDD ARFORM and added Shiphead, added a relationship to Invcdtl with company and packnum.  I duplicated the crystal ARFORM, created a new style and ran the report.  I opened Crystal with my new report and INSERT subreport and created a new report using the wizard.  I selected shiphead and the fields I wanted to use, placed the subreport group header 2 (invcdtl legal number).  Then went to edit subreport links and selected from report fields Invcdtl.packnum.  In the lower right hand box I selected Shiphead.packnum.  Saved my report and ran it.  In the subreport area the only thing I am getting is the heading.  What am I doing wrong?  I had this working in 904.507a.
I originally tried to just link ShipHead to the base report to pull in the fields without a subreport.  After I changed the RDD and ran the report and then reopened Crystal I could add Shiphead but when I tried to LINK Invcdtl to ShipHead and OK Crystal would blow up and close down.
Any help would be appreciated.
Mike
Mike
I was trying to make the same modification last week, only I was adding the tracking number field. I had tried both of the scenarios Mike had tried and yielded the same results. I would be interested if there is a solution also.
-Phil
Phil Collier | Application Software Specialist
[cid:image001.jpg@01CF6942.81913950]
Dynomax Inc. | Design • Manufacturing • Performance
1535 Abbott Drive, Wheeling, IL 60090| www.dynomaxinc.com<http://www.dynomaxinc.com/>
Main: 847.680.8833 | Direct: 224.207.7657 | Fax: : 847.680.8838
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Scott A. Litzau
Sent: Tuesday, May 06, 2014 3:46 PM
Subject: RE: [Vantage] Help in adding Subreport to Epicor Report 905.702
Check the report XML output file. Make sure the data you are expecting is in there. If it is not then it is in your RDD not pulling the info. If it is then I would suspect either the Sub report links are not correct or you have the sub-report in a section that does not logically link to that data.
From: vantage@yahoogroups.com<mailto:vantage@yahoogroups.com> [mailto:vantage@yahoogroups.com] On Behalf Of mnumbers@...<mailto:mnumbers@...>
Sent: Tuesday, May 06, 2014 3:32 PM
To: vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>
I originally tried to just link ShipHead to the base report to pull in the fields without a subreport.&nb sp; After I changed the RDD and ran the report and then reopened Crystal I could add Shiphead but when I tried to LINK Invcdtl to ShipHead and OK Crystal would blow up and close down.
Mike
This electronic message transmission is intended only for the use of the person to whom it is addressed, including any attachments, and contains information from Dynomax Inc, which may be privileged, competition sensitive, confidential, or protected by law. If you are not the intended recipient, you are hereby notified that any dissemination, copying or distribution of this email or its contents is strictly prohibited. If you have received this message in error, please notify us immediately by replying to the message and deleting it from your computer.
ITAR Notice: This email may contain technical data which may be controlled by the US International Traffic in Arms Regulation (ITAR) 22 CFT part 120-130. If this data is determined to be ITAR controlled, such data may not be transmitted, shared or provided to any foreign party or entity either verbally or visually without proper licenses from the State Department. It is your responsibility to assure this item can by legally shared with another party. Thank you for your compliance.
