I need to add a calculated field for extended price in the “Lines” grid on the Quote Order Wizard. Can’t seem to find a way to access that form since it is modal, I can’t click on “Customization” when it is displayed. Suggestions? Thanks!
Did you try to right-click the screen (not on an object)?
I would never have thought about that! Is that documented anywhere? Thank you!
Random luck instead of documentation.
