I know you have to be in developer mode to open this and then right click or go to tools to go to customization. I do that, but I was playing around with how to display a minimum quantity when the form is opened and a PO is suggested that is not bound to any of the views already in the form. I added a form event wizard (the before tool click one). Now I can’t back to the customization or do anything because when I click a tool, I get a message saying there is no row at position zero and it errors out and doesn’t open up the customization screen or any tool I click on. Is there any way to get around this, so I can get back to the customization screen and delete this form event wizard?
You could try pulling the customization into the Visual studio extension that Jose made. That will open the code, and you can delete the problem stuff before it opens up the screen.
Usé the customizaion maintenance form. In there you can retreive your custo and edit the code in script.
Pierre.
The built in tool is Customization Maintenance. Open your customization and click Actions>Show Custom Data
