I am trying to determine which adapter to use to access a specific table (OpDtl) in a customization. In a BPM I could query it straight from the DB.
How do I figure which adapters to use for specific tables?
Is it possible that adapters don’t exist for every table? If so, what is the workaround?
Is there a document besides ERP Object Reference with similar info. I have found most of the documentation doesn’t match the object.
And since I’m asking so many questions already I’ll add:
Is there a way to call a standard SQL query (like a BAQ) without actually having a physical BAQ?
There is a JobOperSearchAdapter you can use to query some JobOper Details… but your best bet is going to be a BAQ. IT will be faster and contain only the data you want.
I think you are most likely right (per usual) that a BAQ will stop my hair pulling fit I am having.
I did try the trace but it just give me that dang WorkQueue adapter which forces me to do things I don’t like (and can’t do)
Re: JobOperSearchAdapter - It was almost there. It didn’t give me the ResourceID of the op though Boooo!
I did even try to dig into the assemblies to maybe try some of your magical reflection. I wont say I couldn’t do it, but I am limiting myself to 45 minutes of playing since you have offered a better alternative.
Thanks for your input and meme - both are appreciated
Merry Christmas and Happy Holidays to all the E10help.com staff and users!
Jose nailed the normal approach for discovery. Trace the form that contains the data of interest. If not present, fall back to a BAQ. Looking at future approaches but that is best for now
