We typically have a lot of similar parts that have unique BOMs, but the operations are close to identical. We are currently manually entering all of the operations, std hrs, etc via engineering work bench. This can be time consuming as 99% of the information is the same on the parts. Is there a way to “copy” the operations from one part to another, so we can get 99% of the work done and then change the last 1%.
Personally I would use DMT to add the operations.
And if you don’t have DMT, you could try making an updatable dashboard that you could populate by pasting data in.
It would probably be cheaper to buy DMT, than to wrestle with the one uBAQ and uDashboard.
