Is here a way to tell what parameters / filters have been used to run reports that are attached to the task agent schedules? I deleted some schedules by mistake and need to create them. The pilot environment has the reports in the schedule but it only lists them. It doesn’t indicate what criteria were used to run them (e.g. email / filters etc.) Is there a database table that holds this info?
I know for our MRP, if you double click on the row in the Scheduled Tasks tab you can see the dialog that was submitted for run. I assume the same happens for scheduled reports.
