Hi Calvin,
You should be able to do the Job Receipt to Inventory, and put a
negative quantity (at least you can in 6.1)
Liz
Of Calvin Krusen
Sent: Friday, November 14, 2008 09:47 AM
Subject: [Vantage] Re: How to "un-report" job quantity
I looked at doing that, but that looked like that would effect the
components of the job, not the finished stocked assembly.
The Production Detail report shows the proper issue qty's of the
components. It's just that the Received to Stock qty is wrong.
This makes the QOH incorrect. By the way, the Part Trans Hist shows
two MFG-STK transactions. The first created by the Auto Receive
function when the labor was reported, and the second from my manual
Job Receipt to Inventory. The unit cos on the first trans is
correct, while the unit cost for the second trans is zero.
I'm guessing a Misc Issue will be required, followed by a Journal
Entry to clean up the mfg variances and inventory adjustments.
Calvin Krusen
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , Mark
Liz
Of Calvin Krusen
Calvin Krusen
>accidentitly
> Use can use the return material program under Inventory Management
> --- On Fri, 11/14/08, Calvin Krusen <ckrusen@...> wrote:
> From: Calvin Krusen <ckrusen@...>
> Subject: [Vantage] How to "un-report" job quantity
> Date: Friday, November 14, 2008, 11:59 AM
> A job was setup for 'Auto Receive' when completed, but I
> performed a 'Job Receipt to Inventory' too.[Non-text portions of this message have been removed]
> How do I reverse the 'Job Receipt to Inventory' step?
> Thanks,
> Calvin
