Doug,
If it's an error 599, you need to make sure the computer running the
report has the ODBC set up exactly the same as yours, and you will need
to remove the comments from the last 3 or 4 lines of the .vtg file they
use to run Vantage. The comment is the ";" at the start of the line.
Remove them and give it a shot. If not feel free to contact me off list
for more help, we use custom reports with ODBC connections for several
of our reports. I just instituted a new report for Employee Badge that
I created completely from scratch and that works also.
Good luck,
Aaron Hoyt
Hittite Microwave Corporation
Sent: Thursday, March 04, 2004 10:42 AM
Subject: Re: [Vantage] HOW TO USE A NEWLY CREATED CRYSTAL REPORT AS A
VANTAGE FORM
We are trying to do the same thing.
We have been told to utilize sub-reports to bring in
additional information.
But I have still not been able to get them to print in
Vantage. We get a 544 error I believe.
Doug
--- Rodney Warwick <r.warwick@...> wrote:
Do you Yahoo!?
Yahoo! Search - Find what you're looking for faster
http://search.yahoo.com
Yahoo! Groups Links
Good luck,
Aaron Hoyt
VANTAGE FORM
Doug
>__________________________________
> > We want to be able to add some Tables and fields
> to an existing Vantage
> > form, for example the Sales Order Form (SOFORM).
> > When I try to link additional tables to an
> existing form, I get the
> > following messages:
> > 1."File Link warning: The specified fields may not
> link successfully due
> > to different type."
> > 2."Link error: Invalid file link. Not all fields
> in same index expression"
> > 3."More than one database driver has been used in
> this report. If you want
> > to change the database drivers, use Database / Set
> Location. Also please
> > make sure that no SQL Expression is added and no
> server-side group-by is
> > performed.
> > When I try to run the form after adding extra
> tables, I get "Error 599".
> > As an alternative, I created a brand new Crystal
> Report from "scratch"
> > using the same tables. When I pointed the new
> Crystal Report in
> > "System Management / Configuration Maintenance /
> Report Style", and tried
> > to print the Form, I again got "Error 599".
> > Do you know if it is possible to use a newly
> created Crystal Report as a
> > Vantage Form?
> > Regards,
> > Rodney Warwick
> > The Signcraft Group
> [Non-text portions of this message have been
> removed]
Do you Yahoo!?
Yahoo! Groups Links
