Inter-company SO/PO
Hi Friends,
I have been trying hard to know how we can create inter-company POs and SOs please help?
I don’t know if this is the correct way to do it, probably not. But the way we handle that is to make a Customer Managed PO for $0. I would definitely love to hear other ways of handling this. I don’t really know what we do for SOs, but I could ask around.
Thanks Jonathan i would definitely try this.
If you are licensed for multi-company currently, I would highly recommend reviewing the Multi-Site Company Setup Technical Reference Guide (it is titled Multi-Site but it is actually for Multi-Company). This walks through all of the setups required as well as the process for inter-company POs/SOs.
Yes i have the license for multi company can you tell where can i find the technical reference guide? @BScanlan
If you are on a version of Kinetic, you can search for ‘Technical Reference Guide’ from your help in the software. Otherwise, they can be found on epicweb.epicor.com under Documentation > Technical Reference Guides
My company has automation where a PO from our Company A to our Company B results in automatic Sales Order generation in Company B. It sounds like what you are looking for.
I didn’t develop it, it was pre-existing when I came to work here. Basically several BPMs with a lot of C#.
I have got the guide Thanks a lot.
Ahh! No actually i was asking about the standard ICPO or ICSO process.
Once you have setup each of your companies as intercompany customer/supplier then you can create a PO from one company to the other, and run the Multi-Company Direct Server Process.
Reference the technical guide that was mentioned before, and reach out to your CAM for any other documentation they might have for Multi-Company setup.
Worst case, spend two hours with an Epicor Professional Services consultant to properly setup Multi-Company exactly the way you need it to function.
