Thank you all for your help.
The problem was with DHCP server configuration. As soon as I set the IP addresses manually, it worked.
Mike Tonoyan / All American Products Co.
miket@...
miket@...
----- Original Message -----
To: <vantage@yahoogroups.com>
Sent: Friday, June 07, 2002 10:43 AM
Subject: RE: [Vantage] Internet connection over LAN
> Manually set the gateway in the TCP/IP properties.
> Jim Carnes
> IS Administrator
> Kenlee Precision Corp
> jcarnes@...
> 1700 Morrell Park Ave
> Baltimore, MD 21230
> -----Original Message-----
> From: Mike Tonoyan [mailto:miket@...]
> Sent: Friday, June 07, 2002 1:27 PM
> To: vantage@yahoogroups.com
> Subject: Re: [Vantage] Internet connection over LAN
> I reinstalled TCP/IP protocol, but still IPCONFIG is not recognizing the
> default gateway. The registry file shows default gateway
> with the correct address.
> Mike
> From: "Shirley Graver" <shirleyg@...>
> Sent: Friday, June 07, 2002 9:18 AM
> > Try this: Since you have a default Gateway, Go to internet browser,
> Tools,
> > Internet Options, Connections, Lan Settings, Click Automaticaly detect
> > settings check box , Click Proxy Server check box, Click Advanced. In the
> > HTTP window, enter the proxy address of your gateway, under port enter 80.
> > Do the same for "Secure" and "FTP", Leave Gopher blank (ANOTHER Microsoft
> > security hole) for "Socks" (not Clinton's Cat) enter gateway address and
> > under port 1080. Then see what happens.
> > Shirley
> > Sent: Friday, June 07, 2002 11:43 AM
> > The clients are using DHCP for IP addresses, the Default Gateway and DNS
> > addresses are specified. The Internet Explorer browsers are
> > configured to Never dial a Dial UP connection and Automatically Detect
> > Settings on the LAN. I am not sure about the proxy.
> > Mike
> > Sent: Friday, June 07, 2002 8:38 AM
> > > Mike what kind of proxy are you using, how do you connect to the
> > internet,
> > > and how are you configuring the client browser.
> > > Shirley
> > > From: miket91326 [mailto:miket@...]
> > > Sent: Friday, June 07, 2002 11:25 AM
> > > Subject: [Vantage] Internet connection over LAN
> > > I am having difficulty connecting some computers to the internet
> over
> > > the LAN. Some PC's that never had a dial up connection to the
> > > internet before get connected without any problem, but those which
> > > had, do not. Any ideas?
> > > MIS Manager
> > > miket@...
> > > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You
> must
> > > have already linked your email address to a yahoo id to enable
> access. )
> > > (1) To access the Files Section of our Yahoo!Group for Report
> Builder
> > and
> > > Crystal Reports and other 'goodies', please goto:
> > > http://groups.yahoo.com/group/vantage/files/.
> > > (2) To search through old msg's goto:
> > > http://groups.yahoo.com/group/vantage/messages
> > > (3) To view links to Vendors that provide Vantage services goto:
> > > http://groups.yahoo.com/group/vantage/links
> > > Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
> > > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> > enable access. )
> > > (1) To access the Files Section of our Yahoo!Group for Report Builder
> > and Crystal Reports and other 'goodies', please goto:
> > http://docs.yahoo.com/info/terms/
> > have already linked your email address to a yahoo id to enable access. )
> and
> enable access. )
> > (1) To access the Files Section of our Yahoo!Group for Report Builder and
> > Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have
> <http://docs.yahoo.com/info/terms/> .
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have already linked your email address to a yahoo id to
enable access. )
> (1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto:
> (2) To search through old msg's goto: http://groups.yahoo.com/group/vantage/messages
> (3) To view links to Vendors that provide Vantage services goto: http://groups.yahoo.com/group/vantage/links
