Wayne,
It sounds like you went in under network setup (or shat ever its called)
thats good. But did you go into Control Panal > System > Network
Identification ??? You might need to set a few things there. Also on the
login in box, click on the details or options button . Make sure you are
logging in to the domain and not locally. Sorry this is missing a couple
specific names, I'm not in front of a 2000 PC... If it would help give me a
call.
nancy dunn
Winco Ind.
Sent: Tuesday, July 24, 2001 2:06 PM
Subject: [Vantage] OT - Win2000 Question
Hi All... was hoping someone out there with more Win2000 experience than
myself might be able to help with a problem.
I have installed it on a new machine, and cannot get any IP networking to
function. It has DHCP enabled, and is able to retrieve all its settings
from the server (verified though IPCONFIG /ALL) It also passes the 3Com
NIC diagnostics, including being able to broadcast to other 3Com NICs.
However, it can't see any other hosts on the LAN. Even the most simple
things - PINGing a server by IP address fail. Tried bypassing the DHCP and
setting static parameters for all the TCP/IP stuff, but still the
same. Also swapped in a different NIC, to no avail.
Any ideas?
-Thanks, Wayne Cox
call.
nancy dunn
Winco Ind.
Any ideas?
-Thanks, Wayne Cox
