After we optimize material usage by job we use service connect to update the material allocation by operation before the job is run.
Rob Bucek
Production Control Manager
PH: (715) 284-5376 ext 311
Mobile: (715)896-0590
FAX: (715)284-4084
[Description: cid:1.234354861@...]<http://www.dsmfg.com/>
(Click the logo to view our site)<http://www.dsmfg.com/>
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of greg_clauser
Sent: Friday, January 06, 2012 12:09 PM
Subject: [Vantage] Inventory and MOM issues with sheet stock 9.05.607
We just barely got up and running and are still trying to find out the best way to handle some things and what Epicor tools or features we could use better.
We use a lot of both wood and metal sheet stock. Popular raw sheet sizes are 48"x120", 60"x144", etc. (inventoried as 'each' and not sq ft). With the wood sheets, we use some optimizer software that will combine more than one job requirement if necessary to both effciently use the sheet as well as generate CNC code for our CNC routing machines. I guess for this area, MOMs would use material by the square foot with some estimated scrap percentage and backflush.
For the metal sheets, they are sheared in a more traditional manner without any optimizing so we often end up with large sheets of 'drop off' that we of course save and use whenever possible for smaller size requirements. I do not want to charge full sheets to a job if it really has significant usable drop off. On I'm looking at right now is a 89" by 29" piece being cut from a 48"x120" sheet for example. I'll likely get a 21"x48" drop off and a 19"x89" drop off when this is sheared.
If I backflush metal sheet material in square feet, I can have a lot of square footage in stock without very much of it being full sheets. I was thinking of creating two additional part numbers for 1/2 and maybe 1/4 sheets to track inventory of the drop off but creating additional part numbers does not seem like the best way.
My engineer also tells me that in JobBoss (that we just shut off), it would calculate how many (metal) sheets he would need for any cut sizes he specified in the job and was wondering if Epicor had a similar feature or even something that might optimize multiple job requirements on one sheet.
Anybody else out there use sheet stock in a similar manner? How do you handle in Epicor?
Rob Bucek
FAX: (715)284-4084
