Thanks to all for the input and thanks Charlie for your insight. I believe this solution seems to be the simplest. I'll tackle it from that angle.
--- In vantage@yahoogroups.com, "CharlieSmith" <CSmith@...> wrote:
> The problem is that the job is not completed. Unless you are going to
> use two separate jobs in which case you would need two separate finished
> part numbers. One for the finished part and one for the unfinished part
> (or the part that requires secondary work).
> Seems like a lot of work.
> A job status report that shows all of the open operations (and quantity
> completed) would be the best bet. Much like the job tracker except
> printed (or previewed) that only shows the open operations on a job. If
> he is pretty much a molding operation, there won't be too many ops in
> the method.
> Charlie Smith
> Smith Business Services / 2W Technologies LLC
> www.vistaconsultant.com <http://www.vistaconsultant.com/> /
> www.2WTech.com
> Of Steven Gotschall
> Sent: Friday, October 09, 2009 3:06 PM
> To: vantage@yahoogroups.com
> Subject: Re: [Vantage] Inventory Availability & Visibility
> How about a separate wharehouse? We use a separate warehouse for our
> showroom items and then move them back to our main wharehouse when we
> are ready to sell it.
> From: rgraf56 <rgraf@... <mailto:rgraf%40abapgt.com> >
> Sent: Fri, October 9, 2009 2:00:49 PM
> Subject: [Vantage] Inventory Availability & Visibility
> Hi All,
> I'm using Vantage 6.10 (without the Quality Module) in an injection
> molding operation. Currently parts are set to auto-receive to a
> warehouse bin when the molding is done. We sometimes (not always) need
> to sort parts or perform a secondary process before they can be issued
> to a customer order. I need some advice on the best way to show the
> parts as being molded and available to satisfy customer requirements but
> not yet in inventory. I'd like to keep it as simple as possible. Any and
> all help is greatly appreciated.
> Rick
