I would like to add the UOM to the inventory tags. Does anyone know how
to do this?
Best Regards,
Carol Silvey
Wisdom Industries, Ltd.
to do this?
Best Regards,
Carol Silvey
>I would like to add the UOM to the inventory tags. Does anyone know howJust amazing that they don't include that, ehh ?!
>to do this?
> &El=&SG=&RAND=24873&partner=hotbar>
> &El=&SG=&RAND=17429&partner=hotbar>
> &El=&SG=&RAND=6595&partner=hotbar>
--- In vantage@yahoogroups.com, "Alan Jensen" <ajensen@...> wrote:
> The tags are a crystal report so they can be modified. You need to
be
> somewhat experienced in crystal reports to do this though. If you
have
> someone in your company that is a crystal guru I would go to that
person.
> Otherwise I could try to explain it but it would be pretty
difficult.
> Thanks
> > Alan
> _____
Behalf Of
> surealloydan
> Sent: Tuesday, December 05, 2006 12:19 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Inventory Tags
> Hello,
> We are on Vantage 8.00. Every month we perform a physical count of
> some part of our inventory. As part of the process, we print
> inventory tags for the selected parts. We do this using Vantage,
> and we print two copies of each tag using a laser printer. We then
> cut the tags and staple the matching tags together and give them to
> the person doing the counting. He then leaves one copy with the
> part and the other goes to the person entering the counts. We're
> wondering if anyone has found a more efficient way of printing tags.
> We will be purchasing perforated paper for future counts, but we
> will still have to staple the matching tags. Does anyone know of a
> way to modify the way the tags are printed? Right now, we print two
> copies that each comes out as follows, 000,001,002,003,004, etc. I
> would like to have them come out in this order,
> 000,000,001,001,002,002, etc. That way the matching tags are
already
> together and can be separated by the counter. Do you know if this
> is possible? Thank you for any insight or suggestions.
> Dan Murray
> Inventory Specialist
> SAS Global Corporation
> tel: (248) 414-4470
> tel: (586) 510-3244 direct
> fax: (248) 414-4490
> danm@sasglobalcorp. <mailto:danm%40sasglobalcorp.com> com
--- In vantage@yahoogroups.com, "surealloydan" <danm@...> wrote:
> Hello,
of
then
to
tags.
a
two
I
already
> Dan Murray
> tel: (248) 414-4470
> fax: (248) 414-4490
> danm@...
be
have
person.
difficult.
> Thanks
> > Alan
> _____
Behalf Of
> surealloydan
> Hello,
already
> Dan Murray
> tel: (248) 414-4470
> fax: (248) 414-4490
Yahoo! Groups Links
>c,
> In the Section Expert go to the Details section (Not Details a, b,
> etc...) and look at the Layout Tap on the right. In there it isspecifying
> the Height and Width of the Detail Section. I don't know where itis getting
> set. On the Common Tab "Format with Multiple Columns" is set butgrayed out.
> I don't know why you can not remove it. But since Vantage isgenerating the
> XML file it could be being set there. I have not had a chance toinvestigate
> that.Behalf Of
> I set mine to a height of 1.75 and was able to get 6 to a page (not
> generating bar codes)
> Scott Litzau, MCP
> Olympus Flag & Banner
> Information Systems Manager
> scott.litzau@...
> P: 414-365-9732
> F: 414-355-1931
> -----Original Message-----
> bw2868bondas
> Sent: Tuesday, December 05, 2006 6:11 PM
> Subject: [Vantage] Re: Inventory Tags
> I have removed or suppressed parts of the tag we will not use. Try
> I may I can not get it to print more than three on a page and thereto
> is room for at least 5 - any Ideas on how to get the Details M to
> stop expanding out to 3.6 inches instaed of stopping at 1.75?
> there are no embedded lines that I can see...... and in design view
> it is not expanded.
> beyou
> haveof
> person.
> difficult.
> > Thanks
> > > Alan
> > _____
> Behalf Of
> > surealloydan
> > Hello,
> > some part of our inventory. As part of the process, we printthen
> > cut the tags and staple the matching tags together and give themto
> > the person doing the counting. He then leaves one copy with thetags.
> >a
> > way to modify the way the tags are printed? Right now, we printtwo
> > copies that each comes out as follows, 000,001,002,003,004, etc.I
> > would like to have them come out in this order,must have
> already
> > Dan Murray
> > tel: (248) 414-4470
> > fax: (248) 414-4490
> already linked your email address to a yahoo id to enable access. )Builder and
> Yahoo! Groups Links
