Hello Rick,
I think I get it. If I have an invoice that is only for misc charges, I
would create the invoice with a $0.00 amount, then add all the different
misc charges using the misc chrg button. I would then add a job to the
details section and I would only need to select one misc material seq from
the job making the $ amount match the misc total giving me a variance of
0.00. Is this correct?
Mark
Sent: Tuesday, June 25, 2002 4:27 PM
To: 'vantage@yahoogroups.com'
Subject: RE: [Vantage] Invoicing misc to a job
Hi Mark,
I am a former CFO/Bean counter, so I know you can make this approach work :)
You can apply many different miscellaneous charges in the A/P invoice line
entry screen (button at the bottom) for the entry against this job line.
Additionally, usually, and I say usually, if something is getting charged to
a job, the amount should go against WIP inventory and not one of many
different G/L account numbers that misc charges normally go against. But
this can and does vary by circumstance and accountant preference.
Let me know if you need further information.
Rick Lane
Intelligent Systems Integration, Inc.
600 Weber Drive
Wadsworth, OH 44281
PH: 330-335-5291
FX: 330-335-7275
"Helping Business Make Intelligent Use of Technology"
Sent: Tuesday, June 25, 2002 4:02 PM
Hi Rick,
I suggested this approach but my CFO gave me that look >:( Our bean
counters maintained different GL numbers for different misc charges(about 20
of them). Vantage has a misc charge table which maintains the account
numbers associated with the different charges. It just does not allow you
to add them to the job on the fly from ap/invoicing.
Mark
Sent: Tuesday, June 25, 2002 3:01 PM
Why don't you add one standard material to each/every job to catch all of
these miscellaneous charges when the job is originally created. You can
then tie any/all miscellaneous charges to this one material on the job. You
can still see the detail of the charges by looking in job tracker or the
production detail report. Also, as long as there is a material associated
with a miscellaneous charge on the job, it can be "charged against" even if
the job is marked complete.
All of this can be done directly from the A/P screen.
Rick Lane
600 Weber Drive
Wadsworth, OH 44281
PH: 330-335-5291
FX: 330-335-7275
Sent: Tuesday, June 25, 2002 1:35 PM
And there's more. We have jobs which are completed. We have
invoices for
misc items like unplanned freight charges which need to be tied to the job.
We have to go into job closing, uncheck the complete box, go to the job,
uncheck the engineered box, add a misc freight material, check the released
box, go to job closing and check the complete box. Now we can tie the
invoice to the job. Somebody please tell me there is a better way?
Mark
Sent: Monday, June 24, 2002 11:54 AM
What I have found is that you must have a misc material called out
in the
job and it must be tied to a misc charge defined in the Misc Charge table.
If this is done you can then tie an invoice to it. The job material
quantity can stay at 1 and you can still tie multiple invoices to it with
varing quantities.
It's a pain to go back to the job, unengineer, added the material,
and then
release the job to create this entry. It would be much nicer if you could
add this material line item to the job from invoice entry.
Mark
Sent: Monday, June 24, 2002 9:08 AM
Sarah,
That functionality was introduced in 5.1.
Tim
From: sarah.vareschi@... [mailto:sarah.vareschi@...]
Sent: Monday, June 24, 2002 8:05 AM
From what I've heard, in 5.2, you can tie an A/P invoice just to a 'job'.
Mark
Hi Mark,
Rick Lane
600 Weber Drive
Wadsworth, OH 44281
PH: 330-335-5291
FX: 330-335-7275
Hi Rick,
Mark
Rick Lane
600 Weber Drive
Wadsworth, OH 44281
PH: 330-335-5291
FX: 330-335-7275
invoices for
Mark
in the
varing quantities.
and then
Mark
Sarah,
Tim
