You can add the cost of your tooling to the job without using an
existing part, without creating a purchasing suggestion, without
having to receive apart and without having to issue a part by
flagging it as a miscellaneous part. To do this, go to your job in
Job
Entry, go to the material pull down menu and go to add. A new
Material
Maintenance screen will appear -- make up a part number and
description, then check off the Miscellaneous Charge box, then select
a miscellaneous charge category and type in the cost. Hit OK, and you
will see the Misc charge appear as an issued material in your job.
Good Luck,
James Moore
LCEI
Job
Material
Good Luck,
James Moore
LCEI
> Behalf Oftooling
> Ben Belzer
> Sent: Wednesday, June 21, 2006 4:38 PM
> To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
> Subject: [Vantage] Adding cost to job
> I am running 6.1 and I would like to be able to add expendable
> costs to my jobs.tedious
> I wish there was a way to do so without having to go through the
> way of adding a material.master, I
> The problem is that if I add a material that is not in my part
> can't accurately show cost. Is that correct?part
> For example, I add a material XYZ to a job, and it is not in the
> master. How can I issue this material with a cost?
> Is anyone else doing something like this?
> Thanks in advance,
> Ben
> Ben Belzer
> Manager
> Inside Sales
> TCI Precision Metals
> 800.234.5613.W
> 310.323.1255.F
