Is it possible to use solution workbench to export process set?
Hi Folks,
I need to move following items from one environment to another. My preference is package them up and deploy using solution workbench but happy to export and import by other means if it is possible to do so. I’ve had a good hunt around Epicor and forums but no joy at the moment. I can find any of this stuff in solution workbench…Any ideas?
  1. BAQ Export Processes
  2. Process Set containing these BAQ Exports
  3. System Agent Schedule
  4. Schedule Process Set
I don’t remember anything that would support this. You might try submitting a service call to Tech Support. It might be possible to add this to the solution tracking.
Ok thank you Tim.
Sadly I believe those items all need to be rebuild from scratch post-upgrade.
(they certainly did when I went from 9.05 to 10.2.300)
My only suggestion would be creating lots of detailed documentation / screenshots & lots of test runs: depending on how many you have it can be a time-consuming fiddly part of the process.
Jon - did you ever get a viable solution on this?
You can but you have to do it with two solution elements. One for ProcessSet table and one for the ProcessTask with the child param table set in the element. I just did this today to move some things from a dev to test environment.
I will check on that tomorrow and let you know how it goes
Is this still the case in Kinetic?
