Job Adjustments in Updatable Dashboard
HI
In my experience, if the BO is not available on the Update Processing tab then you are NOT allowed to update using that method.
There are several instances where Updateable BAQs do not work LaborDtl (JobAdjustment) is one of them.
If you have some questions you can PM me.
Marianne Gizzi
Estes Group - Epicor Patner
mgizzi@...
Has anyone created an updatable BAQ for use in a dashboard to do labor adjustments (complete and report a quantity)? I see the BO that is called is JobAdjustment but not sure how to make this work in a BAQ.
I have tried to bring in the LaborDtl table but on the Update Processing tab where you select the business object, JobAdjustment is not available.
Ted
