Job Costing error Vantage 803.405
Larry,
Did you do a cost roll-up on the full assembly prior to starting the job? Related to Manasa’s question, we run on standard cost. If we don’t do that cost roll-up, WIP cannot be properly relieved at the time of job receipt.
Mark L. Knight, CPIM
Master Scheduler
Picometrix, LLC (an API company)
2925 Boardwalk
Ann Arbor, MI 48104
Phone: 734-864-5675
Fax: 734-998-3474
mknight@... <mailto:mknight@...>
This transmission contains information belonging to Picometrix and is confidential and/or legally privileged under all Non-Disclosure Agreements in place between Picometrix and the recipient. The information is intended for the use of the individual or entity named above. If you are not the intended recipient, you are hereby notified that disclosing, distributing or copying this information is strictly prohibited. If you have received this email in error, please contact the sender named above.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Larry Barriere
Sent: Wednesday, June 30, 2010 2:49 PM
To: Vantage Group
Subject: [Vantage] Job Costing error Vantage 803.405
We have been having a serious problem with job costing.
These are the step that I took to recreated the problem.
I created four parts “ATop”, “ASub”, “ACheap” and “AExpensive”
Adjusted the inventory with 100 “ACheap” and 100 “AExpensive”
Adjusted the cost to “ACheap” =$0.05 and “AExpensive” = $1,000.00 Total inventory value of $100,005.00
I then engineered and Approve “ATop” and “ASub”
“ASub” consisted of 1 operation and 1 “AExpensive” part
“ATop” consisted of 1 operation, one sub assembly “ASub” and one material “ACheap”
The problem starts with the following procedures
I then Create a job for “ATop” for a Qty of 5 Engineer and release job
Issue Material
Issue 5 “Acheap” material to level 0 (Issues Material)
Issue 5 “ASub” as sub assembly to level 0 (Issues Assembly)
Add Zero labor to level 0 and only completed qty 4
Receive the job to stock for a Qty of 4 and COMPLETE the Job
I received the 4 parts into inventory @ a cost of $0.05 per. But the job unit cost $1,250.05.
I have been able to reproduce this on demand.
I have discover that if we do not received the complete job demand and have pulled some sub-assembly that it will not record properly.
As you can see this is unacceptable since our inventory value will be completely off and the mfg variance account keep getting hit.
I did contact Tech about this but have not been able to convince anyone that we have a problem.I believe that Epicor is not taking this very seriously.
Has anyone else had problems with the production report and cost received to inventory. I would like to hear from anyone else that has been having trouble getting the "Production Detail Report" to report correctly.
Thank you
Larry Barriere
larry.barriere@... <mailto:larry.barriere%40symmetrymedical.com>
W 603-626-3160
Issue Material
Receive the job to stock for a Qty of 4 Â and COMPLETE the Job
Â
Â
Â
Thank you
Â
Larry Barriere
larry.barriere@...
W 603-626-3160
Unless I missed it in reading your post, one important question...what
is your costing method? Average, Standard, or Last?
M. Manasa Reddy
manasa@... <mailto:manasa@...>
800.852.2325
630.806.2000 ofc
630.806.2001 fax
www.weldcoa.com
Of Larry Barriere
Sent: Wednesday, June 30, 2010 1:49 PM
To: Vantage Group
I created four parts "ATop", "ASub", "ACheap" and "AExpensive"
Adjusted the inventory with 100 "ACheap" and 100 "AExpensive"
Adjusted the cost to "ACheap" =$0.05 and "AExpensive" = $1,000.00 Total
I then engineered and Approve "ATop" and "ASub"
"ASub" consisted of 1 operation and 1 "AExpensive" part
"ATop" consisted of 1 operation, one sub assembly "ASub" and one
material "ACheap"
I then Create a job for "ATop" for a Qty of 5 Engineer and release job
Issue Material
Issue 5 "Acheap" material to level 0 (Issues Material)
Issue 5 "ASub" as sub assembly to level 0 (Issues Assembly)
seriously.
correctly.
Thank you
Larry Barriere
larry.barriere@...
W 603-626-3160
