Jobs / Wip Reconcilliation
Inventory doesnt go neg typically.
We have simple BOM's.  1 operation where material is backflushed.
each shift reports production real time(1 carton filled 1 carton reported), we confirm qty for each shift is correct and do a Receipt to inventory.  Qty received is the combined amount of 3 shifts.
We pull from stock to another job to complete a finished good.
We also transfer from A location to B location.
there's a number of transactions before next day shift reporting.
But the variance on cost seems to drastic.
I see the adj-cost in Part Transaction history Tracker.
I can't attach that page here to give you a clearer picture.
Thanks for your help.
From: "'Cathy' cathy@... [vantage]" <vantage@yahoogroups.com>
Sent: Tuesday, May 20, 2014 3:54 PM
Subject: RE: [Vantage] jobs / Wip Reconcilliation
Umh – When you say cost adjustments to the job is the MFG-VAR transaction?
When is the material being backflushed?  First operation?  Last?
When is the receipt being done?
Do you allow your inventory to go negative?
Sent: Tuesday, May 20, 2014 12:45 PM
Subject: Re: [Vantage] jobs / Wip Reconcilliation
I understand Average cost fluctuates, just not sure what causes it to fluctuate so drastically as stated below.  Same amount of material issued.
I understand it has to do with timing and any transactions between each days reporting, but .06 difference is to much.  Creates cost adjustments in the job.  Which may be part of the suspense amount.
As much as i've learned i know nothing  ((sigh))
Thanks for the help
From: "Joshua Serwe jserwe@... [vantage]" <vantage@yahoogroups.com>
To: "vantage@yahoogroups.com" <vantage@yahoogroups.com>
Sent: Tuesday, May 20, 2014 3:34 PM
Average costing will fluctuate by transaction
Josh Serwe
Wisconsin Converting Inc.
Production Planning & Logistics
(920)437-6400 x 327
Sent: Tuesday, May 20, 2014 2:26 PM
We use average cost.
Cathy,
Do you know what would cause a part cost to change from
Day 1: .09
Day 2: .03
Day 3: .09
same qty each day.
Sent: Tuesday, May 20, 2014 2:49 PM
What costing method are you using?
Sent: Tuesday, May 20, 2014 11:05 AM
We are not auto-receiving. We do Job receipt to inventory at the end of the day.
From: "Joshua Serwe mailto:jserwe@...%3cmailto:jserwe@...> [vantage]" <mailto:vantage@yahoogroups.com%3cmailto:vantage@yahoogroups.com>>
To: "mailto:vantage@yahoogroups.com%3cmailto:vantage@yahoogroups.com%3e" <mailto:vantage@yahoogroups.com%3cmailto:vantage@yahoogroups.com>>
Sent: Tuesday, May 20, 2014 12:07 PM
It should be… are you auto receiving to inventory as well? That may cause a timing issue.
Josh Serwe
(920)437-6400 x 327
From: mailto:vantage@yahoogroups.com%3cmailto:vantage@yahoogroups.com> [mailto:vantage@yahoogroups.com]
Sent: Tuesday, May 20, 2014 11:03 AM
To: mailto:vantage@yahoogroups.com%3cmailto:vantage@yahoogroups.com>
We're backflushing material. I thought that meant material was issued as soon as production is reported.
From: "'Cathy' mailto:cathy@...%3cmailto:cathy@...> [vantage]" <mailto:vantage@yahoogroups.com%3cmailto:vantage@yahoogroups.com>>
Sent: Tuesday, May 20, 2014 11:59 AM
We usually get variances when there is a timing problem.
Did any material get issued after the Job was received to stock?
Sent: Tuesday, May 20, 2014 8:43 AM
MFG to VAR
Sent: Tuesday, May 20, 2014 11:27 AM
What is the transaction type for the $150?
Sent: Tuesday, May 20, 2014 8:07 AM
Subject: [Vantage] jobs / Wip Reconcilliation
Hi all,
Question regarding jobs again......
We create jobs manuf to stock. When we're done with the run, I check the estimated material usage compared to actual usage. It's off by $10.00 (maybe)allowing for scrap. Yet when i run the Wip Reconcilliation for the job, $150.00 hit the suspense account.
I can't figure where the 150.00 is coming from.
Could it be the difference if i change the qty prod to match the qty received ?
I've been struggling with this for a few weeks now.
thanks in advance
#ygrps-yiv-1182046408 #ygrps-yiv-1182046408yiv4540147328 #ygrps-yiv-1182046408yiv4540147328 -- #ygrps-yiv-1182046408yiv4540147328ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}
#ygrps-yiv-1182046408 #ygrps-yiv-1182046408yiv4540147328 #ygrps-yiv-1182046408yiv4540147328ygrp-mkp hr {
border:1px solid #d8d8d8;}
#ygrps-yiv-1182046408 #ygrps-yiv-1182046408yiv4540147328 #ygrps-yiv-1182046408yiv4540147328ygrp-mkp #ygrps-yiv-1182046408yiv4540147328hd {
color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}
#ygrps-yiv-1182046408 #ygrps-yiv-1182046408yiv4540147328 #ygrps-yiv-1182046408yiv4540147328ygrp-mkp #ygrps-yiv-1182046408yiv4540147328ads {
margin-bottom:10px;}
#ygrps-yiv-1182046408 #ygrps-yiv-1182046408yiv4540147328 #ygrps-yiv-1182046408yiv4540147328ygrp-mkp .ygrps-yiv-1182046408yiv4540147328ad {
padding:0 0;}
#ygrps-yiv-1182046408 #ygrps-yiv-1182046408yiv4540147328 #ygrps-yiv-1182046408yiv4540147328ygrp-mkp .ygrps-yiv-1182046408yiv4540147328ad p {
margin:0;}
#ygrps-yiv-1182046408 #ygrps-yiv-1182046408yiv4540147328 #ygrps-yiv-1182046408yiv4540147328ygrp-mkp .ygrps-yiv-1182046408yiv4540147328ad a {
color:#0000ff;text-decoration:none;}
#ygrps-yiv-1182046408 #ygrps-yiv-1182046408yiv4540147328 #ygrps-yiv-1182046408yiv4540147328ygrp-sponsor #ygrps-yiv-1182046408yiv4540147328ygrp-lc {
font-family:Arial;}
#ygrps-yiv-1182046408 #ygrps-yiv-1182046408yiv4540147328 #ygrps-yiv-1182046408yiv4540147328ygrp-sponsor #ygrps-yiv-1182046408yiv4540147328ygrp-lc #ygrps-yiv-1182046408yiv4540147328hd {
margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}
#ygrps-yiv-1182046408 #ygrps-yiv-1182046408yiv4540147328 #ygrps-yiv-1182046408yiv4540147328ygrp-sponsor #ygrps-yiv-1182046408yiv4540147328ygrp-lc .ygrps-yiv-1182046408yiv4540147328ad {
margin-bottom:10px;padding:0 0;}
#ygrps-yiv-1182046408 #ygrps-yiv-1182046408yiv4540147328 #ygrps-yiv-1182046408yiv4540147328actions {
font-family:Verdana;font-size:11px;padding:10px 0;}
#ygrps-yiv-1182046408 #ygrps-yiv-1182046408yiv4540147328 #ygrps-yiv-1182046408yiv4540147328activity {
background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}
#ygrps-yiv-1182046408 #ygrps-yiv-1182046408yiv4540147328 #ygrps-yiv-1182046408yiv4540147328activity span {
font-weight:700;}
#ygrps-yiv-1182046408 #ygrps-yiv-1182046408yiv4540147328 #ygrps-yiv-1182046408yiv4540147328activity span:first-child {
text-transform:uppercase;}
#ygrps-yiv-1182046408 #ygrps-yiv-1182046408yiv4540147328 #ygrps-yiv-1182046408yiv4540147328activity span a {
color:#5085b6;text-decoration:none;}
#ygrps-yiv-1182046408 #ygrps-yiv-1182046408yiv4540147328 #ygrps-yiv-1182046408yiv4540147328activity span span {
color:#ff7900;}
#ygrps-yiv-1182046408 #ygrps-yiv-1182046408yiv4540147328 #ygrps-yiv-1182046408yiv4540147328activity span .ygrps-yiv-1182046408yiv4540147328underline {
text-decoration:underline;}
#ygrps-yiv-1182046408 #ygrps-yiv-1182046408yiv4540147328 .ygrps-yiv-1182046408yiv4540147328attach {
clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}
#ygrps-yiv-1182046408 #ygrps-yiv-1182046408yiv4540147328 .ygrps-yiv-1182046408yiv4540147328attach div a {
#ygrps-yiv-1182046408 #ygrps-yiv-1182046408yiv4540147328 .ygrps-yiv-1182046408yiv4540147328attach img {
border:none;padding-right:5px;}
#ygrps-yiv-1182046408 #ygrps-yiv-1182046408yiv4540147328 .ygrps-yiv-1182046408yiv4540147328attach label {
display:block;margin-bottom:5px;}
#ygrps-yiv-1182046408 #ygrps-yiv-1182046408yiv4540147328 .ygrps-yiv-1182046408yiv4540147328attach label a {
#ygrps-yiv-1182046408 #ygrps-yiv-1182046408yiv4540147328 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-1182046408 #ygrps-yiv-1182046408yiv4540147328 .ygrps-yiv-1182046408yiv4540147328bold {
font-family:Arial;font-size:13px;font-weight:700;}
#ygrps-yiv-1182046408 #ygrps-yiv-1182046408yiv4540147328 .ygrps-yiv-1182046408yiv4540147328bold a {
#ygrps-yiv-1182046408 #ygrps-yiv-1182046408yiv4540147328 dd.ygrps-yiv-1182046408yiv4540147328last p a {
font-family:Verdana;font-weight:700;}
#ygrps-yiv-1182046408 #ygrps-yiv-1182046408yiv4540147328 dd.ygrps-yiv-1182046408yiv4540147328last p span {
margin-right:10px;font-family:Verdana;font-weight:700;}
#ygrps-yiv-1182046408 #ygrps-yiv-1182046408yiv4540147328 dd.ygrps-yiv-1182046408yiv4540147328last p span.ygrps-yiv-1182046408yiv4540147328yshortcuts {
margin-right:0;}
#ygrps-yiv-1182046408 #ygrps-yiv-1182046408yiv4540147328 div.ygrps-yiv-1182046408yiv4540147328attach-table div div a {
#ygrps-yiv-1182046408 #ygrps-yiv-1182046408yiv4540147328 div.ygrps-yiv-1182046408yiv4540147328attach-table {
width:400px;}
#ygrps-yiv-1182046408 #ygrps-yiv-1182046408yiv4540147328 div.ygrps-yiv-1182046408yiv4540147328file-title a, #ygrps-yiv-1182046408 #ygrps-yiv-1182046408yiv4540147328 div.ygrps-yiv-1182046408yiv4540147328file-title a:active, #ygrps-yiv-1182046408 #ygrps-yiv-1182046408yiv4540147328 div.ygrps-yiv-1182046408yiv4540147328file-title a:hover, #ygrps-yiv-1182046408 #ygrps-yiv-1182046408yiv4540147328 div.ygrps-yiv-1182046408yiv4540147328file-title a:visited {
#ygrps-yiv-1182046408 #ygrps-yiv-1182046408yiv4540147328 div.ygrps-yiv-1182046408yiv4540147328photo-title a, #ygrps-yiv-1182046408 #ygrps-yiv-1182046408yiv4540147328 div.ygrps-yiv-1182046408yiv4540147328photo-title a:active, #ygrps-yiv-1182046408 #ygrps-yiv-1182046408yiv4540147328 div.ygrps-yiv-1182046408yiv4540147328photo-title a:hover, #ygrps-yiv-1182046408 #ygrps-yiv-1182046408yiv4540147328 div.ygrps-yiv-1182046408yiv4540147328photo-title a:visited {
#ygrps-yiv-1182046408 #ygrps-yiv-1182046408yiv4540147328 div#ygrps-yiv-1182046408yiv4540147328ygrp-mlmsg #ygrps-yiv-1182046408yiv4540147328ygrp-msg p a span.ygrps-yiv-1182046408yiv4540147328yshortcuts {
font-family:Verdana;font-size:10px;font-weight:normal;}
#ygrps-yiv-1182046408 #ygrps-yiv-1182046408yiv4540147328 .ygrps-yiv-1182046408yiv4540147328green {
color:#628c2a;}
#ygrps-yiv-1182046408 #ygrps-yiv-1182046408yiv4540147328 .ygrps-yiv-1182046408yiv4540147328MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-1182046408 #ygrps-yiv-1182046408yiv4540147328 o {
font-size:0;}
#ygrps-yiv-1182046408 #ygrps-yiv-1182046408yiv4540147328 #ygrps-yiv-1182046408yiv4540147328photos div {
float:left;width:72px;}
#ygrps-yiv-1182046408 #ygrps-yiv-1182046408yiv4540147328 #ygrps-yiv-1182046408yiv4540147328photos div div {
border:1px solid #666666;height:62px;overflow:hidden;width:62px;}
#ygrps-yiv-1182046408 #ygrps-yiv-1182046408yiv4540147328 #ygrps-yiv-1182046408yiv4540147328photos div label {
color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}
#ygrps-yiv-1182046408 #ygrps-yiv-1182046408yiv4540147328 #ygrps-yiv-1182046408yiv4540147328reco-category {
font-size:77%;}
#ygrps-yiv-1182046408 #ygrps-yiv-1182046408yiv4540147328 #ygrps-yiv-1182046408yiv4540147328reco-desc {
font-size:77%;}
#ygrps-yiv-1182046408 #ygrps-yiv-1182046408yiv4540147328 .ygrps-yiv-1182046408yiv4540147328replbq {
margin:4px;}
#ygrps-yiv-1182046408 #ygrps-yiv-1182046408yiv4540147328 #ygrps-yiv-1182046408yiv4540147328ygrp-actbar div a:first-child {
margin-right:2px;padding-right:5px;}
#ygrps-yiv-1182046408 #ygrps-yiv-1182046408yiv4540147328 #ygrps-yiv-1182046408yiv4540147328ygrp-mlmsg {
font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}
#ygrps-yiv-1182046408 #ygrps-yiv-1182046408yiv4540147328 #ygrps-yiv-1182046408yiv4540147328ygrp-mlmsg table {
font-size:inherit;font:100%;}
#ygrps-yiv-1182046408 #ygrps-yiv-1182046408yiv4540147328 #ygrps-yiv-1182046408yiv4540147328ygrp-mlmsg select, #ygrps-yiv-1182046408 #ygrps-yiv-1182046408yiv4540147328 input, #ygrps-yiv-1182046408 #ygrps-yiv-1182046408yiv4540147328 textarea {
font:99% Arial, Helvetica, clean, sans-serif;}
#ygrps-yiv-1182046408 #ygrps-yiv-1182046408yiv4540147328 #ygrps-yiv-1182046408yiv4540147328ygrp-mlmsg pre, #ygrps-yiv-1182046408 #ygrps-yiv-1182046408yiv4540147328 code {
font:115% monospace;}
#ygrps-yiv-1182046408 #ygrps-yiv-1182046408yiv4540147328 #ygrps-yiv-1182046408yiv4540147328ygrp-mlmsg * {
line-height:1.22em;}
#ygrps-yiv-1182046408 #ygrps-yiv-1182046408yiv4540147328 #ygrps-yiv-1182046408yiv4540147328ygrp-mlmsg #ygrps-yiv-1182046408yiv4540147328logo {
padding-bottom:10px;}
#ygrps-yiv-1182046408 #ygrps-yiv-1182046408yiv4540147328 #ygrps-yiv-1182046408yiv4540147328ygrp-msg p a {
font-family:Verdana;}
#ygrps-yiv-1182046408 #ygrps-yiv-1182046408yiv4540147328 #ygrps-yiv-1182046408yiv4540147328ygrp-msg p#ygrps-yiv-1182046408yiv4540147328attach-count span {
color:#1E66AE;font-weight:700;}
#ygrps-yiv-1182046408 #ygrps-yiv-1182046408yiv4540147328 #ygrps-yiv-1182046408yiv4540147328ygrp-reco #ygrps-yiv-1182046408yiv4540147328reco-head {
color:#ff7900;font-weight:700;}
#ygrps-yiv-1182046408 #ygrps-yiv-1182046408yiv4540147328 #ygrps-yiv-1182046408yiv4540147328ygrp-reco {
margin-bottom:20px;padding:0px;}
#ygrps-yiv-1182046408 #ygrps-yiv-1182046408yiv4540147328 #ygrps-yiv-1182046408yiv4540147328ygrp-sponsor #ygrps-yiv-1182046408yiv4540147328ov li a {
font-size:130%;text-decoration:none;}
#ygrps-yiv-1182046408 #ygrps-yiv-1182046408yiv4540147328 #ygrps-yiv-1182046408yiv4540147328ygrp-sponsor #ygrps-yiv-1182046408yiv4540147328ov li {
font-size:77%;list-style-type:square;padding:6px 0;}
#ygrps-yiv-1182046408 #ygrps-yiv-1182046408yiv4540147328 #ygrps-yiv-1182046408yiv4540147328ygrp-sponsor #ygrps-yiv-1182046408yiv4540147328ov ul {
margin:0;padding:0 0 0 8px;}
#ygrps-yiv-1182046408 #ygrps-yiv-1182046408yiv4540147328 #ygrps-yiv-1182046408yiv4540147328ygrp-text {
font-family:Georgia;}
#ygrps-yiv-1182046408 #ygrps-yiv-1182046408yiv4540147328 #ygrps-yiv-1182046408yiv4540147328ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-1182046408 #ygrps-yiv-1182046408yiv4540147328 #ygrps-yiv-1182046408yiv4540147328ygrp-text tt {
font-size:120%;}
#ygrps-yiv-1182046408 #ygrps-yiv-1182046408yiv4540147328 #ygrps-yiv-1182046408yiv4540147328ygrp-vital ul li:last-child {
border-right:none !important;}
Hi all,
thanks in advance
Hi all,
thanks in advance
MFG to VAR
Hi all,
thanks in advance
#ygrps-yiv-59794061 #ygrps-yiv-59794061yiv7671681740 #ygrps-yiv-59794061yiv7671681740 -- #ygrps-yiv-59794061yiv7671681740ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}
#ygrps-yiv-59794061 #ygrps-yiv-59794061yiv7671681740 #ygrps-yiv-59794061yiv7671681740ygrp-mkp hr {
#ygrps-yiv-59794061 #ygrps-yiv-59794061yiv7671681740 #ygrps-yiv-59794061yiv7671681740ygrp-mkp #ygrps-yiv-59794061yiv7671681740hd {
#ygrps-yiv-59794061 #ygrps-yiv-59794061yiv7671681740 #ygrps-yiv-59794061yiv7671681740ygrp-mkp #ygrps-yiv-59794061yiv7671681740ads {
#ygrps-yiv-59794061 #ygrps-yiv-59794061yiv7671681740 #ygrps-yiv-59794061yiv7671681740ygrp-mkp .ygrps-yiv-59794061yiv7671681740ad {
padding:0 0;}
#ygrps-yiv-59794061 #ygrps-yiv-59794061yiv7671681740 #ygrps-yiv-59794061yiv7671681740ygrp-mkp .ygrps-yiv-59794061yiv7671681740ad p {
margin:0;}
#ygrps-yiv-59794061 #ygrps-yiv-59794061yiv7671681740 #ygrps-yiv-59794061yiv7671681740ygrp-mkp .ygrps-yiv-59794061yiv7671681740ad a {
#ygrps-yiv-59794061 #ygrps-yiv-59794061yiv7671681740 #ygrps-yiv-59794061yiv7671681740ygrp-sponsor #ygrps-yiv-59794061yiv7671681740ygrp-lc {
font-family:Arial;}
#ygrps-yiv-59794061 #ygrps-yiv-59794061yiv7671681740 #ygrps-yiv-59794061yiv7671681740ygrp-sponsor #ygrps-yiv-59794061yiv7671681740ygrp-lc #ygrps-yiv-59794061yiv7671681740hd {
#ygrps-yiv-59794061 #ygrps-yiv-59794061yiv7671681740 #ygrps-yiv-59794061yiv7671681740ygrp-sponsor #ygrps-yiv-59794061yiv7671681740ygrp-lc .ygrps-yiv-59794061yiv7671681740ad {
#ygrps-yiv-59794061 #ygrps-yiv-59794061yiv7671681740 #ygrps-yiv-59794061yiv7671681740actions {
#ygrps-yiv-59794061 #ygrps-yiv-59794061yiv7671681740 #ygrps-yiv-59794061yiv7671681740activity {
#ygrps-yiv-59794061 #ygrps-yiv-59794061yiv7671681740 #ygrps-yiv-59794061yiv7671681740activity span {
font-weight:700;}
#ygrps-yiv-59794061 #ygrps-yiv-59794061yiv7671681740 #ygrps-yiv-59794061yiv7671681740activity span:first-child {
#ygrps-yiv-59794061 #ygrps-yiv-59794061yiv7671681740 #ygrps-yiv-59794061yiv7671681740activity span a {
#ygrps-yiv-59794061 #ygrps-yiv-59794061yiv7671681740 #ygrps-yiv-59794061yiv7671681740activity span span {
color:#ff7900;}
#ygrps-yiv-59794061 #ygrps-yiv-59794061yiv7671681740 #ygrps-yiv-59794061yiv7671681740activity span .ygrps-yiv-59794061yiv7671681740underline {
#ygrps-yiv-59794061 #ygrps-yiv-59794061yiv7671681740 .ygrps-yiv-59794061yiv7671681740attach {
#ygrps-yiv-59794061 #ygrps-yiv-59794061yiv7671681740 .ygrps-yiv-59794061yiv7671681740attach div a {
#ygrps-yiv-59794061 #ygrps-yiv-59794061yiv7671681740 .ygrps-yiv-59794061yiv7671681740attach img {
#ygrps-yiv-59794061 #ygrps-yiv-59794061yiv7671681740 .ygrps-yiv-59794061yiv7671681740attach label {
#ygrps-yiv-59794061 #ygrps-yiv-59794061yiv7671681740 .ygrps-yiv-59794061yiv7671681740attach label a {
#ygrps-yiv-59794061 #ygrps-yiv-59794061yiv7671681740 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-59794061 #ygrps-yiv-59794061yiv7671681740 .ygrps-yiv-59794061yiv7671681740bold {
#ygrps-yiv-59794061 #ygrps-yiv-59794061yiv7671681740 .ygrps-yiv-59794061yiv7671681740bold a {
#ygrps-yiv-59794061 #ygrps-yiv-59794061yiv7671681740 dd.ygrps-yiv-59794061yiv7671681740last p a {
#ygrps-yiv-59794061 #ygrps-yiv-59794061yiv7671681740 dd.ygrps-yiv-59794061yiv7671681740last p span {
#ygrps-yiv-59794061 #ygrps-yiv-59794061yiv7671681740 dd.ygrps-yiv-59794061yiv7671681740last p span.ygrps-yiv-59794061yiv7671681740yshortcuts {
margin-right:0;}
#ygrps-yiv-59794061 #ygrps-yiv-59794061yiv7671681740 div.ygrps-yiv-59794061yiv7671681740attach-table div div a {
#ygrps-yiv-59794061 #ygrps-yiv-59794061yiv7671681740 div.ygrps-yiv-59794061yiv7671681740attach-table {
width:400px;}
#ygrps-yiv-59794061 #ygrps-yiv-59794061yiv7671681740 div.ygrps-yiv-59794061yiv7671681740file-title a, #ygrps-yiv-59794061 #ygrps-yiv-59794061yiv7671681740 div.ygrps-yiv-59794061yiv7671681740file-title a:active, #ygrps-yiv-59794061 #ygrps-yiv-59794061yiv7671681740 div.ygrps-yiv-59794061yiv7671681740file-title a:hover, #ygrps-yiv-59794061 #ygrps-yiv-59794061yiv7671681740 div.ygrps-yiv-59794061yiv7671681740file-title a:visited {
#ygrps-yiv-59794061 #ygrps-yiv-59794061yiv7671681740 div.ygrps-yiv-59794061yiv7671681740photo-title a, #ygrps-yiv-59794061 #ygrps-yiv-59794061yiv7671681740 div.ygrps-yiv-59794061yiv7671681740photo-title a:active, #ygrps-yiv-59794061 #ygrps-yiv-59794061yiv7671681740 div.ygrps-yiv-59794061yiv7671681740photo-title a:hover, #ygrps-yiv-59794061 #ygrps-yiv-59794061yiv7671681740 div.ygrps-yiv-59794061yiv7671681740photo-title a:visited {
#ygrps-yiv-59794061 #ygrps-yiv-59794061yiv7671681740 div#ygrps-yiv-59794061yiv7671681740ygrp-mlmsg #ygrps-yiv-59794061yiv7671681740ygrp-msg p a span.ygrps-yiv-59794061yiv7671681740yshortcuts {
#ygrps-yiv-59794061 #ygrps-yiv-59794061yiv7671681740 .ygrps-yiv-59794061yiv7671681740green {
color:#628c2a;}
#ygrps-yiv-59794061 #ygrps-yiv-59794061yiv7671681740 .ygrps-yiv-59794061yiv7671681740MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-59794061 #ygrps-yiv-59794061yiv7671681740 o {
font-size:0;}
#ygrps-yiv-59794061 #ygrps-yiv-59794061yiv7671681740 #ygrps-yiv-59794061yiv7671681740photos div {
#ygrps-yiv-59794061 #ygrps-yiv-59794061yiv7671681740 #ygrps-yiv-59794061yiv7671681740photos div div {
#ygrps-yiv-59794061 #ygrps-yiv-59794061yiv7671681740 #ygrps-yiv-59794061yiv7671681740photos div label {
#ygrps-yiv-59794061 #ygrps-yiv-59794061yiv7671681740 #ygrps-yiv-59794061yiv7671681740reco-category {
font-size:77%;}
#ygrps-yiv-59794061 #ygrps-yiv-59794061yiv7671681740 #ygrps-yiv-59794061yiv7671681740reco-desc {
font-size:77%;}
#ygrps-yiv-59794061 #ygrps-yiv-59794061yiv7671681740 .ygrps-yiv-59794061yiv7671681740replbq {
margin:4px;}
#ygrps-yiv-59794061 #ygrps-yiv-59794061yiv7671681740 #ygrps-yiv-59794061yiv7671681740ygrp-actbar div a:first-child {
#ygrps-yiv-59794061 #ygrps-yiv-59794061yiv7671681740 #ygrps-yiv-59794061yiv7671681740ygrp-mlmsg {
#ygrps-yiv-59794061 #ygrps-yiv-59794061yiv7671681740 #ygrps-yiv-59794061yiv7671681740ygrp-mlmsg table {
#ygrps-yiv-59794061 #ygrps-yiv-59794061yiv7671681740 #ygrps-yiv-59794061yiv7671681740ygrp-mlmsg select, #ygrps-yiv-59794061 #ygrps-yiv-59794061yiv7671681740 input, #ygrps-yiv-59794061 #ygrps-yiv-59794061yiv7671681740 textarea {
#ygrps-yiv-59794061 #ygrps-yiv-59794061yiv7671681740 #ygrps-yiv-59794061yiv7671681740ygrp-mlmsg pre, #ygrps-yiv-59794061 #ygrps-yiv-59794061yiv7671681740 code {
#ygrps-yiv-59794061 #ygrps-yiv-59794061yiv7671681740 #ygrps-yiv-59794061yiv7671681740ygrp-mlmsg * {
#ygrps-yiv-59794061 #ygrps-yiv-59794061yiv7671681740 #ygrps-yiv-59794061yiv7671681740ygrp-mlmsg #ygrps-yiv-59794061yiv7671681740logo {
#ygrps-yiv-59794061 #ygrps-yiv-59794061yiv7671681740 #ygrps-yiv-59794061yiv7671681740ygrp-msg p a {
#ygrps-yiv-59794061 #ygrps-yiv-59794061yiv7671681740 #ygrps-yiv-59794061yiv7671681740ygrp-msg p#ygrps-yiv-59794061yiv7671681740attach-count span {
#ygrps-yiv-59794061 #ygrps-yiv-59794061yiv7671681740 #ygrps-yiv-59794061yiv7671681740ygrp-reco #ygrps-yiv-59794061yiv7671681740reco-head {
#ygrps-yiv-59794061 #ygrps-yiv-59794061yiv7671681740 #ygrps-yiv-59794061yiv7671681740ygrp-reco {
#ygrps-yiv-59794061 #ygrps-yiv-59794061yiv7671681740 #ygrps-yiv-59794061yiv7671681740ygrp-sponsor #ygrps-yiv-59794061yiv7671681740ov li a {
#ygrps-yiv-59794061 #ygrps-yiv-59794061yiv7671681740 #ygrps-yiv-59794061yiv7671681740ygrp-sponsor #ygrps-yiv-59794061yiv7671681740ov li {
#ygrps-yiv-59794061 #ygrps-yiv-59794061yiv7671681740 #ygrps-yiv-59794061yiv7671681740ygrp-sponsor #ygrps-yiv-59794061yiv7671681740ov ul {
#ygrps-yiv-59794061 #ygrps-yiv-59794061yiv7671681740 #ygrps-yiv-59794061yiv7671681740ygrp-text {
#ygrps-yiv-59794061 #ygrps-yiv-59794061yiv7671681740 #ygrps-yiv-59794061yiv7671681740ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-59794061 #ygrps-yiv-59794061yiv7671681740 #ygrps-yiv-59794061yiv7671681740ygrp-text tt {
font-size:120%;}
#ygrps-yiv-59794061 #ygrps-yiv-59794061yiv7671681740 #ygrps-yiv-59794061yiv7671681740ygrp-vital ul li:last-child {
#ygrps-yiv-59794061
MFG to VAR
Hi all,
thanks in advance
MFG to VAR
Hi all,
thanks in advance
#ygrps-yiv-725610323 #ygrps-yiv-725610323yiv8839976551 #ygrps-yiv-725610323yiv8839976551 -- #ygrps-yiv-725610323yiv8839976551ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}
#ygrps-yiv-725610323 #ygrps-yiv-725610323yiv8839976551 #ygrps-yiv-725610323yiv8839976551ygrp-mkp hr {
#ygrps-yiv-725610323 #ygrps-yiv-725610323yiv8839976551 #ygrps-yiv-725610323yiv8839976551ygrp-mkp #ygrps-yiv-725610323yiv8839976551hd {
#ygrps-yiv-725610323 #ygrps-yiv-725610323yiv8839976551 #ygrps-yiv-725610323yiv8839976551ygrp-mkp #ygrps-yiv-725610323yiv8839976551ads {
#ygrps-yiv-725610323 #ygrps-yiv-725610323yiv8839976551 #ygrps-yiv-725610323yiv8839976551ygrp-mkp .ygrps-yiv-725610323yiv8839976551ad {
padding:0 0;}
#ygrps-yiv-725610323 #ygrps-yiv-725610323yiv8839976551 #ygrps-yiv-725610323yiv8839976551ygrp-mkp .ygrps-yiv-725610323yiv8839976551ad p {
margin:0;}
#ygrps-yiv-725610323 #ygrps-yiv-725610323yiv8839976551 #ygrps-yiv-725610323yiv8839976551ygrp-mkp .ygrps-yiv-725610323yiv8839976551ad a {
#ygrps-yiv-725610323 #ygrps-yiv-725610323yiv8839976551 #ygrps-yiv-725610323yiv8839976551ygrp-sponsor #ygrps-yiv-725610323yiv8839976551ygrp-lc {
font-family:Arial;}
#ygrps-yiv-725610323 #ygrps-yiv-725610323yiv8839976551 #ygrps-yiv-725610323yiv8839976551ygrp-sponsor #ygrps-yiv-725610323yiv8839976551ygrp-lc #ygrps-yiv-725610323yiv8839976551hd {
#ygrps-yiv-725610323 #ygrps-yiv-725610323yiv8839976551 #ygrps-yiv-725610323yiv8839976551ygrp-sponsor #ygrps-yiv-725610323yiv8839976551ygrp-lc .ygrps-yiv-725610323yiv8839976551ad {
#ygrps-yiv-725610323 #ygrps-yiv-725610323yiv8839976551 #ygrps-yiv-725610323yiv8839976551actions {
#ygrps-yiv-725610323 #ygrps-yiv-725610323yiv8839976551 #ygrps-yiv-725610323yiv8839976551activity {
#ygrps-yiv-725610323 #ygrps-yiv-725610323yiv8839976551 #ygrps-yiv-725610323yiv8839976551activity span {
font-weight:700;}
#ygrps-yiv-725610323 #ygrps-yiv-725610323yiv8839976551 #ygrps-yiv-725610323yiv8839976551activity span:first-child {
#ygrps-yiv-725610323 #ygrps-yiv-725610323yiv8839976551 #ygrps-yiv-725610323yiv8839976551activity span a {
#ygrps-yiv-725610323 #ygrps-yiv-725610323yiv8839976551 #ygrps-yiv-725610323yiv8839976551activity span span {
color:#ff7900;}
#ygrps-yiv-725610323 #ygrps-yiv-725610323yiv8839976551 #ygrps-yiv-725610323yiv8839976551activity span .ygrps-yiv-725610323yiv8839976551underline {
#ygrps-yiv-725610323 #ygrps-yiv-725610323yiv8839976551 .ygrps-yiv-725610323yiv8839976551attach {
#ygrps-yiv-725610323 #ygrps-yiv-725610323yiv8839976551 .ygrps-yiv-725610323yiv8839976551attach div a {
#ygrps-yiv-725610323 #ygrps-yiv-725610323yiv8839976551 .ygrps-yiv-725610323yiv8839976551attach img {
#ygrps-yiv-725610323 #ygrps-yiv-725610323yiv8839976551 .ygrps-yiv-725610323yiv8839976551attach label {
#ygrps-yiv-725610323 #ygrps-yiv-725610323yiv8839976551 .ygrps-yiv-725610323yiv8839976551attach label a {
#ygrps-yiv-725610323 #ygrps-yiv-725610323yiv8839976551 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-725610323 #ygrps-yiv-725610323yiv8839976551 .ygrps-yiv-725610323yiv8839976551bold {
#ygrps-yiv-725610323 #ygrps-yiv-725610323yiv8839976551 .ygrps-yiv-725610323yiv8839976551bold a {
#ygrps-yiv-725610323 #ygrps-yiv-725610323yiv8839976551 dd.ygrps-yiv-725610323yiv8839976551last p a {
#ygrps-yiv-725610323 #ygrps-yiv-725610323yiv8839976551 dd.ygrps-yiv-725610323yiv8839976551last p span {
#ygrps-yiv-725610323 #ygrps-yiv-725610323yiv8839976551 dd.ygrps-yiv-725610323yiv8839976551last p span.ygrps-yiv-725610323yiv8839976551yshortcuts {
margin-right:0;}
#ygrps-yiv-725610323 #ygrps-yiv-725610323yiv8839976551 div.ygrps-yiv-725610323yiv8839976551attach-table div div a {
#ygrps-yiv-725610323 #ygrps-yiv-725610323yiv8839976551 div.ygrps-yiv-725610323yiv8839976551attach-table {
width:400px;}
#ygrps-yiv-725610323 #ygrps-yiv-725610323yiv8839976551 div.ygrps-yiv-725610323yiv8839976551file-title a, #ygrps-yiv-725610323 #ygrps-yiv-725610323yiv8839976551 div.ygrps-yiv-725610323yiv8839976551file-title a:active, #ygrps-yiv-725610323 #ygrps-yiv-725610323yiv8839976551 div.ygrps-yiv-725610323yiv8839976551file-title a:hover, #ygrps-yiv-725610323 #ygrps-yiv-725610323yiv8839976551 div.ygrps-yiv-725610323yiv8839976551file-title a:visited {
#ygrps-yiv-725610323 #ygrps-yiv-725610323yiv8839976551 div.ygrps-yiv-725610323yiv8839976551photo-title a, #ygrps-yiv-725610323 #ygrps-yiv-725610323yiv8839976551 div.ygrps-yiv-725610323yiv8839976551photo-title a:active, #ygrps-yiv-725610323 #ygrps-yiv-725610323yiv8839976551 div.ygrps-yiv-725610323yiv8839976551photo-title a:hover, #ygrps-yiv-725610323 #ygrps-yiv-725610323yiv8839976551 div.ygrps-yiv-725610323yiv8839976551photo-title a:visited {
#ygrps-yiv-725610323 #ygrps-yiv-725610323yiv8839976551 div#ygrps-yiv-725610323yiv8839976551ygrp-mlmsg #ygrps-yiv-725610323yiv8839976551ygrp-msg p a span.ygrps-yiv-725610323yiv8839976551yshortcuts {
#ygrps-yiv-725610323 #ygrps-yiv-725610323yiv8839976551 .ygrps-yiv-725610323yiv8839976551green {
color:#628c2a;}
#ygrps-yiv-725610323 #ygrps-yiv-725610323yiv8839976551 .ygrps-yiv-725610323yiv8839976551MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-725610323 #ygrps-yiv-725610323yiv8839976551 o {
font-size:0;}
#ygrps-yiv-725610323 #ygrps-yiv-725610323yiv8839976551 #ygrps-yiv-725610323yiv8839976551photos div {
#ygrps-yiv-725610323 #ygrps-yiv-725610323yiv8839976551 #ygrps-yiv-725610323yiv8839976551photos div div {
#ygrps-yiv-725610323 #ygrps-yiv-725610323yiv8839976551 #ygrps-yiv-725610323yiv8839976551photos div label {
#ygrps-yiv-725610323 #ygrps-yiv-725610323yiv8839976551 #ygrps-yiv-725610323yiv8839976551reco-category {
font-size:77%;}
#ygrps-yiv-725610323 #ygrps-yiv-725610323yiv8839976551 #ygrps-yiv-725610323yiv8839976551reco-desc {
font-size:77%;}
#ygrps-yiv-725610323 #ygrps-yiv-725610323yiv8839976551 .ygrps-yiv-725610323yiv8839976551replbq {
margin:4px;}
#ygrps-yiv-725610323 #ygrps-yiv-725610323yiv8839976551 #ygrps-yiv-725610323yiv8839976551ygrp-actbar div a:first-child {
#ygrps-yiv-725610323 #ygrps-yiv-725610323yiv8839976551 #ygrps-yiv-725610323yiv8839976551ygrp-mlmsg {
#ygrps-yiv-725610323 #ygrps-yiv-725610323yiv8839976551 #ygrps-yiv-725610323yiv8839976551ygrp-mlmsg table {
#ygrps-yiv-725610323 #ygrps-yiv-725610323yiv8839976551 #ygrps-yiv-725610323yiv8839976551ygrp-mlmsg select, #ygrps-yiv-725610323 #ygrps-yiv-725610323yiv8839976551 input, #ygrps-yiv-725610323 #ygrps-yiv-725610323yiv8839976551 textarea {
#ygrps-yiv-725610323 #ygrps-yiv-725610323yiv8839976551 #ygrps-yiv-725610323yiv8839976551ygrp-mlmsg pre, #ygrps-yiv-725610323 #ygrps-yiv-725610323yiv8839976551 code {
#ygrps-yiv-725610323 #ygrps-yiv-725610323yiv8839976551 #ygrps-yiv-725610323yiv8839976551ygrp-mlmsg * {
#ygrps-yiv-725610323 #ygrps-yiv-725610323yiv8839976551 #ygrps-yiv-725610323yiv8839976551ygrp-mlmsg #ygrps-yiv-725610323yiv8839976551logo {
#ygrps-yiv-725610323 #ygrps-yiv-725610323yiv8839976551 #ygrps-yiv-725610323yiv8839976551ygrp-msg p a {
#ygrps-yiv-725610323 #ygrps-yiv-725610323yiv8839976551 #ygrps-yiv-725610323yiv8839976551ygrp-msg p#ygrps-yiv-725610323yiv8839976551attach-count span {
#ygrps-yiv-725610323 #ygrps-yiv-725610323yiv8839976551 #ygrps-yiv-725610323yiv8839976551ygrp-reco #ygrps-yiv-725610323yiv8839976551reco-head {
#ygrps-yiv-725610323 #ygrps-yiv-725610323yiv8839976551 #ygrps-yiv-725610323yiv8839976551ygrp-reco {
#ygrps-yiv-725610323 #ygrps-yiv-725610323yiv8839976551 #ygrps-yiv-725610323yiv8839976551ygrp-sponsor #ygrps-yiv-725610323yiv8839976551ov li a {
#ygrps-yiv-725610323 #ygrps-yiv-725610323yiv8839976551 #ygrps-yiv-725610323yiv8839976551ygrp-sponsor #ygrps-yiv-725610323yiv8839976551ov li {
#ygrps-yiv-725610323 #ygrps-yiv-725610323yiv8839976551 #ygrps-yiv-725610323yiv8839976551ygrp-sponsor #ygrps-yiv-725610323yiv8839976551ov ul {
#ygrps-yiv-725610323 #ygrps-yiv-725610323yiv8839976551 #ygrps-yiv-725610323yiv8839976551ygrp-text {
#ygrps-yiv-725610323 #ygrps-yiv-725610323yiv8839976551 #ygrps-yiv-725610323yiv8839976551ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-725610323 #ygrps-yiv-725610323yiv8839976551 #ygrps-yiv-725610323yiv8839976551ygrp-text tt {
font-size:120%;}
#ygrps-yiv-725610323 #ygrps-yiv-725610323yiv8839976551 #ygrps-yiv-725610323yiv8839976551ygrp-vital ul li:last-child {
Josh Serwe
(920)437-6400 x 327
MFG to VAR
From: "'Cathy' cathy@...<mailto:cathy@...> [vantage]" <vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>>
To: vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>
From: vantage@yahoogroups.com<mailto:vantage@yahoogroups.com> [mailto:vantage@yahoogroups.com]
Hi all,
thanks in advance
Josh Serwe
(920)437-6400 x 327
MFG to VAR
Hi all,
thanks in advance
#ygrps-yiv-867302294 #ygrps-yiv-867302294yiv7178488996 #ygrps-yiv-867302294yiv7178488996 -- #ygrps-yiv-867302294yiv7178488996ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}
#ygrps-yiv-867302294 #ygrps-yiv-867302294yiv7178488996 #ygrps-yiv-867302294yiv7178488996ygrp-mkp hr {
#ygrps-yiv-867302294 #ygrps-yiv-867302294yiv7178488996 #ygrps-yiv-867302294yiv7178488996ygrp-mkp #ygrps-yiv-867302294yiv7178488996hd {
#ygrps-yiv-867302294 #ygrps-yiv-867302294yiv7178488996 #ygrps-yiv-867302294yiv7178488996ygrp-mkp #ygrps-yiv-867302294yiv7178488996ads {
#ygrps-yiv-867302294 #ygrps-yiv-867302294yiv7178488996 #ygrps-yiv-867302294yiv7178488996ygrp-mkp .ygrps-yiv-867302294yiv7178488996ad {
padding:0 0;}
#ygrps-yiv-867302294 #ygrps-yiv-867302294yiv7178488996 #ygrps-yiv-867302294yiv7178488996ygrp-mkp .ygrps-yiv-867302294yiv7178488996ad p {
margin:0;}
#ygrps-yiv-867302294 #ygrps-yiv-867302294yiv7178488996 #ygrps-yiv-867302294yiv7178488996ygrp-mkp .ygrps-yiv-867302294yiv7178488996ad a {
#ygrps-yiv-867302294 #ygrps-yiv-867302294yiv7178488996 #ygrps-yiv-867302294yiv7178488996ygrp-sponsor #ygrps-yiv-867302294yiv7178488996ygrp-lc {
font-family:Arial;}
#ygrps-yiv-867302294 #ygrps-yiv-867302294yiv7178488996 #ygrps-yiv-867302294yiv7178488996ygrp-sponsor #ygrps-yiv-867302294yiv7178488996ygrp-lc #ygrps-yiv-867302294yiv7178488996hd {
#ygrps-yiv-867302294 #ygrps-yiv-867302294yiv7178488996 #ygrps-yiv-867302294yiv7178488996ygrp-sponsor #ygrps-yiv-867302294yiv7178488996ygrp-lc .ygrps-yiv-867302294yiv7178488996ad {
#ygrps-yiv-867302294 #ygrps-yiv-867302294yiv7178488996 #ygrps-yiv-867302294yiv7178488996actions {
#ygrps-yiv-867302294 #ygrps-yiv-867302294yiv7178488996 #ygrps-yiv-867302294yiv7178488996activity {
#ygrps-yiv-867302294 #ygrps-yiv-867302294yiv7178488996 #ygrps-yiv-867302294yiv7178488996activity span {
font-weight:700;}
#ygrps-yiv-867302294 #ygrps-yiv-867302294yiv7178488996 #ygrps-yiv-867302294yiv7178488996activity span:first-child {
#ygrps-yiv-867302294 #ygrps-yiv-867302294yiv7178488996 #ygrps-yiv-867302294yiv7178488996activity span a {
#ygrps-yiv-867302294 #ygrps-yiv-867302294yiv7178488996 #ygrps-yiv-867302294yiv7178488996activity span span {
color:#ff7900;}
#ygrps-yiv-867302294 #ygrps-yiv-867302294yiv7178488996 #ygrps-yiv-867302294yiv7178488996activity span .ygrps-yiv-867302294yiv7178488996underline {
#ygrps-yiv-867302294 #ygrps-yiv-867302294yiv7178488996 .ygrps-yiv-867302294yiv7178488996attach {
#ygrps-yiv-867302294 #ygrps-yiv-867302294yiv7178488996 .ygrps-yiv-867302294yiv7178488996attach div a {
#ygrps-yiv-867302294 #ygrps-yiv-867302294yiv7178488996 .ygrps-yiv-867302294yiv7178488996attach img {
#ygrps-yiv-867302294 #ygrps-yiv-867302294yiv7178488996 .ygrps-yiv-867302294yiv7178488996attach label {
#ygrps-yiv-867302294 #ygrps-yiv-867302294yiv7178488996 .ygrps-yiv-867302294yiv7178488996attach label a {
#ygrps-yiv-867302294 #ygrps-yiv-867302294yiv7178488996 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-867302294 #ygrps-yiv-867302294yiv7178488996 .ygrps-yiv-867302294yiv7178488996bold {
#ygrps-yiv-867302294 #ygrps-yiv-867302294yiv7178488996 .ygrps-yiv-867302294yiv7178488996bold a {
#ygrps-yiv-867302294 #ygrps-yiv-867302294yiv7178488996 dd.ygrps-yiv-867302294yiv7178488996last p a {
#ygrps-yiv-867302294 #ygrps-yiv-867302294yiv7178488996 dd.ygrps-yiv-867302294yiv7178488996last p span {
#ygrps-yiv-867302294 #ygrps-yiv-867302294yiv7178488996 dd.ygrps-yiv-867302294yiv7178488996last p span.ygrps-yiv-867302294yiv7178488996yshortcuts {
margin-right:0;}
#ygrps-yiv-867302294 #ygrps-yiv-867302294yiv7178488996 div.ygrps-yiv-867302294yiv7178488996attach-table div div a {
#ygrps-yiv-867302294 #ygrps-yiv-867302294yiv7178488996 div.ygrps-yiv-867302294yiv7178488996attach-table {
width:400px;}
#ygrps-yiv-867302294 #ygrps-yiv-867302294yiv7178488996 div.ygrps-yiv-867302294yiv7178488996file-title a, #ygrps-yiv-867302294 #ygrps-yiv-867302294yiv7178488996 div.ygrps-yiv-867302294yiv7178488996file-title a:active, #ygrps-yiv-867302294 #ygrps-yiv-867302294yiv7178488996 div.ygrps-yiv-867302294yiv7178488996file-title a:hover, #ygrps-yiv-867302294 #ygrps-yiv-867302294yiv7178488996 div.ygrps-yiv-867302294yiv7178488996file-title a:visited {
#ygrps-yiv-867302294 #ygrps-yiv-867302294yiv7178488996 div.ygrps-yiv-867302294yiv7178488996photo-title a, #ygrps-yiv-867302294 #ygrps-yiv-867302294yiv7178488996 div.ygrps-yiv-867302294yiv7178488996photo-title a:active, #ygrps-yiv-867302294 #ygrps-yiv-867302294yiv7178488996 div.ygrps-yiv-867302294yiv7178488996photo-title a:hover, #ygrps-yiv-867302294 #ygrps-yiv-867302294yiv7178488996 div.ygrps-yiv-867302294yiv7178488996photo-title a:visited {
#ygrps-yiv-867302294 #ygrps-yiv-867302294yiv7178488996 div#ygrps-yiv-867302294yiv7178488996ygrp-mlmsg #ygrps-yiv-867302294yiv7178488996ygrp-msg p a span.ygrps-yiv-867302294yiv7178488996yshortcuts {
#ygrps-yiv-867302294 #ygrps-yiv-867302294yiv7178488996 .ygrps-yiv-867302294yiv7178488996green {
color:#628c2a;}
#ygrps-yiv-867302294 #ygrps-yiv-867302294yiv7178488996 .ygrps-yiv-867302294yiv7178488996MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-867302294 #ygrps-yiv-867302294yiv7178488996 o {
font-size:0;}
#ygrps-yiv-867302294 #ygrps-yiv-867302294yiv7178488996 #ygrps-yiv-867302294yiv7178488996photos div {
#ygrps-yiv-867302294 #ygrps-yiv-867302294yiv7178488996 #ygrps-yiv-867302294yiv7178488996photos div div {
#ygrps-yiv-867302294 #ygrps-yiv-867302294yiv7178488996 #ygrps-yiv-867302294yiv7178488996photos div label {
#ygrps-yiv-867302294 #ygrps-yiv-867302294yiv7178488996 #ygrps-yiv-867302294yiv7178488996reco-category {
font-size:77%;}
#ygrps-yiv-867302294 #ygrps-yiv-867302294yiv7178488996 #ygrps-yiv-867302294yiv7178488996reco-desc {
font-size:77%;}
#ygrps-yiv-867302294 #ygrps-yiv-867302294yiv7178488996 .ygrps-yiv-867302294yiv7178488996replbq {
margin:4px;}
#ygrps-yiv-867302294 #ygrps-yiv-867302294yiv7178488996 #ygrps-yiv-867302294yiv7178488996ygrp-actbar div a:first-child {
#ygrps-yiv-867302294 #ygrps-yiv-867302294yiv7178488996 #ygrps-yiv-867302294yiv7178488996ygrp-mlmsg {
#ygrps-yiv-867302294 #ygrps-yiv-867302294yiv7178488996 #ygrps-yiv-867302294yiv7178488996ygrp-mlmsg table {
#ygrps-yiv-867302294 #ygrps-yiv-867302294yiv7178488996 #ygrps-yiv-867302294yiv7178488996ygrp-mlmsg select, #ygrps-yiv-867302294 #ygrps-yiv-867302294yiv7178488996 input, #ygrps-yiv-867302294 #ygrps-yiv-867302294yiv7178488996 textarea {
#ygrps-yiv-867302294 #ygrps-yiv-867302294yiv7178488996 #ygrps-yiv-867302294yiv7178488996ygrp-mlmsg pre, #ygrps-yiv-867302294 #ygrps-yiv-867302294yiv7178488996 code {
#ygrps-yiv-867302294 #ygrps-yiv-867302294yiv7178488996 #ygrps-yiv-867302294yiv7178488996ygrp-mlmsg * {
#ygrps-yiv-867302294 #ygrps-yiv-867302294yiv7178488996 #ygrps-yiv-867302294yiv7178488996ygrp-mlmsg #ygrps-yiv-867302294yiv7178488996logo {
#ygrps-yiv-867302294 #ygrps-yiv-867302294yiv7178488996 #ygrps-yiv-867302294yiv7178488996ygrp-msg p a {
#ygrps-yiv-867302294 #ygrps-yiv-867302294yiv7178488996 #ygrps-yiv-867302294yiv7178488996ygrp-msg p#ygrps-yiv-867302294yiv7178488996attach-count span {
#ygrps-yiv-867302294 #ygrps-yiv-867302294yiv7178488996 #ygrps-yiv-867302294yiv7178488996ygrp-reco #ygrps-yiv-867302294yiv7178488996reco-head {
#ygrps-yiv-867302294 #ygrps-yiv-867302294yiv7178488996 #ygrps-yiv-867302294yiv7178488996ygrp-reco {
#ygrps-yiv-867302294 #ygrps-yiv-867302294yiv7178488996 #ygrps-yiv-867302294yiv7178488996ygrp-sponsor #ygrps-yiv-867302294yiv7178488996ov li a {
#ygrps-yiv-867302294 #ygrps-yiv-867302294yiv7178488996 #ygrps-yiv-867302294yiv7178488996ygrp-sponsor #ygrps-yiv-867302294yiv7178488996ov li {
#ygrps-yiv-867302294 #ygrps-yiv-867302294yiv7178488996 #ygrps-yiv-867302294yiv7178488996ygrp-sponsor #ygrps-yiv-867302294yiv7178488996ov ul {
#ygrps-yiv-867302294 #ygrps-yiv-867302294yiv7178488996 #ygrps-yiv-867302294yiv7178488996ygrp-text {
#ygrps-yiv-867302294 #ygrps-yiv-867302294yiv7178488996 #ygrps-yiv-867302294yiv7178488996ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-867302294 #ygrps-yiv-867302294yiv7178488996 #ygrps-yiv-867302294yiv7178488996ygrp-text tt {
font-size:120%;}
#ygrps-yiv-867302294 #ygrps-yiv-867302294yiv7178488996 #ygrps-yiv-867302294yiv7178488996ygrp-vital ul li:last-child {
Josh Serwe
(920)437-6400 x 327
MFG to VAR
Hi all,
thanks in advance
Cathy,
Day 1:  .09
Day 2:  .03
Day 3:  .09
same qty each day.
Josh Serwe
(920)437-6400 x 327
MFG to VAR
Hi all,
thanks in advance
#ygrps-yiv-1058467479 #ygrps-yiv-1058467479yiv7424049187 #ygrps-yiv-1058467479yiv7424049187 -- #ygrps-yiv-1058467479yiv7424049187ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}
#ygrps-yiv-1058467479 #ygrps-yiv-1058467479yiv7424049187 #ygrps-yiv-1058467479yiv7424049187ygrp-mkp hr {
#ygrps-yiv-1058467479 #ygrps-yiv-1058467479yiv7424049187 #ygrps-yiv-1058467479yiv7424049187ygrp-mkp #ygrps-yiv-1058467479yiv7424049187hd {
#ygrps-yiv-1058467479 #ygrps-yiv-1058467479yiv7424049187 #ygrps-yiv-1058467479yiv7424049187ygrp-mkp #ygrps-yiv-1058467479yiv7424049187ads {
#ygrps-yiv-1058467479 #ygrps-yiv-1058467479yiv7424049187 #ygrps-yiv-1058467479yiv7424049187ygrp-mkp .ygrps-yiv-1058467479yiv7424049187ad {
padding:0 0;}
#ygrps-yiv-1058467479 #ygrps-yiv-1058467479yiv7424049187 #ygrps-yiv-1058467479yiv7424049187ygrp-mkp .ygrps-yiv-1058467479yiv7424049187ad p {
margin:0;}
#ygrps-yiv-1058467479 #ygrps-yiv-1058467479yiv7424049187 #ygrps-yiv-1058467479yiv7424049187ygrp-mkp .ygrps-yiv-1058467479yiv7424049187ad a {
#ygrps-yiv-1058467479 #ygrps-yiv-1058467479yiv7424049187 #ygrps-yiv-1058467479yiv7424049187ygrp-sponsor #ygrps-yiv-1058467479yiv7424049187ygrp-lc {
font-family:Arial;}
#ygrps-yiv-1058467479 #ygrps-yiv-1058467479yiv7424049187 #ygrps-yiv-1058467479yiv7424049187ygrp-sponsor #ygrps-yiv-1058467479yiv7424049187ygrp-lc #ygrps-yiv-1058467479yiv7424049187hd {
#ygrps-yiv-1058467479 #ygrps-yiv-1058467479yiv7424049187 #ygrps-yiv-1058467479yiv7424049187ygrp-sponsor #ygrps-yiv-1058467479yiv7424049187ygrp-lc .ygrps-yiv-1058467479yiv7424049187ad {
#ygrps-yiv-1058467479 #ygrps-yiv-1058467479yiv7424049187 #ygrps-yiv-1058467479yiv7424049187actions {
#ygrps-yiv-1058467479 #ygrps-yiv-1058467479yiv7424049187 #ygrps-yiv-1058467479yiv7424049187activity {
#ygrps-yiv-1058467479 #ygrps-yiv-1058467479yiv7424049187 #ygrps-yiv-1058467479yiv7424049187activity span {
font-weight:700;}
#ygrps-yiv-1058467479 #ygrps-yiv-1058467479yiv7424049187 #ygrps-yiv-1058467479yiv7424049187activity span:first-child {
#ygrps-yiv-1058467479 #ygrps-yiv-1058467479yiv7424049187 #ygrps-yiv-1058467479yiv7424049187activity span a {
#ygrps-yiv-1058467479 #ygrps-yiv-1058467479yiv7424049187 #ygrps-yiv-1058467479yiv7424049187activity span span {
color:#ff7900;}
#ygrps-yiv-1058467479 #ygrps-yiv-1058467479yiv7424049187 #ygrps-yiv-1058467479yiv7424049187activity span .ygrps-yiv-1058467479yiv7424049187underline {
#ygrps-yiv-1058467479 #ygrps-yiv-1058467479yiv7424049187 .ygrps-yiv-1058467479yiv7424049187attach {
#ygrps-yiv-1058467479 #ygrps-yiv-1058467479yiv7424049187 .ygrps-yiv-1058467479yiv7424049187attach div a {
#ygrps-yiv-1058467479 #ygrps-yiv-1058467479yiv7424049187 .ygrps-yiv-1058467479yiv7424049187attach img {
#ygrps-yiv-1058467479 #ygrps-yiv-1058467479yiv7424049187 .ygrps-yiv-1058467479yiv7424049187attach label {
#ygrps-yiv-1058467479 #ygrps-yiv-1058467479yiv7424049187 .ygrps-yiv-1058467479yiv7424049187attach label a {
#ygrps-yiv-1058467479 #ygrps-yiv-1058467479yiv7424049187 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-1058467479 #ygrps-yiv-1058467479yiv7424049187 .ygrps-yiv-1058467479yiv7424049187bold {
#ygrps-yiv-1058467479 #ygrps-yiv-1058467479yiv7424049187 .ygrps-yiv-1058467479yiv7424049187bold a {
#ygrps-yiv-1058467479 #ygrps-yiv-1058467479yiv7424049187 dd.ygrps-yiv-1058467479yiv7424049187last p a {
#ygrps-yiv-1058467479 #ygrps-yiv-1058467479yiv7424049187 dd.ygrps-yiv-1058467479yiv7424049187last p span {
#ygrps-yiv-1058467479 #ygrps-yiv-1058467479yiv7424049187 dd.ygrps-yiv-1058467479yiv7424049187last p span.ygrps-yiv-1058467479yiv7424049187yshortcuts {
margin-right:0;}
#ygrps-yiv-1058467479 #ygrps-yiv-1058467479yiv7424049187 div.ygrps-yiv-1058467479yiv7424049187attach-table div div a {
#ygrps-yiv-1058467479 #ygrps-yiv-1058467479yiv7424049187 div.ygrps-yiv-1058467479yiv7424049187attach-table {
width:400px;}
#ygrps-yiv-1058467479 #ygrps-yiv-1058467479yiv7424049187 div.ygrps-yiv-1058467479yiv7424049187file-title a, #ygrps-yiv-1058467479 #ygrps-yiv-1058467479yiv7424049187 div.ygrps-yiv-1058467479yiv7424049187file-title a:active, #ygrps-yiv-1058467479 #ygrps-yiv-1058467479yiv7424049187 div.ygrps-yiv-1058467479yiv7424049187file-title a:hover, #ygrps-yiv-1058467479 #ygrps-yiv-1058467479yiv7424049187 div.ygrps-yiv-1058467479yiv7424049187file-title a:visited {
#ygrps-yiv-1058467479 #ygrps-yiv-1058467479yiv7424049187 div.ygrps-yiv-1058467479yiv7424049187photo-title a, #ygrps-yiv-1058467479 #ygrps-yiv-1058467479yiv7424049187 div.ygrps-yiv-1058467479yiv7424049187photo-title a:active, #ygrps-yiv-1058467479 #ygrps-yiv-1058467479yiv7424049187 div.ygrps-yiv-1058467479yiv7424049187photo-title a:hover, #ygrps-yiv-1058467479 #ygrps-yiv-1058467479yiv7424049187 div.ygrps-yiv-1058467479yiv7424049187photo-title a:visited {
#ygrps-yiv-1058467479 #ygrps-yiv-1058467479yiv7424049187 div#ygrps-yiv-1058467479yiv7424049187ygrp-mlmsg #ygrps-yiv-1058467479yiv7424049187ygrp-msg p a span.ygrps-yiv-1058467479yiv7424049187yshortcuts {
#ygrps-yiv-1058467479 #ygrps-yiv-1058467479yiv7424049187 .ygrps-yiv-1058467479yiv7424049187green {
color:#628c2a;}
#ygrps-yiv-1058467479 #ygrps-yiv-1058467479yiv7424049187 .ygrps-yiv-1058467479yiv7424049187MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-1058467479 #ygrps-yiv-1058467479yiv7424049187 o {
font-size:0;}
#ygrps-yiv-1058467479 #ygrps-yiv-1058467479yiv7424049187 #ygrps-yiv-1058467479yiv7424049187photos div {
#ygrps-yiv-1058467479 #ygrps-yiv-1058467479yiv7424049187 #ygrps-yiv-1058467479yiv7424049187photos div div {
#ygrps-yiv-1058467479 #ygrps-yiv-1058467479yiv7424049187 #ygrps-yiv-1058467479yiv7424049187photos div label {
#ygrps-yiv-1058467479 #ygrps-yiv-1058467479yiv7424049187 #ygrps-yiv-1058467479yiv7424049187reco-category {
font-size:77%;}
#ygrps-yiv-1058467479 #ygrps-yiv-1058467479yiv7424049187 #ygrps-yiv-1058467479yiv7424049187reco-desc {
font-size:77%;}
#ygrps-yiv-1058467479 #ygrps-yiv-1058467479yiv7424049187 .ygrps-yiv-1058467479yiv7424049187replbq {
margin:4px;}
#ygrps-yiv-1058467479 #ygrps-yiv-1058467479yiv7424049187 #ygrps-yiv-1058467479yiv7424049187ygrp-actbar div a:first-child {
#ygrps-yiv-1058467479 #ygrps-yiv-1058467479yiv7424049187 #ygrps-yiv-1058467479yiv7424049187ygrp-mlmsg {
#ygrps-yiv-1058467479 #ygrps-yiv-1058467479yiv7424049187 #ygrps-yiv-1058467479yiv7424049187ygrp-mlmsg table {
#ygrps-yiv-1058467479 #ygrps-yiv-1058467479yiv7424049187 #ygrps-yiv-1058467479yiv7424049187ygrp-mlmsg select, #ygrps-yiv-1058467479 #ygrps-yiv-1058467479yiv7424049187 input, #ygrps-yiv-1058467479 #ygrps-yiv-1058467479yiv7424049187 textarea {
#ygrps-yiv-1058467479 #ygrps-yiv-1058467479yiv7424049187 #ygrps-yiv-1058467479yiv7424049187ygrp-mlmsg pre, #ygrps-yiv-1058467479 #ygrps-yiv-1058467479yiv7424049187 code {
#ygrps-yiv-1058467479 #ygrps-yiv-1058467479yiv7424049187 #ygrps-yiv-1058467479yiv7424049187ygrp-mlmsg * {
#ygrps-yiv-1058467479 #ygrps-yiv-1058467479yiv7424049187 #ygrps-yiv-1058467479yiv7424049187ygrp-mlmsg #ygrps-yiv-1058467479yiv7424049187logo {
#ygrps-yiv-1058467479 #ygrps-yiv-1058467479yiv7424049187 #ygrps-yiv-1058467479yiv7424049187ygrp-msg p a {
#ygrps-yiv-1058467479 #ygrps-yiv-1058467479yiv7424049187 #ygrps-yiv-1058467479yiv7424049187ygrp-msg p#ygrps-yiv-1058467479yiv7424049187attach-count span {
#ygrps-yiv-1058467479 #ygrps-yiv-1058467479yiv7424049187 #ygrps-yiv-1058467479yiv7424049187ygrp-reco #ygrps-yiv-1058467479yiv7424049187reco-head {
#ygrps-yiv-1058467479 #ygrps-yiv-1058467479yiv7424049187 #ygrps-yiv-1058467479yiv7424049187ygrp-reco {
#ygrps-yiv-1058467479 #ygrps-yiv-1058467479yiv7424049187 #ygrps-yiv-1058467479yiv7424049187ygrp-sponsor #ygrps-yiv-1058467479yiv7424049187ov li a {
#ygrps-yiv-1058467479 #ygrps-yiv-1058467479yiv7424049187 #ygrps-yiv-1058467479yiv7424049187ygrp-sponsor #ygrps-yiv-1058467479yiv7424049187ov li {
#ygrps-yiv-1058467479 #ygrps-yiv-1058467479yiv7424049187 #ygrps-yiv-1058467479yiv7424049187ygrp-sponsor #ygrps-yiv-1058467479yiv7424049187ov ul {
#ygrps-yiv-1058467479 #ygrps-yiv-1058467479yiv7424049187 #ygrps-yiv-1058467479yiv7424049187ygrp-text {
#ygrps-yiv-1058467479 #ygrps-yiv-1058467479yiv7424049187 #ygrps-yiv-1058467479yiv7424049187ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-1058467479 #ygrps-yiv-1058467479yiv7424049187 #ygrps-yiv-1058467479yiv7424049187ygrp-text tt {
font-size:120%;}
#ygrps-yiv-1058467479 #ygrps-yiv-1058467479yiv7424049187 #ygrps-yiv-1058467479yiv7424049187ygrp-vital ul li:last-child {
Josh Serwe
(920)437-6400 x 327
Cathy,
Day 1: .09
Day 2: .03
Day 3: .09
same qty each day.
From: "Joshua Serwe jserwe@...<mailto:jserwe@...> [vantage]" <vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>>
To: "vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>" <vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>>
Josh Serwe
(920)437-6400 x 327
MFG to VAR
Hi all,
thanks in advance
Thanks for the help
Josh Serwe
(920)437-6400 x 327
Cathy,
Day 1: .09
Day 2: .03
Day 3: .09
same qty each day.
Josh Serwe
(920)437-6400 x 327
MFG to VAR
Hi all,
thanks in advance
#ygrps-yiv-1353175192 #ygrps-yiv-1353175192yiv9584664363 #ygrps-yiv-1353175192yiv9584664363 -- #ygrps-yiv-1353175192yiv9584664363ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}
#ygrps-yiv-1353175192 #ygrps-yiv-1353175192yiv9584664363 #ygrps-yiv-1353175192yiv9584664363ygrp-mkp hr {
#ygrps-yiv-1353175192 #ygrps-yiv-1353175192yiv9584664363 #ygrps-yiv-1353175192yiv9584664363ygrp-mkp #ygrps-yiv-1353175192yiv9584664363hd {
#ygrps-yiv-1353175192 #ygrps-yiv-1353175192yiv9584664363 #ygrps-yiv-1353175192yiv9584664363ygrp-mkp #ygrps-yiv-1353175192yiv9584664363ads {
#ygrps-yiv-1353175192 #ygrps-yiv-1353175192yiv9584664363 #ygrps-yiv-1353175192yiv9584664363ygrp-mkp .ygrps-yiv-1353175192yiv9584664363ad {
padding:0 0;}
#ygrps-yiv-1353175192 #ygrps-yiv-1353175192yiv9584664363 #ygrps-yiv-1353175192yiv9584664363ygrp-mkp .ygrps-yiv-1353175192yiv9584664363ad p {
margin:0;}
#ygrps-yiv-1353175192 #ygrps-yiv-1353175192yiv9584664363 #ygrps-yiv-1353175192yiv9584664363ygrp-mkp .ygrps-yiv-1353175192yiv9584664363ad a {
#ygrps-yiv-1353175192 #ygrps-yiv-1353175192yiv9584664363 #ygrps-yiv-1353175192yiv9584664363ygrp-sponsor #ygrps-yiv-1353175192yiv9584664363ygrp-lc {
font-family:Arial;}
#ygrps-yiv-1353175192 #ygrps-yiv-1353175192yiv9584664363 #ygrps-yiv-1353175192yiv9584664363ygrp-sponsor #ygrps-yiv-1353175192yiv9584664363ygrp-lc #ygrps-yiv-1353175192yiv9584664363hd {
#ygrps-yiv-1353175192 #ygrps-yiv-1353175192yiv9584664363 #ygrps-yiv-1353175192yiv9584664363ygrp-sponsor #ygrps-yiv-1353175192yiv9584664363ygrp-lc .ygrps-yiv-1353175192yiv9584664363ad {
#ygrps-yiv-1353175192 #ygrps-yiv-1353175192yiv9584664363 #ygrps-yiv-1353175192yiv9584664363actions {
#ygrps-yiv-1353175192 #ygrps-yiv-1353175192yiv9584664363 #ygrps-yiv-1353175192yiv9584664363activity {
#ygrps-yiv-1353175192 #ygrps-yiv-1353175192yiv9584664363 #ygrps-yiv-1353175192yiv9584664363activity span {
font-weight:700;}
#ygrps-yiv-1353175192 #ygrps-yiv-1353175192yiv9584664363 #ygrps-yiv-1353175192yiv9584664363activity span:first-child {
#ygrps-yiv-1353175192 #ygrps-yiv-1353175192yiv9584664363 #ygrps-yiv-1353175192yiv9584664363activity span a {
#ygrps-yiv-1353175192 #ygrps-yiv-1353175192yiv9584664363 #ygrps-yiv-1353175192yiv9584664363activity span span {
color:#ff7900;}
#ygrps-yiv-1353175192 #ygrps-yiv-1353175192yiv9584664363 #ygrps-yiv-1353175192yiv9584664363activity span .ygrps-yiv-1353175192yiv9584664363underline {
#ygrps-yiv-1353175192 #ygrps-yiv-1353175192yiv9584664363 .ygrps-yiv-1353175192yiv9584664363attach {
#ygrps-yiv-1353175192 #ygrps-yiv-1353175192yiv9584664363 .ygrps-yiv-1353175192yiv9584664363attach div a {
#ygrps-yiv-1353175192 #ygrps-yiv-1353175192yiv9584664363 .ygrps-yiv-1353175192yiv9584664363attach img {
#ygrps-yiv-1353175192 #ygrps-yiv-1353175192yiv9584664363 .ygrps-yiv-1353175192yiv9584664363attach label {
#ygrps-yiv-1353175192 #ygrps-yiv-1353175192yiv9584664363 .ygrps-yiv-1353175192yiv9584664363attach label a {
#ygrps-yiv-1353175192 #ygrps-yiv-1353175192yiv9584664363 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-1353175192 #ygrps-yiv-1353175192yiv9584664363 .ygrps-yiv-1353175192yiv9584664363bold {
#ygrps-yiv-1353175192 #ygrps-yiv-1353175192yiv9584664363 .ygrps-yiv-1353175192yiv9584664363bold a {
#ygrps-yiv-1353175192 #ygrps-yiv-1353175192yiv9584664363 dd.ygrps-yiv-1353175192yiv9584664363last p a {
#ygrps-yiv-1353175192 #ygrps-yiv-1353175192yiv9584664363 dd.ygrps-yiv-1353175192yiv9584664363last p span {
#ygrps-yiv-1353175192 #ygrps-yiv-1353175192yiv9584664363 dd.ygrps-yiv-1353175192yiv9584664363last p span.ygrps-yiv-1353175192yiv9584664363yshortcuts {
margin-right:0;}
#ygrps-yiv-1353175192 #ygrps-yiv-1353175192yiv9584664363 div.ygrps-yiv-1353175192yiv9584664363attach-table div div a {
#ygrps-yiv-1353175192 #ygrps-yiv-1353175192yiv9584664363 div.ygrps-yiv-1353175192yiv9584664363attach-table {
width:400px;}
#ygrps-yiv-1353175192 #ygrps-yiv-1353175192yiv9584664363 div.ygrps-yiv-1353175192yiv9584664363file-title a, #ygrps-yiv-1353175192 #ygrps-yiv-1353175192yiv9584664363 div.ygrps-yiv-1353175192yiv9584664363file-title a:active, #ygrps-yiv-1353175192 #ygrps-yiv-1353175192yiv9584664363 div.ygrps-yiv-1353175192yiv9584664363file-title a:hover, #ygrps-yiv-1353175192 #ygrps-yiv-1353175192yiv9584664363 div.ygrps-yiv-1353175192yiv9584664363file-title a:visited {
#ygrps-yiv-1353175192 #ygrps-yiv-1353175192yiv9584664363 div.ygrps-yiv-1353175192yiv9584664363photo-title a, #ygrps-yiv-1353175192 #ygrps-yiv-1353175192yiv9584664363 div.ygrps-yiv-1353175192yiv9584664363photo-title a:active, #ygrps-yiv-1353175192 #ygrps-yiv-1353175192yiv9584664363 div.ygrps-yiv-1353175192yiv9584664363photo-title a:hover, #ygrps-yiv-1353175192 #ygrps-yiv-1353175192yiv9584664363 div.ygrps-yiv-1353175192yiv9584664363photo-title a:visited {
#ygrps-yiv-1353175192 #ygrps-yiv-1353175192yiv9584664363 div#ygrps-yiv-1353175192yiv9584664363ygrp-mlmsg #ygrps-yiv-1353175192yiv9584664363ygrp-msg p a span.ygrps-yiv-1353175192yiv9584664363yshortcuts {
#ygrps-yiv-1353175192 #ygrps-yiv-1353175192yiv9584664363 .ygrps-yiv-1353175192yiv9584664363green {
color:#628c2a;}
#ygrps-yiv-1353175192 #ygrps-yiv-1353175192yiv9584664363 .ygrps-yiv-1353175192yiv9584664363MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-1353175192 #ygrps-yiv-1353175192yiv9584664363 o {
font-size:0;}
#ygrps-yiv-1353175192 #ygrps-yiv-1353175192yiv9584664363 #ygrps-yiv-1353175192yiv9584664363photos div {
#ygrps-yiv-1353175192 #ygrps-yiv-1353175192yiv9584664363 #ygrps-yiv-1353175192yiv9584664363photos div div {
#ygrps-yiv-1353175192 #ygrps-yiv-1353175192yiv9584664363 #ygrps-yiv-1353175192yiv9584664363photos div label {
#ygrps-yiv-1353175192 #ygrps-yiv-1353175192yiv9584664363 #ygrps-yiv-1353175192yiv9584664363reco-category {
font-size:77%;}
#ygrps-yiv-1353175192 #ygrps-yiv-1353175192yiv9584664363 #ygrps-yiv-1353175192yiv9584664363reco-desc {
font-size:77%;}
#ygrps-yiv-1353175192 #ygrps-yiv-1353175192yiv9584664363 .ygrps-yiv-1353175192yiv9584664363replbq {
margin:4px;}
#ygrps-yiv-1353175192 #ygrps-yiv-1353175192yiv9584664363 #ygrps-yiv-1353175192yiv9584664363ygrp-actbar div a:first-child {
#ygrps-yiv-1353175192 #ygrps-yiv-1353175192yiv9584664363 #ygrps-yiv-1353175192yiv9584664363ygrp-mlmsg {
#ygrps-yiv-1353175192 #ygrps-yiv-1353175192yiv9584664363 #ygrps-yiv-1353175192yiv9584664363ygrp-mlmsg table {
#ygrps-yiv-1353175192 #ygrps-yiv-1353175192yiv9584664363 #ygrps-yiv-1353175192yiv9584664363ygrp-mlmsg select, #ygrps-yiv-1353175192 #ygrps-yiv-1353175192yiv9584664363 input, #ygrps-yiv-1353175192 #ygrps-yiv-1353175192yiv9584664363 textarea {
#ygrps-yiv-1353175192 #ygrps-yiv-1353175192yiv9584664363 #ygrps-yiv-1353175192yiv9584664363ygrp-mlmsg pre, #ygrps-yiv-1353175192 #ygrps-yiv-1353175192yiv9584664363 code {
#ygrps-yiv-1353175192 #ygrps-yiv-1353175192yiv9584664363 #ygrps-yiv-1353175192yiv9584664363ygrp-mlmsg * {
#ygrps-yiv-1353175192 #ygrps-yiv-1353175192yiv9584664363 #ygrps-yiv-1353175192yiv9584664363ygrp-mlmsg #ygrps-yiv-1353175192yiv9584664363logo {
#ygrps-yiv-1353175192 #ygrps-yiv-1353175192yiv9584664363 #ygrps-yiv-1353175192yiv9584664363ygrp-msg p a {
#ygrps-yiv-1353175192 #ygrps-yiv-1353175192yiv9584664363 #ygrps-yiv-1353175192yiv9584664363ygrp-msg p#ygrps-yiv-1353175192yiv9584664363attach-count span {
#ygrps-yiv-1353175192 #ygrps-yiv-1353175192yiv9584664363 #ygrps-yiv-1353175192yiv9584664363ygrp-reco #ygrps-yiv-1353175192yiv9584664363reco-head {
#ygrps-yiv-1353175192 #ygrps-yiv-1353175192yiv9584664363 #ygrps-yiv-1353175192yiv9584664363ygrp-reco {
#ygrps-yiv-1353175192 #ygrps-yiv-1353175192yiv9584664363 #ygrps-yiv-1353175192yiv9584664363ygrp-sponsor #ygrps-yiv-1353175192yiv9584664363ov li a {
#ygrps-yiv-1353175192 #ygrps-yiv-1353175192yiv9584664363 #ygrps-yiv-1353175192yiv9584664363ygrp-sponsor #ygrps-yiv-1353175192yiv9584664363ov li {
#ygrps-yiv-1353175192 #ygrps-yiv-1353175192yiv9584664363 #ygrps-yiv-1353175192yiv9584664363ygrp-sponsor #ygrps-yiv-1353175192yiv9584664363ov ul {
#ygrps-yiv-1353175192 #ygrps-yiv-1353175192yiv9584664363 #ygrps-yiv-1353175192yiv9584664363ygrp-text {
#ygrps-yiv-1353175192 #ygrps-yiv-1353175192yiv9584664363 #ygrps-yiv-1353175192yiv9584664363ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-1353175192 #ygrps-yiv-1353175192yiv9584664363 #ygrps-yiv-1353175192yiv9584664363ygrp-text tt {
font-size:120%;}
#ygrps-yiv-1353175192 #ygrps-yiv-1353175192yiv9584664363 #ygrps-yiv-1353175192yiv9584664363ygrp-vital ul li:last-child {
Thanks for the help
Josh Serwe
(920)437-6400 x 327
Cathy,
Day 1: .09
Day 2: .03
Day 3: .09
same qty each day.
Josh Serwe
(920)437-6400 x 327
MFG to VAR
Hi all,
thanks in advance
