Hello all, I am having a really hard time getting 10.2.200 running on 32-bit Windows 7 machines. They are running .NET 4.7.2 and nearly all of them get the same application event log error. I am logging in as a domain admin so do not suspect any rights issues. Just wondering if there are any known issues or incompatibilities between 32-bit Win 7 / .NET 4.7 / E10.
Matt
Faulting application name: Epicor.exe, version: 3.2.200.0, time stamp: 0x5aa01345
Faulting module name: KERNELBASE.dll, version: 6.1.7601.24335, time stamp: 0x5c267ec8
Exception code: 0xe0434352
Fault offset: 0x0000845d
Faulting process id: 0x8f4
Faulting application start time: 0x01d4bd7ced98bca9
Faulting application path: C:\Epicor\ERP10.2Client\Client\Epicor.exe
Faulting module path: C:\Windows\system32\KERNELBASE.dll
Report Id: 2b77438d-2970-11e9-b74f-ac162d05744c
which is accompanied by this .net runtime error:
Application: Epicor.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.Runtime.InteropServices.COMException
at System.BaseConfigHandler.RunParser(System.String)
at System.ConfigTreeParser.Parse(System.String, System.String, Boolean)
Exception Info: System.ApplicationException
at System.Security.Cryptography.CryptoConfig.OpenCryptoConfig()
at System.Security.Cryptography.CryptoConfig.InitializeConfigInfo()
at System.Security.Cryptography.CryptoConfig.CreateFromName(System.String, System.Object[])
at System.Security.Cryptography.RandomNumberGenerator.Create()
at System.MarvinHash.GenerateSeed()
at System.MarvinHash…cctor()
Exception Info: System.TypeInitializationException
at System.Xml.NameTable…ctor()
at System.Configuration.XmlUtil…ctor(System.IO.Stream, System.String, Boolean, System.Configuration.ConfigurationSchemaErrors)
at System.Configuration.BaseConfigurationRecord.InitConfigFromFile()
Exception Info: System.Configuration.ConfigurationErrorsException
at System.Configuration.ConfigurationSchemaErrors.ThrowIfErrors(Boolean)
at System.Configuration.BaseConfigurationRecord.ThrowIfParseErrors(System.Configuration.ConfigurationSchemaErrors)
at System.Configuration.BaseConfigurationRecord.ThrowIfInitErrors()
at System.Configuration.ClientConfigurationSystem.EnsureInit(System.String)
at System.Configuration.ClientConfigurationSystem.PrepareClientConfigSystem(System.String)
at System.Configuration.ClientConfigurationSystem.System.Configuration.Internal.IInternalConfigSystem.GetSection(System.String)
at System.Configuration.ConfigurationManager.get_AppSettings()
at Epicor.ServiceModel.Trace.ClientTracing.UserTracer…cctor()
at Epicor.ServiceModel.Trace.ClientTracing.UserTracer.get_DialogException()
at Ice.Lib.Epicor.Main(System.String[])
