Hello,
my client will move to epicor kinetic cloud very soon.
my question is if it is possible to set up a linked server in the sql server to connect the cloud database.
our salesforce has this feature to setup a linked server and connect to the cloud database. I want to know if Epicor can do that too. if so, can you please show me how to do it.
You can NOT link to your production server. Period. Itās just not secure. You CAN have a replicated server that they give some access to. Your CAM will have details.
As Olga noted, this is the address of the Application Server, not the database server.
There is nothing inherently insecure about SQL Server on prem or SQL Server/Azure SQL in the cloud. Would you expose your on-prem SQL Server directly to the Internet? If not, why would Epicor? Moreover, there are probably more than one customer databases in a single SQL Server instance.
Thatās setting aside that Linked Server queries are not optimized by SQL Server (according to Brent Ozar).
So, the Business problem is āHow do I interface with Sales Force in the cloudā and there are others doing that. The question Iām hearing is, āCan I keep my previous on-prem integration with the cloud?ā and I would suggest probably not. Iām sure that most Sales Force integrators would prefer to work with a web service vs. directly with a database. APIs would provide one with finer security controls as well.
now, since you raise the rest api topic, my root of the problem is how to query the cloud epicor database properly.
give you an example, i have a stored procedure. it is list for each part, how many on hand qty, how many open quotes, how many open orders, how many qty shipped, how many qty in work order and how many qty in purchase not received yet.
now, I need convert this stored procedure using cloud database. I donāt know how to do it.
also, in my stored procedure, I have running total calculation because user choose the date, on that date, what is the on hand qty.
so, no idea how to do that. thatās why I ask if I can use linked server to do that. now, Epicor force everyone move to cloud. it cause some headache to grab the data easily and fast.
Thatās why I am trying to understand how you are so plugged in and I havenāt connected with you before. Am I just losing my memory or my mind?
I apologize if we have connected, and I just donāt remember. But I read a ton of your posts and learn a ton, I feel like I would have connected with you a lot sooner.
Hi Eddy,
I have the same problems like you. I have stored procedures on my sql server and now that we transition to SaaS I am scratching my head how to convert the reports. Did you finaly try CDATA ODBC? Did it work?
To give you an example, we have multiple levels of subassemblies in methods master and we use crystal reports to explode the BOM down to the leaves with raw material part numbers and check availability for each part whatās in stock, open POs, demand for other jobs and so on. Although crystal reports is currently the front end of the report, on the back end it is stored procedures using Transact SQL to loop through the BOM levels and prepare the data for the report. Kind of what you see below:
while (exists (select * from #bomtemp1 with (nolock) where lvl=@levelnum))
begin
insert into #bomtemp1
select partmtl.company, partmtl.partnum, partmtl.revisionnum, partmtl.pullasasm, partmtl.viewasasm, partmtl.mtlpartnum, @levelnum + 1, cast(partmtl.mtlseq as varchar(8)), partmtl.qtyper, #bomtemp1.nodes + ā-ā + partmtl.mtlpartnum
from partmtl with (nolock)
inner join #tlastrev with (nolock)
on partmtl.company = #tlastrev.company and partmtl.partnum = #tlastrev.partnum and partmtl.revisionnum = #tlastrev.revisionnum
inner join #bomtemp1 with (nolock)
on partmtl.partnum = #bomtemp1.child and partmtl.company = #bomtemp1.company
where #bomtemp1.lvl = @levelnum and #bomtemp1.viewasasm = 1 and
partmtl.partnum in (select partnum from part with (nolock) where typecode=āMā)
set @levelnum=@levelnum+1
end
I have no idea how to migrate this kind of reports in SaaS Kinetic.
