I think they would need to launch another web page like most other applications do, whether that’s your banking app for statements, or whatever… Maybe @josecgomez can explain how other browser based applications handle the previewing of a PDF.
I also found that when you generate Print Previews in web, then open your Windows client, they all suddenly open at once. I submitted a ticket for this and got this response:
There is an enhancement that will be included in the upcoming 2022.2 release that will allow the Kinetic homepage in a browser to automatically retrieve/open a print preview and this current behavior wouldn’t occur when logging into the client with the same user account as the one that print previewed the reports from the browser.
WOW I just had this happen to me yesterday and was super confused! Thank you for enlightening me!
Yes, I noticed if I opened the client it would display all your print previews.
October 20 for GA.
If I recall properly, installing the Edge Agent on the PC in question, essentially makes it work like the System Monitor does on the Windows Desktop client. The PDF’s pop up on the screen instead of having to download them from the notification manger.
Edit: Nope, turns out I was wrong.
I have that installed and it does not. It just gives you access to the client printers. At least as far as I can tell.
But with a little coding magic… all of your dreams can come true! :3
Quite honestly, this is a hacky solution that would need to be implemented on every report. Epicor should really just fix their shit because it is doable.
You’ll need this BAQ to make it work.
SysRptLst.baq (14.0 KB)
Create a view to hold the BAQ data.
Create an event that triggers after SubmitToAgent
Call your BAQ.
Add a widget that has an expression field (I use condition because I can put console writes on true/false to show if it’s working in the log).
Condition expression:
eval ("var byteString = window.atob('{SysRptList.SysRptLst_RptData}');let int8Array = new Uint8Array(new ArrayBuffer(byteString.length));for (let i = 0; i < byteString.length; i++) { int8Array[i] = byteString.charCodeAt(i);}let documentBlob = new Blob([int8Array], { type: 'application/pdf' });let fileURL = URL.createObjectURL(documentBlob);console.log(fileURL); window.open(fileURL,'_blank');")
I have install Edge Agent and still don’t see any print previews.
Don’t let your boss see that!
Edit: I can spell… really!
So… We’ve been anticipating a post on using the conditionals to inject behavior beyond Boolean conditions at some point so congrats Hannah - we should probably send you a prize of some sort. Probably will not surprise you all to know that there will be increasing sandboxing added here to stop users from breaking outside the condition box as well as a designer for non-coders to help you know what you can/can’t do there.
On the feature here… we do have open previews and data exports automatically rather than making you click the alert button tagged for 23.1 so that is upcoming. That was a poor design choice on our part (only showing these kind of actions in the notification panel to select) which we’ll be changing.
Edge agent as someone mentioned also will not impact this either way it gets us access to local actions like printing and local file access but not required to view a pdf preview.
Tickets to F1 in October maybe?
Hannah you really outdid yourself here… This is nuts. So amazing hahahah
