Labor Edit Report - Labor Hrs
Todd,
Go to set up a work center in help and click on "Split Burden" it gives how
labor detail is split and looks exactly like the scenario you are speaking
of in the example. Hope this helps.
Jim Frice
> -----Original Message-----
> From: Todd Caughey [mailto:caugheyt@...]
> Sent: Monday, February 05, 2001 12:52 PM
> To: 'vantage@yahoogroups.com'
> Subject: [Vantage] Labor Edit Report - Labor Hrs
> The labor edit report is not calculating labor hours the way we would
> expect. Either it is wrong or more likely there is some reason we are not
> aware of. For example: Clock in = 18.33 / Clock-out = 23.75 shows labor
> hours of 2.58 instead of the expected 4.92 (allowing for .5 hr
> lunch in that
> time range). In almost every case the labor hours shown on the report is
> roughly 1/2 of what we would expect. Often, but not always,
> another person
> is clocked on to the same job/operation at the same time so I suspect some
> sort of splitting it going on.
> I have searched all over the help screens and can find no explanation for
> the calculations going on inside the labor edit report, and what flags or
> settings they drive off of. When I dump labor detail records the LaborHrs
> shows as the correct amount but this may be because accounting
> has corrected
> it already. This is probably a pretty simple system setting we
> have missed
> but the documentation is not helping at all. Any help from "the
> real world"
> would be much appreciated.
> Thanks,
> -Todd Caughey
> Harvey Vogel Mfg. Co.
> To unsubscribe from this group, send an email to:
> vantage-unsubscribe@egroups.com
hours of 2.58 instead of the expected 4.92 (allowing for .5 hr lunch in that
roughly 1/2 of what we would expect. Often, but not always, another person
shows as the correct amount but this may be because accounting has corrected
it already. This is probably a pretty simple system setting we have missed
but the documentation is not helping at all. Any help from "the real world"
-Todd Caughey
One thing we have found, if an employee clocks in on two or more operations
at the same time Vantage will spread the time across both operations. Can
also depend on how your work centers are setup. I have talked with Vantage
support several times and each time get a little more insight on this and
it's still pretty gray to me.
Warren R. Eddy
Information Services Manager
National Tube Form, LLC
An Excaliber Company
e-mail - Warren.Eddy@...
phone - 219 478-2363 ext 217
fax - 219 478-1043
-Todd Caughey
Thanks, I might have to call support. One person on two opers is working as
we would expect (splits time) and is easy to see (consecutive details on
report with overlapping times). But when a person clocks in/out of the same
job all day ( 8 hrs) and then shows 4.00 labor hours something else is at
work that I can't pin down.
-Todd C.
Sent: Monday, February 05, 2001 1:30 PM
Subject: RE: [Vantage] Labor Edit Report - Labor Hrs
Warren R. Eddy
fax - 219 478-1043
-Todd Caughey
Yahoo! Groups Sponsor
<http://rd.yahoo.com/M=176325.1307935.2900315.1248727/D=egroupmail/S=1700007
183:N/A=567159/R=1/*http://domains.yahoo.com>
183:N/A=567159/R=2/*http://domains.yahoo.com>
www. .com
<http://us.adserver.yahoo.com/l?M=176325.1307935.2900315.1248727/D=egroupmai
l/S=1700007183:N/A=567159/rand=562436274>
