FYI.
I received information from support that this is a known bug and scheduled for release in 8.03.410.
This happens when you make a change to a labor transaction on an operation that was already complete. The change must occur against a transaction that was not the original completing one. My test...
Example:
Opr. 20 Posted Setup for 1 hour and 100%. This completed setup and marked the "Complete" box.
Opr. 20 Posted Production for 30 minutes and 1 piece against the Run Qty. of 5.
Opr. 20 Posted Production for 1 1/2 hours and 4 pieces. This completed and marked the "Complete" and "Opr. Complete" boxes.
Now, an adjustment is made within Labor Entry. The transaction for 30 minutes and 1 piece should have been 15 minutes and 1 piece. Save. View Job Tracker and the GREEN checkmark has now been removed.
Workaround:
In this scenario you must mark the "Complete" and "Opr. Complete" boxes on the transaction you are correcting.
Hope this helps others.
Jeff... PS. Thanks Rob!
Example:
Workaround:
--- In vantage@yahoogroups.com, "jplehr" <jlehr@...> wrote:
> Vantage 8.03.408A
> I thought I saw something recently on this topic but had no luck in my search.
> Has anyone seen this scenario. We thought we found a common variable in the way we process information, however, with this one, that went out the window. Please keep in mind that we do NOT use MES and enter information through manual Labor Entry.
> Operation 30. Setup complete 100%. Production run and completed. Labor Entry shows the operation two check boxes (Complete and Opr. Complete) both checked. Job Tracker shows the same in Labor Transactions. Job Adjustment shows the same.
> Problem: There is NO Green check mark in the tree view of Job Tracker and the operation remains on my Priority Dispatch Report.
> We have been chasing this scenario for some time and really thought it resulted when posting setup after setup had already been completed. Now, we don't have a clue.
> Any thoughts?
> Jeff
