If you wish to attach your name to this issue the call number is 776498PSC.
The last labor date field on the Job Operations record does not always
reflect the last labor performed on the operation. If you go into labor
entry and select labor turned in prior to the actual last labor date and
modify the record it will update the job operation record with the labor
date being edited which is not necessarily the last labor date.
Patrick Winter
sSc Specialty Screw Corporation
Vantage 5.10.130, Progress 9.1C
Patrick Winter
