LastLaborDate on JobOper
Heads up:
It you create a report to verify the accuracy of the LastLaborDate field
compaired to labor tickets you may find some errors. What I have found is if
you go back say 2 days to fix a labor ticket for a job that finished today
the last guy wins. In other words the lastlabordate will now show two days
ago. In other words the write trigger needs to only update the lastlabordate
when the date is greater than the current lastlabordate not every time.
Patrick Winter
sSc Specialty Screw Corporation
Vantage 5.10.130, Progress 9.1C
Sent: Wednesday, April 30, 2003 8:40 AM
Subject: RE: [Vantage] LastLaborDate on JobOper
Can't answer as to why JobOper doesn't seem to update for you .. but I have
a similar reporting feature using PartWip.LastActivityDate ... never had a
poblem with it ... might work better for you?
Mike
Sent: Tuesday, April 29, 2003 2:35 PM
Subject: [Vantage] LastLaborDate on JobOper
I'm trying to use the last labor date on JobOper to determine roughly when
the operation was completed (not that they always get marked completed). But
I am notcing that often (but not always) this is returning "?" as if there
is no value there. But when I run the production detail report for the job
it shows labor transactions for the job. Any reason why the JobOper field
is not being updated with the date?
5.20.313
-Todd Caughey
Harvey Vogel Mfg. Co.
Yahoo! Groups Sponsor
------------------------ Yahoo! Groups Sponsor ---------------------~--> Get
128 Bit SSL Encryption!
http://us.click.yahoo.com/xaxhjB/hdqFAA/bW3JAA/PhFolB/TM
I'm trying to use the last labor date on JobOper to determine roughly when the operation was completed (not that they always get marked completed). But I am notcing that often (but not always) this is returning "?" as if there is no value there. But when I run the production detail report for the job it shows labor transactions for the job. Any reason why the JobOper field is not being updated with the date?
5.20.313
-Todd Caughey
OK, I figured it out. The ones showing dates are all dated after we went from 4.0 to 5.20 on Oct. 4, 2002. So the field must have been added some time after 4.0.
-Todd C
5.20.313
-Todd Caughey
<http://rd.yahoo.com/M=229633.3212141.4526654.2595810/D=egroupweb/S=1705007183:HM/A=1556779/R=0/*http://shop.store.yahoo.com/cgi-bin/clink?ftd2+shopping:dmad/M=229633.3212141.4526654.2595810/D=egroupweb/S=1705007183:HM/A=1556779/R=1/1051644937+http://us.rmi.yahoo.com/rmi/http://www.ftd.com/rmi-framed-url/http://www.ftd.com/yahoo36>
<http://us.adserver.yahoo.com/l?M=229633.3212141.4526654.2595810/D=egroupmail/S=:HM/A=1556779/rand=507207024>
Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> .
have a similar reporting feature using PartWip.LastActivityDate ... never
had a poblem with it ... might work better for you?
Mike
5.20.313
-Todd Caughey
