Hello Group,
I am creating a customization where I am opening a report from the MES menu. I was going to open an ODBC report but in Vantage the Crystal Viewer won’t accept parameters. So we’ve decided to use a version of the Labor Edit report. However when I use the process.caller method on this I get an error using the LaunchFormOptions inside the Labor Edit report screen when trying to load the values I’m passing. The error says:
‘LaunchFormOptions’ is not a member of ‘Epicor.Mfg.UI.Rpt.LaborEditEntry.LaborEditForm’.
So my question is can I open a report and pass it parameters form a screen in Vantage 8? If so what method should I use? Is there some assembly I need to add or does Vantage just not support LaunchFormOptions for their out of the box reports? any help is appreciated
