Upgrading from 8.03 to 9.05. Customer previously tried doing the upgrade themselves first and had issues. We ompleted all the steps in the epicor guide without issue. We are trying to start the 3 appservers for Production and only TaskAgent and ProcessServer will start, the main mfgsys one will not. Not sure what is causing the issue, I suspect something in OpenEdge isn’t right from doing both upgrades on the same box and a setting got crossed or is missing. In the broker log for the mfgsys appserver is the below error. I can confirm that the .pf file is in the correct location and it ‘appears’ to look correct when I open it in notepad but im not 100% on this. Any help is appreciated.
Broker Log
ERROR: cannot start server (8100)
Ending serverPool thread s-0010 (8077)
admin error response received: 2. (8067)
Message from server: Startup Procedure Failed (8113)
IOException reading message from server: java.io.EOFException: pipe to server broken (8117)
Regards
On 23 Oct 2015, at 23:19, detroitrdwings91@... [vantage] <vantage@yahoogroups.com> wrote:
Broker Log
Stephen Edginton (Beng) | Solutions & Technical Director |
Dot Net IT Limited, One St Kenelm Court, Steel Park Road, Halesowen, B62 8HD, United Kingdom.
This is from progress.
Cause |
Resolution |
also are you sure the Epicor905 progress db us running?
Sent: Friday, October 23, 2015 6:14 PM
Subject: [Vantage] Main Appserver Won't start
Broker Log
CONFIDENTIALITY NOTICE
The information contained in this communication, including attachments, is privileged and confidential. It is intended only for the exclusive use of the addressee. If the reader of this message is not the intended recipient, or the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us at 727-578-6240 and immediately delete the communication.
The server log is what will tell you the real solution.
Broker Log
