Got it back online. We ended up replacing the entire oe102a folder. Tech support said a file got corrupted in this folder so the service couldn't start.
Sent: Monday, August 20, 2012 2:24 PM
Subject: [Vantage] Re: Appservers not starting
They should get you gong.
If not maybe these Progress KB might give you some ideas
http://knowledgebase.progress.com/articles/Article/000029188
http://knowledgebase.progress.com/articles/Article/P151109
--- In vantage@yahoogroups.com, Ted Koch <tkoch77@...> wrote:
> Yes, Progress. On the phone with support currently.
>Â From: b_ordway <cooner_55421@...>
> Sent: Monday, August 20, 2012 2:06 PM
>Â
> I assume you are Progress?
> I had the issue you describe once.
> - I believe something that an AppServer was connecting to had not finished starting.
> Short term, just to get up and running I unchecked autostart on the appservers.
> Made sure the database started.
> Then I manually started each of the appservers in this order: MfgSysXXX,MfgSysXXXTaskAgent, MfgSysXXXProcesServer
> I made sure each had started before moving on to the next.
> Eventually, after going thru the tuning guide I re-enabled autostart & the appservers behaved from that point on.
> --- In vantage@yahoogroups.com, Ted Koch <tkoch77@> wrote:
> > Seeing this error in the Appserver log.
> > Startup Procedure Failed (8113)Â
> >Â From: tkoch77 <tkoch77@>
> > Sent: Monday, August 20, 2012 1:21 PM
> > Subject: [Vantage] Appservers not starting
> >Â
> > Has anyone else had an issue where when they restart their Epicor server the appservers don't start right away, and sometimes they never start at all?
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note:Â You must have already linked your email address to a yahoo id to enable access. )
> > (1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/.%c2%a0
> > (2) To search through old msg's goto: http://groups.yahoo.com/group/vantage/messages
> > (3) To view links to Vendors that provide Vantage services goto: http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
