Yes, you can run OE from your desktop, but you can also start/stop app servers a couple of other ways. We started 905.602 and have only upgraded once to 905.605, I don't know about the older versions. Epicor did the install and used my SQL server as the 32 admin install. The installer showed me the fathom management console that runs in a browser. You can start stop and monitor appservers from there. It works, but I didn't like all of the maneuvering to start/stop all three appservers.
I found a batch script in an Epicor admin guide. I have versions to stop/start all three servers, or just the task and process servers. I run these on the 64bit admin server.
@echo off
echo Starting 905 Database and AppServers...
set DLC=E:\Epicor\OE102A
set PATH=%DLC%\BIN;%PATH%
set LIB=%DLC%\LIB;%LIB%
echo .
echo .
echo STARTING LOCAL DB/APPSERVERS...
cd \Epicor905\db\Test
call asbman -name EpicorTest905ProcessServer -start
call asbman -name EpicorTest905TaskAgent -start
call asbman -name EpicorTest905 -start
You can not have CR Developer 2008 and CR 2008 runtime on the same machine. Developer will not install. Don't know about XI
@echo off
echo .
echo .
--- In vantage@yahoogroups.com, "Elizabeth" <gracefulthreads@...> wrote:
> Realizing this is an old thread, I want to make sure I can do something before I completely trash something important (always an exciting way to spend a weekend...)
> We're running E9.04.507A, and I just got the DVDs for 9.05. Just upgraded my test server to SQL 2008, and am going through the prelim stuff (chapters 1-4 of the 9.05 Install Guide).
> Main question: can I use my regular daily computer (on which I run 9.04 and Crystal Developer XI) to be the Windows Admin Workstation for the 9.05 installation? Will the actual install of OE 10.2 play nice with the older Epicor (or at least ignore it completely?)
> Secondary: Did I read somewhere that the new version of Crystal Developer (2008) can't reside on a system with the CR runtime?
> Ernie Lowell
> Diba Industries
> --- In vantage@yahoogroups.com, Zac Jason Woodward <zac@> wrote:
> > Going to clarify a little more on what nate said:
> > 1. install OpenEdge 32 bit on another server (admin service does not need to be running. after patches you can set to manual or disabled.)
> > 2. Patch OpenEdge 32 bit to the latest version for safety
> > 3. On the OpenEdge 32 bit server run the Epicor client installer and when prompted select admin console/tools
> > 4. Run your conversions
> > Yes it sucks, but at this point it is a necessary evil. If you use Open4 you will need this 32 bit server anyhow as it wont run on the 64 bit.
> > "Zac" Jason Woodward
> > Network Administrator
> > Intermountain Electronics, Inc.
> > O: 877-544-2291
> > M: 435-820-6515
> > F: 435-637-9601
> > www.ie-corp.com
> > Creating customer confidence through extraordinary service and experienced industry experts.
> > From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Nathan Anderson
> > Sent: Monday, July 18, 2011 3:42 PM
> > Subject: RE: [Vantage] Re: Epicor 9.05.600 x64 MS SQL, can't start AppServers
> > Are you trying to run the admin tools from the 64bit server? With 905,
> > if you installed the 64bit version of 905 you need to run the admin
> > tools program from your 32bit admin workstation. The instructions on
> > how to set up the admin workstation is in the install guide
> > ~Nathan
> > From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf
> > Of Clive
> > Sent: Monday, July 18, 2011 4:37 PM
> > To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>
> > Subject: [Vantage] Re: Epicor 9.05.600 x64 MS SQL, can't start
> > AppServers
> > I did that this morning to see if it would sort things out, which it
> > didn't.
> > With the latest version of E9, 9.0.5.605, I now get the lovely error...
> > The shared memory is version 45088768; expected 12009 (1178)
> > ... when trying to 'Run Conversions Using Epicor Admin Tools'.
> > All I get from Epicor support is the dirty 'C' word, consultancy. To be
> > honest I wish we had the budget this year to move to Microsoft Dynamics
> > AX...
> > --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> ,
> > "Ned" <TechnoBabbly@> wrote:
> > > Install the service packs, the CD itself won't work all on it's own.
> > > -----Original Message-----
> > > From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
> > [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> ] On
> > Behalf Of
> > > Clive
> > > Sent: Saturday, July 16, 2011 7:52 AM
> > > To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
> > > Subject: [Vantage] Epicor 9.05.600 x64 MS SQL, can't start AppServers
> > > Hi,
> > > I've done some research on here, and I think I may be lucky in that
> > others
> > > have had exactly the same problem ?.
> > > I'm currently setting up a new server, Epicor 9.05.600 x64 with MS SQL
> > 2008
> > > running on Windows Server 2008 x64. I've not applied any Epicor
> > patches,
> > > jusy OpenEdge, as I want to get it working correctly off of the DVD's
> > first
> > > in case I need to perfomr a clean install again.
> > > I've had various quirks here and there, to be expected with Epicor
> > software,
> > > but currently I can't start the AppServer's.
> > > I've seen the verbose logging issue mentioned, I've made the tweak but
> > I get
> > > this in the broker log...
> > > IOException reading message from server : java.io.EOFException: pipe
> > to
> > > server broken (8117)
> > > ... and this in the server log...
> > > [11/07/15@21:44:12.576+0100] P-009260 T-007868 2 AS AS Application
> > Server
> > > Startup. (5473)
> > > [11/07/15@21:44:13.077+0100] P-007508 T-009664 2 AS CONN Connected to
> > > database mfgsyssh, user number 49. (9543)
> > > [11/07/15@21:44:13.101+0100] P-008540 T-009436 2 AS CONN Connected to
> > > database mfgsyssh, user number 48. (9543)
> > > [11/07/15@21:44:13.138+0100] P-007508 T-009664 1 AS -- ** Warning --
> > > database mfgsyssh is already connected. (1012)
> > [11/07/15@21:44:13.139+0100]
> > > P-007508 T-009664 1 AS -- ** Warning -- database mfgsys is already
> > > connected. (1012) [11/07/15@21:44:13.142+0100] P-007508 T-009664 1 AS
> > > Invalid version, 1007 (expected 17391) in object file
> > > D:\Epicor\Epicor905\Server\as\startup.r. (2888)
> > > P-007508 T-009664 1 AS -- as/startup.p startup procedure ended with an
> > > ERROR condition. (8025)
> > > ... I've a support call logged with Epicor but I think the people here
> > can
> > > beat them to the punch ;-)
> > > Thanks.
> > > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> > have
> > > already linked your email address to a yahoo id to enable access. )
> > > (1) To access the Files Section of our Yahoo!Group for Report Builder
> > and
> > > Crystal Reports and other 'goodies', please goto:
> > > http://groups.yahoo.com/group/vantage/files/.<http://groups.yahoo.com/group/vantage/files/>
> > > (2) To search through old msg's goto:
> > > http://groups.yahoo.com/group/vantage/messages
> > > (3) To view links to Vendors that provide Vantage services goto:
> > > http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
> > Click here
> > <https://www.mailcontrol.com/sr/wQw0zmjPoHdJTZGyOCrrhg==
> > y8wPKdkajUj6QbCV!KpIx8oX9eFTxii74Kez5oFEicUPXg==> to report this email
> > as spam.
> > This e-mail is for the use of the intended recipient(s) only. If you have received this e-mail in error, please notify the sender immediately and then delete it. If you are not the intended recipient, you must not use, disclose or distribute this e-mail without the author's prior permission. We have taken precautions to minimize the risk of transmitting software viruses, but we advise you to carry out your own virus checks on any attachment to this message. We cannot accept liability for any loss or damage caused by software viruses. Any views and/or opinions expressed in this e-mail are of the author only and do not represent the views of Epicor Software Corporation or any other company within its group.
> > This message has been scanned for malware by Websense. www.websense.com
