Major MRP issues in 10.0700.4. and 10.1 also?
Thanks Jose.
That helps a lot.
MIKE TONOYAN | IT Director
MTonoyan@...
Tel +1.818.734.6511  |  Cell +1.818.397.8515
Sent: Tuesday, July 19, 2016 9:45 AM
Subject: [Vantage] RE: Major MRP issues in 10.0700.4. and 10.1 also?
Mike,
I had the same problem a few months ago. I opened a ticket with Epicor support and they had me try several things and none worked and I finally gave up. I then had another issue with MRP which they gave me a fix for which also fixed this issue.  Below is the SCR bundle ,It fixed both my MRP problems. The only strange thing was that the descriptions of the SCRs didn’t reference my issues exactly but fixed my issues.
SCR 162052 - Create MRP / Scheduling Bundle
For 10.0.700.4, this retro includes:
  SCR  141261 - Calculate Global Scheduling Order - Process takes an hour to run in Epicor 10 but only 15 minutes on
  SCR  144016 - Multi Resource Scheduling Board - multi resource scheduling board it is taking up to 4 minutes to co
  SCR  145707 - Process Multi Level Pegging -  Process is not Running on a customer database.
  SCR  149442 - Scheduling Engine - Improve performance eliminating use of the indexers.
  SCR  149678 - Process MRP - does not populate a job s Creation Date
  SCR  151132 - Scheduling Engine - Scheduling loops between assemblies and subassemblies when running on a customer
  SCR  153717 - Calculate Global Scheduling Order - Process abandons and do not complete
  SCR  154458 - Process MRP should continue running if one processor fails.
  SCR  155695 - Scheduling Engine  - Daily Production Capacity is not calculated.
  SCR  158803 - Multi Resource Scheduling Board - takes the same resource for more than 1 scheduling block when movi
  SCR  159804 - Scheduling Engine  -The capabilities cannot be scheduled.
  SCR  160152 - Process MRP - Process Hangs and MRP log says that "The connection s current state is broken"
  SCR  162430 - Process MRP - Inserting duplicate records when firming a job
Sent: Monday, July 18, 2016 3:43 PM
Subject: [Vantage] Major MRP issues in 10.0700.4. and 10.1 also?
I am wondering if anyone else is having similar problems in E10.0.700.4 or in E10.1.400.xx versions.
MRP is not able to create suggestion job for the first demand, but then goes on and creates a suggestion job for the second demand for the same part
08:43:16 Copying BOM from Part:11112163 Rev:E to Job:z0000001302.
08:44:10 An error occurred while reading from the store provider's data reader. See the inner exception for details.
08:44:10 Error copying BOM, deleting Job:z0000001302.
08:44:10 Deleting unfirm job z0000001302
08:44:10 Creating new unfirm job:z0000001303 Quantity:1760.00000000.
08:44:11 Adding to job:z0000001303 Quantity:1760.00000000.
08:44:11 Copying BOM from Part:11112163 Rev:E to Job:zAGV0000001303.
08:45:54 Sent job zAGV0000001303 to SchedJobI
MTonoyan@...
_________________________________________________________________________________ Notice: This email transmission may contain confidential information and is intended only for the person(s) named. Any use, copying or disclosure to/by any other person(s) is strictly prohibited. By accepting this information, recipients confirm that they understand and will comply with all applicable ITAR and EAR requirements. _________________________________________________________________________________
AP clerk has a new printer. we have to load checks in this new printer face down. how can I change the check print to print highest number to lowest as the paper feed pulls the highest number check first......
bw
Sounds like if the printer is pulling from the bottom of the stack you are SOL on that one. Even if you did shift how Epicor was printing (which I don’t think that would be an easy task if even possible) you would always have to load the exact number of checks you are about to print so that they match up. PIA for that employee though.
Joshua Giese
Technology Solutions : CXO
Direct Phone:    920.593.8299
Office Phone:    920.437.6400 x342
http://wcibags.com/email/emailFooter4.jpg
Sent: Wednesday, July 13, 2016 9:18
Subject: [Vantage] E10.1 Silly Question ?
bw
I don’t know how many checks you are printing or if you are already doing this, but we’ve had that issue forever and we just take the correct number of checks to print for that run and reverse order them,
so they go into the printer with the lowest number on top.
Julie Lehmann
Sent: Wednesday, July 13, 2016 9:18 AM
bw
No virus found in this message.
Checked by AVG - www.avg.com
Version: 2016.0.7640 / Virus Database: 4627/12605 - Release Date: 07/12/16
Version: 2016.0.7640 / Virus Database: 4627/12607 - Release Date: 07/13/16
<p>See if the printer has a layout option of: back to front vs.
  front to back in the preferences.<br>
</p>
On 7/13/2016 8:19 AM, &#39;Julie Lehmann&#39; <a rel="nofollow" class="ygrps-yiv-1503122996moz-txt-link-abbreviated" target="_blank" href="mailto:jlehmann@...">jlehmann@...</a>
[vantage] wrote:<br>
<blockquote><span title="qreply"> <blockquote
type=“cite”>
  <style><!--
#ygrps-yiv-1503122996
_filtered #ygrps-yiv-1503122996 {font-family:Wingdings;panose-1:5 0 0 0 0 0 0 0 0 0;}
_filtered #ygrps-yiv-1503122996 {font-family:Calibri;panose-1:2 15 5 2 2 2 4 3 2 4;}
_filtered #ygrps-yiv-1503122996 {font-family:Tahoma;panose-1:2 11 6 4 3 5 4 4 2 4;}
_filtered #ygrps-yiv-1503122996 {font-family:Verdana;panose-1:2 11 6 4 3 5 4 4 2 4;}
_filtered #ygrps-yiv-1503122996 {font-family:Consolas;panose-1:2 11 6 9 2 2 4 3 2 4;}
#ygrps-yiv-1503122996 p.ygrps-yiv-1503122996MsoNormal, #ygrps-yiv-1503122996 li.ygrps-yiv-1503122996MsoNormal, #ygrps-yiv-1503122996 div.ygrps-yiv-1503122996MsoNormal
{margin:0in;margin-bottom:.0001pt;font-size:12.0pt;font-family:“Times New Roman”, “serif”;}
#ygrps-yiv-1503122996 a:link, #ygrps-yiv-1503122996 span.ygrps-yiv-1503122996MsoHyperlink
{color:blue;text-decoration:underline;}
#ygrps-yiv-1503122996 a:visited, #ygrps-yiv-1503122996 span.ygrps-yiv-1503122996MsoHyperlinkFollowed
{color:purple;text-decoration:underline;}
{margin-right:0in;margin-left:0in;font-size:12.0pt;font-family:“Times New Roman”, “serif”;}
#ygrps-yiv-1503122996 code
{font-family:“Courier New”;}
#ygrps-yiv-1503122996 pre
{margin:0in;margin-bottom:.0001pt;font-size:10.0pt;font-family:“Courier New”;}
#ygrps-yiv-1503122996 tt
#ygrps-yiv-1503122996 span.ygrps-yiv-1503122996cat
#ygrps-yiv-1503122996 span.ygrps-yiv-1503122996ct
#ygrps-yiv-1503122996 span.ygrps-yiv-1503122996HTMLPreformattedChar
{font-family:Consolas;}
#ygrps-yiv-1503122996 p.ygrps-yiv-1503122996attach, #ygrps-yiv-1503122996 li.ygrps-yiv-1503122996attach, #ygrps-yiv-1503122996 div.ygrps-yiv-1503122996attach
{margin-right:0in;margin-left:0in;font-size:9.0pt;font-family:“Arial”, “sans-serif”;}
#ygrps-yiv-1503122996 p.ygrps-yiv-1503122996bold, #ygrps-yiv-1503122996 li.ygrps-yiv-1503122996bold, #ygrps-yiv-1503122996 div.ygrps-yiv-1503122996bold
{margin-right:0in;margin-left:0in;font-size:10.0pt;font-family:“Arial”, “sans-serif”;font-weight:bold;}
#ygrps-yiv-1503122996 p.ygrps-yiv-1503122996green, #ygrps-yiv-1503122996 li.ygrps-yiv-1503122996green, #ygrps-yiv-1503122996 div.ygrps-yiv-1503122996green
{margin-right:0in;margin-left:0in;font-size:12.0pt;font-family:“Times New Roman”, “serif”;color:#628C2A;}
#ygrps-yiv-1503122996 p.ygrps-yiv-1503122996replbq, #ygrps-yiv-1503122996 li.ygrps-yiv-1503122996replbq, #ygrps-yiv-1503122996 div.ygrps-yiv-1503122996replbq
{margin:3.0pt;font-size:12.0pt;font-family:“Times New Roman”, “serif”;}
#ygrps-yiv-1503122996 p.ygrps-yiv-1503122996ad, #ygrps-yiv-1503122996 li.ygrps-yiv-1503122996ad, #ygrps-yiv-1503122996 div.ygrps-yiv-1503122996ad
#ygrps-yiv-1503122996 p.ygrps-yiv-1503122996underline, #ygrps-yiv-1503122996 li.ygrps-yiv-1503122996underline, #ygrps-yiv-1503122996 div.ygrps-yiv-1503122996underline
#ygrps-yiv-1503122996 span.ygrps-yiv-1503122996yshortcuts
#ygrps-yiv-1503122996 p.ygrps-yiv-1503122996ad1, #ygrps-yiv-1503122996 li.ygrps-yiv-1503122996ad1, #ygrps-yiv-1503122996 div.ygrps-yiv-1503122996ad1
#ygrps-yiv-1503122996 p.ygrps-yiv-1503122996ad2, #ygrps-yiv-1503122996 li.ygrps-yiv-1503122996ad2, #ygrps-yiv-1503122996 div.ygrps-yiv-1503122996ad2
{margin-right:0in;margin-bottom:7.5pt;margin-left:0in;font-size:12.0pt;font-family:“Times New Roman”, “serif”;}
#ygrps-yiv-1503122996 p.ygrps-yiv-1503122996underline1, #ygrps-yiv-1503122996 li.ygrps-yiv-1503122996underline1, #ygrps-yiv-1503122996 div.ygrps-yiv-1503122996underline1
{margin-right:0in;margin-left:0in;font-size:12.0pt;font-family:“Times New Roman”, “serif”;text-decoration:underline;}
#ygrps-yiv-1503122996 span.ygrps-yiv-1503122996yshortcuts1
{font-family:“Verdana”, “sans-serif”;font-weight:bold;}
#ygrps-yiv-1503122996 span.ygrps-yiv-1503122996yshortcuts2
{font-family:“Verdana”, “sans-serif”;font-weight:normal;}
#ygrps-yiv-1503122996 span.ygrps-yiv-1503122996EmailStyle36
{font-family:“Calibri”, “sans-serif”;color:#1F497D;}
#ygrps-yiv-1503122996 .ygrps-yiv-1503122996MsoChpDefault
{font-size:10.0pt;}
_filtered #ygrps-yiv-1503122996 {margin:1.0in 1.0in 1.0in 1.0in;}
#ygrps-yiv-1503122996 div.ygrps-yiv-1503122996WordSection1
_filtered #ygrps-yiv-1503122996 {}
_filtered #ygrps-yiv-1503122996 {font-family:Symbol;}
_filtered #ygrps-yiv-1503122996 {font-family:“Courier New”;}
_filtered #ygrps-yiv-1503122996 {font-family:Wingdings;}
#ygrps-yiv-1503122996 ol
{margin-bottom:0in;}
#ygrps-yiv-1503122996 ul
  <div class="ygrps-yiv-1503122996WordSection1">
    <p class="ygrps-yiv-1503122996MsoNormal"><span
style=“font-size:11.0pt;color:#1F497D;”>I
so
Â
Julie
Lehmann
Â
Â
Â
feed pulls the highest number check first…
Â
bw
No
No
      <div style="color:white;clear:both;"></div>
  </div>
</div></blockquote>
<br>
The easiest option would be to see if the printer driver under properties has an option to print last page first. Not all printers drivers have this option so you’ll have to look under properties of the printer driver and you might just get lucky.
Sent: Wednesday, July 13, 2016 7:18 AM
bw
Well, I just walked over to my accounting team and asked them the same question.  They actually reverse all the checks!  If anyone knows of a printer reverse the order, please let me know.  What a waste of time.
Miguel A. Santillan
Compass Manufacturing Systems
Sent: Wednesday, July 13, 2016 7:47 AM
Subject: RE: [Vantage] E10.1 Silly Question ?
bw
Disclaimer
The information contained in this communication from the sender is confidential. It is intended solely for use by the recipient and others authorized to receive it. If you are not the recipient, you are hereby notified that any disclosure, copying, distribution or taking action in relation of the contents of this information is strictly prohibited and may be unlawful.
Other than manually sorting them in the opposite order before loading them, I don’t think there are other options.
JOE ROJAS
Epicor Applications Manager
VENTION MEDICAL
DIRECT: 508.597.1392 x1625 | MOBILE: 774.826.9245
Sent: Wednesday, July 13, 2016 11:05 AM
Joshua Giese
[Image removed by sender. http://wcibags.com/email/emailFooter4.jpg%5d<http://www.wcibags.com/>
bw
When you buy checks, you can have them sent to you reversed. It’s quite convenient.
Tom Christie | Chief Financial Officer | AGM Container Controls, Inc.<http://www.agmcontainer.com/> | tchristie@...<mailto:tchristie@...> | t: 520.881.2130 ext 2176
Sent: Wednesday, July 13, 2016 9:47 AM
Miguel A. Santillan
From: vantage@yahoogroups.com<mailto:vantage@yahoogroups.com> [mailto:vantage@yahoogroups.com]
To: vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>
bw
Disclaimer
The other option is to change the sorting on the check form. On the SSRS version of the check form it’s sorting in ascending order by check number. All you have to do is change the sorting to be descending order and it will print the last check in the batch last-  first.  If you use Crystal report forms, it should be exactly the same change.
Miguel A. Santillan
bw
Disclaimer
Sent: Wednesday, July 13, 2016 10:28 AM
Miguel A. Santillan
bw
Disclaimer
First Off, Thanks for all the suggestions !!
I checked printer driver settings and no luck there.
I modified the SSRS report to change sort order on the Tablix and the Group and it seemed to work just as I hoped.
I saved as a new report name and tried to preview using exact same dataset that was used to preview the unmodified report and received error saying Invalid object name 'ChechHead_<GUID>' yet I could use same GUID to preview stock report !!
Did I ever mention how much I despise SSRS reports??
I finally saved as original name and it will preview in report builder - I will see what happens when they try a check run :/
Any method of printing in reverse order (printer driver setting or SSRS defiition) would still require having the exact number of checks in the printer when starting.
Is there a manual feed that allows several sheets to be installed at once?  Most manual feeds print on the "top" side of the sheet being fed.
Just spit-balling ....
SSRS does do some caching and why you can probably still preview the stock report specially since you didn’t make a change to it. The new modified report probably failed with that error because the data for that GUID has been purged from the SSRS database. It will do it pretty quickly, especially on checks unless you set the archive period to be > 0 days which is the default when you print.
I’m sure you’ll be fine on your next check run !
Sent: Wednesday, July 13, 2016 10:57 AM
MTonoyan@...
Mike,
MTonoyan@...
Anyone running 10.700.4 should have that bundle in place if they are scheduling and using MRP
Rob Bucek
Production Control Manager
D&S Manufacturing
301 E. Main St.
Black River Falls, WI 54615
715-284-5376 Ext. 311
Mobile: 715-896-3119
rbucek@...<mailto:rbucek@...>
Visit our newly redesigned Website at www.dsmfg.com<http://www.dsmfg.com/>
Sent: Tuesday, July 19, 2016 11:45 AM
Mike,
MTonoyan@...<mailto:MTonoyan@...>
