You could always just do it using a BPM as long as you are not deleting or adding records. Use the update method of an unused UD table and put your code in. Then just create a single record and save.
--- In vantage@yahoogroups.com, Jose Gomez <jose@...> wrote:
> Open edge architect is an IDE for progress. Very nice but not necessary.
> You'll still need the dev license.
> Ps we paid much less for it
> Sent from mobile
> On Mar 23, 2011 7:07 PM, "cubcrafters_it" <jason.navarrete@...>
> wrote:
> > Thanks! That's what I needed.
> > I got a quote back from my CAM for $3600 + $720 maintenance for OpenEdge
> Architect (for OpenEdge 10.2a). Any idea how that differs from the Dev
> license?
> > --- In vantage@yahoogroups.com, Jose Gomez <jose@> wrote:
> >> This si the link for the editor
> >> "C:\Program Files\epicor\oe101c\bin\prowin32.exe" -db "C:\Program
> >> Files\Epicor Software\Epicor904\db\Test\mfgsys.db" -S 9020 -H disraeli -N
> >> TCP -Mm 1024
> >> This is the link for the compiler
> >> "C:\Program Files\epicor\oe101c\bin\prowin32.exe" -p _comp.p -db
> >> "C:\Program Files\Epicor Software\Epicor904\db\mfgsys.db" -S 9020 -H
> >> disraeli -N TCP -Mm 1024
> >> S= DB Port
> >> H Host
> >> -Mm don't know what it means but its one of the parameters in the
> >> mfgsys.pffile it can be 1024, 2048 or 4096 depending on your setup
> >> *Jose C Gomez*
> >> *Software Engineer*
> >> *T: 904.469.1524 mobile
> >> E: jose@
> >> http://www.josecgomez.com
> >> <http://www.linkedin.com/in/josecgomez> <
> http://www.facebook.com/josegomez>
> >> <http://www.google.com/profiles/jose.gomez> <http://www.twitter.com/joc85
> >> <http://www.josecgomez.com/professional-resume/>
> >> <http://www.josecgomez.com/feed/>
> >> *Quis custodiet ipsos custodes?*
> >> On Wed, Mar 23, 2011 at 1:12 PM, cubcrafters_it <
> >> jason.navarrete@> wrote:
> >> > Very good to know. I see 4GL Dev listed in my test 9.04 and 9.05
> instances,
> >> > so maybe I'll poke around in there more.
> >> > Next question (and apologies to Chris for hijacking his thread, but
> >> > hopefully it's mutually beneficial) -- Jose, what's the link you're
> using on
> >> > the desktop to start the Procedure Editor, that prompts for a password?
> I'm
> >> > now calling the Procedure Editor from the OpenEdge Desktop utility, but
> it
> >> > doesn't prompt to connect to a database, and I'm assuming that might be
> why
> >> > I get a 'Unknown or ambiguous table Customer. (725)' error.
> >> > --- In vantage@yahoogroups.com, "Carl Peterson" <cpeterson@> wrote:
> >> > > The Progress license codes are located in your Progress root
> directory -
> >> > for
> >> > > example, epicor\oe101b and file name is progress.cfg
> >> > > The Progress 4GL Development license, before 9.05, is a chargeable
> and
> >> > > around the price of $1800.00 + 18% maintenance and can be purchased
> from
> >> > > Epicor. You only need a single user version.
> >> > > Carl
> >> > > From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On
> Behalf
> >> > Of
> >> > > cubcrafters_it
> >> > > Sent: Wednesday, March 23, 2011 12:32 PM
> >> > > To: vantage@yahoogroups.com
> >> > > Subject: [Vantage] Re: Making changes in bulk
> >> > > I don't have a link for a Procedure Editor, but I can bring one up
> with
> >> > Data
> >> > > Administration or something similar.
> >> > > But the only license code I got aside from the Epicor License was a
> key
> >> > for
> >> > > Crystal Reports.
> >> > > Any idea what the cost was to step to the 4GL dev license?
> >> > > --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ,
> Jose
> >> > > > Do you have those programs I showed on the video? On progress
> licence
> >> > > codes
> >> > > > one shouold say 4gl Development.
> >> > > > *Jose C Gomez*
> >> > > > *Software Engineer*
> >> > > > E: jose@
> >> > > <http://www.facebook.com/josegomez>
> >> > http://www.twitter.com/joc85>
> >> > > > On Wed, Mar 23, 2011 at 12:08 PM, cubcrafters_it <
> >> > > > > How do you tell if you have the Progress Development License?
> >> > Jose
> >> > > > > > Sure,
> >> > > > > > Do you have the Progress Development Licence?? if so, simply go
> to
> >> > > your
> >> > > > > > server
> >> > > > > > Open your Epicor Admin Tools
> >> > > > > > Go to Run Progress Editor
> >> > > > > > There write a progress query that will accomplish what you want
> for
> >> > > > > example
> >> > > > > > for each jobMethod where jobMethod.Company="YOUR COMPANY":
> >> > > > > > Assign jobMethod.FieldName = "New Value".
> >> > > > > > end.
> >> > > > > > Save your file
> >> > > > > > Go to the Application Compiler under Start -> Open Edge
> >> > > > > > Load your file and compile it, if it compiles without problem
> >> > > > > > Then go back to Epicor Admin Tools and this time Click Run
> Progress
> >> > > > > Program
> >> > > > > > Load your compiled file and run it.
> >> > > > > > As a disclaimer do this in test first and make sure it does
> what
> >> > you
> >> > > > > want.
> >> > > > > > I'll try to put together a video tutorial for you if I have
> time in
> >> > a
> >> > > few
> >> > > > > > minutes.
> >> > > > > > *Jose C Gomez*
> >> > > > > > *Software Engineer*
> >> > > > > > E: jose@
> >> > > > > > On Wed, Mar 23, 2011 at 9:59 AM, Chris Thompson <chriselectrix@
> >> > > > > ...>wrote:
> >> > > > > > > We are progress.
> >> > > > > > > I have no idea how to do what you've just said.
> >> > > > > > > Would you mind giving me a few pointers?
> >> > > > > > > ________________________________
> >> > > > > > > From: Jose Gomez <jose@>
> >> > > > > > > To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com
> >> > > > > > > Sent: Wed, 23 March, 2011 13:55:48
> >> > > > > > > Subject: Re: [Vantage] Making changes in bulk
> >> > > > > > > Progress or SQL?
> >> > > > > > > if so write a Procedure for either and run it. (Easiest I can
> >> > think)
> >> > > > > > > *Jose C Gomez*
> >> > > > > > > *Software Engineer*
> >> > > > > > > E: jose@
> >> > > > > > > On Wed, Mar 23, 2011 at 9:39 AM, Chris Thompson
> <chriselectrix@
> >> > > > > > > >wrote:
> >> > > > > > > > Hi All
> >> > > > > > > > We need to make changes in bulk to hundreds of job methods.
> >> > > > > > > > We need to change a /LID to -LID.
> >> > > > > > > > Is there any EASY way to do this?
> >> > > > > > > > [Non-text portions of this message have been removed]
> >> > > > > > > Useful links for the Yahoo!Groups Vantage Board are: ( Note:
> You
> >> > > must
> >> > > > > have
> >> > > > > > > already linked your email address to a yahoo id to enable
> access.
> >> > > > > > > (1) To access the Files Section of our Yahoo!Group for Report
> >> > > Builder
> >> > > > > and
> >> > > > > > > Crystal Reports and other 'goodies', please goto:
> >> > > > > > > http://groups.yahoo.com/group/vantage/files/.
> >> > > <http://groups.yahoo.com/group/vantage/files/>
> >> > > > > > > (2) To search through old msg's goto:
> >> > > > > > > http://groups.yahoo.com/group/vantage/messages
> >> > > > > > > (3) To view links to Vendors that provide Vantage services
> goto:
> >> > > > > > > http://groups.yahoo.com/group/vantage/linksYahoo! Groups
> Links
