Making changes in bulk
I use this method as well. I use the ABC Code table as opposed to the Company table, but same logic applies. I believe I got this little trick from Rob Bucek. Thanks again Rob.
--- In vantage@yahoogroups.com, "Kevin Simon" <ksimon@...> wrote:
> I don't know if you ever said what version you're on, but by one of the
> versions (it may be 9.04), you no longer need the license - it's bundled
> with the software.
> What I've done for one time programs, which I find a lot easier than
> compiling programs, etc, is I have a checkbox on the Company form, and I
> have a BPM that triggers when the checkbox changes and it's being run by me.
> Then, I simply insert my code in the advanced, 4GL section, open company
> maint and click the box.
> Kevin Simon
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of
> cubcrafters_it
> Sent: Wednesday, March 23, 2011 7:06 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: Making changes in bulk
> Thanks! That's what I needed.
> I got a quote back from my CAM for $3600 + $720 maintenance for OpenEdge
> Architect (for OpenEdge 10.2a). Any idea how that differs from the Dev
> license?
> --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , Jose
> Gomez <jose@> wrote:
> > This si the link for the editor
> > "C:\Program Files\epicor\oe101c\bin\prowin32.exe" -db "C:\Program
> > Files\Epicor Software\Epicor904\db\Test\mfgsys.db" -S 9020 -H disraeli -N
> > TCP -Mm 1024
> > This is the link for the compiler
> > "C:\Program Files\epicor\oe101c\bin\prowin32.exe" -p _comp.p -db
> > "C:\Program Files\Epicor Software\Epicor904\db\mfgsys.db" -S 9020 -H
> > disraeli -N TCP -Mm 1024
> > S= DB Port
> > H Host
> > -Mm don't know what it means but its one of the parameters in the
> > mfgsys.pffile it can be 1024, 2048 or 4096 depending on your setup
> > *Jose C Gomez*
> > *Software Engineer*
> > *T: 904.469.1524 mobile
> > E: jose@
> > http://www.josecgomez.com
> > <http://www.linkedin.com/in/josecgomez>
> <http://www.facebook.com/josegomez>
> > <http://www.google.com/profiles/jose.gomez> <http://www.twitter.com/joc85>
> > <http://www.josecgomez.com/professional-resume/>
> > <http://www.josecgomez.com/feed/>
> > *Quis custodiet ipsos custodes?*
> > On Wed, Mar 23, 2011 at 1:12 PM, cubcrafters_it <
> > jason.navarrete@> wrote:
> > > Very good to know. I see 4GL Dev listed in my test 9.04 and 9.05
> instances,
> > > so maybe I'll poke around in there more.
> > > Next question (and apologies to Chris for hijacking his thread, but
> > > hopefully it's mutually beneficial) -- Jose, what's the link you're
> using on
> > > the desktop to start the Procedure Editor, that prompts for a password?
> I'm
> > > now calling the Procedure Editor from the OpenEdge Desktop utility, but
> it
> > > doesn't prompt to connect to a database, and I'm assuming that might be
> why
> > > I get a 'Unknown or ambiguous table Customer. (725)' error.
> "Carl Peterson" <cpeterson@> wrote:
> > > > The Progress license codes are located in your Progress root directory
> > > for
> > > > example, epicor\oe101b and file name is progress.cfg
> > > > The Progress 4GL Development license, before 9.05, is a chargeable and
> > > > around the price of $1800.00 + 18% maintenance and can be purchased
> from
> > > > Epicor. You only need a single user version.
> > > > Carl
> > > > From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
> Behalf
> > > Of
> > > > cubcrafters_it
> > > > Sent: Wednesday, March 23, 2011 12:32 PM
> > > > To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> > > > I don't have a link for a Procedure Editor, but I can bring one up
> with
> > > Data
> > > > Administration or something similar.
> > > > But the only license code I got aside from the Epicor License was a
> key
> > > for
> > > > Crystal Reports.
> > > > Any idea what the cost was to step to the 4GL dev license?
> > > > > Do you have those programs I showed on the video? On progress
> licence
> > > > codes
> > > > > one shouold say 4gl Development.
> > > > > *Jose C Gomez*
> > > > > *Software Engineer*
> > > > > E: jose@
> > > > > On Wed, Mar 23, 2011 at 12:08 PM, cubcrafters_it <
> > > > > > How do you tell if you have the Progress Development License?
> > > Jose
> > > > > > > Sure,
> > > > > > > Do you have the Progress Development Licence?? if so, simply go
> to
> > > > your
> > > > > > > server
> > > > > > > Open your Epicor Admin Tools
> > > > > > > Go to Run Progress Editor
> > > > > > > There write a progress query that will accomplish what you want
> for
> > > > > > example
> > > > > > > for each jobMethod where jobMethod.Company="YOUR COMPANY":
> > > > > > > Assign jobMethod.FieldName = "New Value".
> > > > > > > end.
> > > > > > > Save your file
> > > > > > > Go to the Application Compiler under Start -> Open Edge
> > > > > > > Load your file and compile it, if it compiles without problem
> > > > > > > Then go back to Epicor Admin Tools and this time Click Run
> Progress
> > > > > > Program
> > > > > > > Load your compiled file and run it.
> > > > > > > As a disclaimer do this in test first and make sure it does what
> > > you
> > > > > > want.
> > > > > > > I'll try to put together a video tutorial for you if I have time
> in
> > > a
> > > > few
> > > > > > > minutes.
> > > > > > > *Jose C Gomez*
> > > > > > > *Software Engineer*
> > > > > > > E: jose@
> > > > > > > <http://www.linkedin.com/in/josecgomez> <
> > > > > > > On Wed, Mar 23, 2011 at 9:59 AM, Chris Thompson <chriselectrix@
> > > > > > ...>wrote:
> > > > > > > > We are progress.
> > > > > > > > I have no idea how to do what you've just said.
> > > > > > > > Would you mind giving me a few pointers?
> > > > > > > > ________________________________
> > > > > > > > From: Jose Gomez <jose@>
> > > > > > > > Sent: Wed, 23 March, 2011 13:55:48
> > > > > > > > Subject: Re: [Vantage] Making changes in bulk
> > > > > > > > Progress or SQL?
> > > > > > > > if so write a Procedure for either and run it. (Easiest I can
> > > think)
> > > > > > > > *Jose C Gomez*
> > > > > > > > *Software Engineer*
> > > > > > > > E: jose@
> > > > > > > > On Wed, Mar 23, 2011 at 9:39 AM, Chris Thompson
> <chriselectrix@
> > > > > > > > >wrote:
> > > > > > > > > Hi All
> > > > > > > > > We need to make changes in bulk to hundreds of job methods.
> > > > > > > > > We need to change a /LID to -LID.
> > > > > > > > > Is there any EASY way to do this?
> > > > > > > > > [Non-text portions of this message have been removed]
> > > > > > > > Useful links for the Yahoo!Groups Vantage Board are: ( Note:
> You
> > > > must
> > > > > > have
> > > > > > > > already linked your email address to a yahoo id to enable
> access.
> > > > > > > > (1) To access the Files Section of our Yahoo!Group for Report
> > > > Builder
> > > > > > and
> > > > > > > > Crystal Reports and other 'goodies', please goto:
> > > > > > > > http://groups.yahoo.com/group/vantage/files/.
> <http://groups.yahoo.com/group/vantage/files/>
> > > > > > > > (2) To search through old msg's goto:
> > > > > > > > http://groups.yahoo.com/group/vantage/messages
> > > > > > > > (3) To view links to Vendors that provide Vantage services
> goto:
> > > > > > > > http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
Hi All
Progress or SQL?
if so write a Procedure for either and run it. (Easiest I can think)
*Jose C Gomez*
*Software Engineer*
E: jose@...
On Wed, Mar 23, 2011 at 9:39 AM, Chris Thompson <chriselectrix@...>wrote:
> Hi All
We are progress.
Progress or SQL?
*Jose C Gomez*
*Software Engineer*
E: jose@...
<http://www.linkedin.com/in/josecgomez>Â <http://www.facebook.com/josegomez>
> Hi All
Useful links for the Yahoo!Groups Vantage Board are: ( Note:Â You must have
http://groups.yahoo.com/group/vantage/files/.%c2%a0
Sure,
Do you have the Progress Development Licence?? if so, simply go to your
server
There write a progress query that will accomplish what you want for example
end.
Save your file
Then go back to Epicor Admin Tools and this time Click Run Progress Program
As a disclaimer do this in test first and make sure it does what you want.
I'll try to put together a video tutorial for you if I have time in a few
minutes.
*Jose C Gomez*
*Software Engineer*
E: jose@...
On Wed, Mar 23, 2011 at 9:59 AM, Chris Thompson <chriselectrix@...>wrote:
> We are progress.
> From: Jose Gomez <jose@...>
> Progress or SQL?
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> >wrote:
> > Hi All
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have
The difficulty is, the text that needs changing is in the middle of a much
larger text section (within the same field)
Sent: Wed, 23 March, 2011 14:08:56
Sure,
server
end.
Save your file
minutes.
*Jose C Gomez*
*Software Engineer*
E: jose@...
> We are progress.
> Progress or SQL?
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
>Â <http://www.google.com/profiles/jose.gomez> <
>Â <http://www.josecgomez.com/professional-resume/>
> >wrote:
> > Hi All
Jose, that would be so much easier in MSSQL. :-) :-)
Of Jose Gomez
Sent: Wednesday, March 23, 2011 10:09 AM
Sure,
server
example
end.
Save your file
Program
want.
few
minutes.
*Jose C Gomez*
*Software Engineer*
E: jose@...
> We are progress.
> Progress or SQL?
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
<chriselectrix@...
> >wrote:
> > Hi All
have
and
haha nice one Vic ;-)
You can use a find and replace function if its in the middle of other texts
for example
FOR EACH Customer WHERE Customer.CustID="9046351996":
ASSIGN
Customer.Name = Replace(Customer.Name,"Jose","Pete").
END.
*Jose C Gomez*
*Software Engineer*
E: jose@...
> Of Jose Gomez
> Sure,
> server
> example
> end.
> Save your file
> Program
> want.
> few
> minutes.
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > We are progress.
> > Progress or SQL?
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> <chriselectrix@...
> > >wrote:
> > > Hi All
> have
> and
Here is a Quick video tutorial I threw together, its kinda fast so watch
several times if you need(it may take a few minitues to be available as it
is processing. Chage the resolution to HD so that you can see better.
Again here goes the disclaimer
*If you break your DB and or destroy the world I am not responsible! I am
letting you know how to do it, but I can in no way be liable for what the
code you write will do. Make sure you run it in test first,*
http://www.youtube.com/watch?v=4Dv295qg3FY
*Jose C Gomez*
*Software Engineer*
E: jose@...
> for example
> ASSIGN
> END.
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> <http://www.josecgomez.com/professional-resume/> <http://www.josecgomez.com/feed/>
>> Of Jose Gomez
>> Sure,
>> server
>> example
>> end.
>> Save your file
>> Program
>> want.
>> few
>> minutes.
>> *Jose C Gomez*
>> *Software Engineer*
>> E: jose@...
>> > We are progress.
>> > Progress or SQL?
>> > *Jose C Gomez*
>> > *Software Engineer*
>> > E: jose@...
>> <chriselectrix@...
>> > >wrote:
>> > > Hi All
>> have
>> and
--- In vantage@yahoogroups.com, Jose Gomez <jose@...> wrote:
> Sure,
> server
> end.
> Save your file
> minutes.
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > We are progress.
> > Progress or SQL?
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> > >wrote:
> > > Hi All
Do you have those programs I showed on the video? On progress licence codes
*Jose C Gomez*
*Software Engineer*
E: jose@...
> > Sure,
> > server
> example
> > end.
> > Save your file
> Program
> want.
> > minutes.
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> ...>wrote:
> > > We are progress.
> > > Progress or SQL?
> > > *Jose C Gomez*
> > > *Software Engineer*
> > > E: jose@...
> > > >wrote:
> > > > Hi All
> have
> and
I don't have a link for a Procedure Editor, but I can bring one up with Data Administration or something similar.
But the only license code I got aside from the Epicor License was a key for Crystal Reports.
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > --- In vantage@yahoogroups.com, Jose Gomez <jose@> wrote:
> > > Sure,
> > > server
> > example
> > > end.
> > > Save your file
> > Program
> > want.
> > > minutes.
> > > *Jose C Gomez*
> > > *Software Engineer*
> > > E: jose@
> > ...>wrote:
> > > > We are progress.
> > > > Progress or SQL?
> > > > *Jose C Gomez*
> > > > *Software Engineer*
> > > > E: jose@
> > > > >wrote:
> > > > > Hi All
> > have
> > and
Not sure what the cost was. You don't have a list of progress license
codes/?
Sent from mobile
On Mar 23, 2011 12:32 PM, "cubcrafters_it" <jason.navarrete@...>
codes
>> *Jose C Gomez*
>> *Software Engineer*
>> E: jose@...
>> > > Sure,
your
>> > > server
>> > example
>> > > end.
>> > > Save your file
>> > Program
>> > want.
few
>> > > minutes.
>> > > *Jose C Gomez*
>> > > *Software Engineer*
>> > > E: jose@
>> > ...>wrote:
>> > > > We are progress.
>> > > > Progress or SQL?
think)
>> > > > *Jose C Gomez*
>> > > > *Software Engineer*
>> > > > E: jose@
>> > > > >wrote:
>> > > > > Hi All
must
>> > have
Builder
>> > and
The Progress license codes are located in your Progress root directory - for
around the price of $1800.00 + 18% maintenance and can be purchased from
Carl
cubcrafters_it
Crystal Reports.
codes
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > > Sure,
your
> > > server
> > example
> > > end.
> > > Save your file
> > Program
> > want.
few
> > > minutes.
> > > *Jose C Gomez*
> > > *Software Engineer*
> > > E: jose@
> > ...>wrote:
> > > > We are progress.
> > > > Progress or SQL?
> > > > *Jose C Gomez*
> > > > *Software Engineer*
> > > > E: jose@
> > > > >wrote:
> > > > > Hi All
must
> > have
Builder
> > and
Nope. The only Progress license codes I have are the ones from EpicWeb for the OpenEdge Management tool.
And I tried to check syntax on a test procedure and I get 'This version of PROGRESS compiles only encrypted programs. (1086).'
> codes/?
> Sent from mobile
> codes
> >> *Jose C Gomez*
> >> *Software Engineer*
> >> E: jose@
> >> > > Sure,
> your
> >> > > server
> >> > example
> >> > > end.
> >> > > Save your file
> >> > Program
> >> > want.
> few
> >> > > minutes.
> >> > > *Jose C Gomez*
> >> > > *Software Engineer*
> >> > > E: jose@
> >> > ...>wrote:
> >> > > > We are progress.
> >> > > > Progress or SQL?
> think)
> >> > > > *Jose C Gomez*
> >> > > > *Software Engineer*
> >> > > > E: jose@
> >> > > > >wrote:
> >> > > > > Hi All
> must
> >> > have
> Builder
> >> > and
Very good to know. I see 4GL Dev listed in my test 9.04 and 9.05 instances, so maybe I'll poke around in there more.
Next question (and apologies to Chris for hijacking his thread, but hopefully it's mutually beneficial) -- Jose, what's the link you're using on the desktop to start the Procedure Editor, that prompts for a password? I'm now calling the Procedure Editor from the OpenEdge Desktop utility, but it doesn't prompt to connect to a database, and I'm assuming that might be why I get a 'Unknown or ambiguous table Customer. (725)' error.
> Carl
> cubcrafters_it
> Crystal Reports.
> codes
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@
> > > > Sure,
> your
> > > > server
> > > example
> > > > end.
> > > > Save your file
> > > Program
> > > want.
> few
> > > > minutes.
> > > > *Jose C Gomez*
> > > > *Software Engineer*
> > > > E: jose@
> > > ...>wrote:
> > > > > We are progress.
> > > > > Progress or SQL?
> > > > > *Jose C Gomez*
> > > > > *Software Engineer*
> > > > > E: jose@
> > > > > >wrote:
> > > > > > Hi All
> must
> > > have
> Builder
> > > and
TCP -Mm 1024
S= DB Port
H Host
*Jose C Gomez*
*Software Engineer*
E: jose@...
> for
> > Carl
> Of
> > cubcrafters_it
> Data
> for
> > Crystal Reports.
> > codes
> > > *Jose C Gomez*
> > > *Software Engineer*
> > > E: jose@
> Jose
> > > > > Sure,
> > your
> > > > > server
> > > > example
> > > > > end.
> > > > > Save your file
> > > > Program
> you
> > > > want.
> a
> > few
> > > > > minutes.
> > > > > *Jose C Gomez*
> > > > > *Software Engineer*
> > > > > E: jose@
> > > > ...>wrote:
> > > > > > We are progress.
> > > > > > Progress or SQL?
> think)
> > > > > > *Jose C Gomez*
> > > > > > *Software Engineer*
> > > > > > E: jose@
> > > > > > >wrote:
> > > > > > > Hi All
> > must
> > > > have
> > Builder
> > > > and
I got a quote back from my CAM for $3600 + $720 maintenance for OpenEdge Architect (for OpenEdge 10.2a). Any idea how that differs from the Dev license?
> TCP -Mm 1024
> S= DB Port
> H Host
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > for
> > > Carl
> > Of
> > > cubcrafters_it
> > Data
> > for
> > > Crystal Reports.
> > > codes
> > > > *Jose C Gomez*
> > > > *Software Engineer*
> > > > E: jose@
> > Jose
> > > > > > Sure,
> > > your
> > > > > > server
> > > > > example
> > > > > > end.
> > > > > > Save your file
> > > > > Program
> > you
> > > > > want.
> > a
> > > few
> > > > > > minutes.
> > > > > > *Jose C Gomez*
> > > > > > *Software Engineer*
> > > > > > E: jose@
> > > > > ...>wrote:
> > > > > > > We are progress.
> > > > > > > Progress or SQL?
> > think)
> > > > > > > *Jose C Gomez*
> > > > > > > *Software Engineer*
> > > > > > > E: jose@
> > > > > > > >wrote:
> > > > > > > > Hi All
> > > must
> > > > > have
> > > Builder
> > > > > and
Open edge architect is an IDE for progress. Very nice but not necessary.
You'll still need the dev license.
Ps we paid much less for it
Sent from mobile
On Mar 23, 2011 7:07 PM, "cubcrafters_it" <jason.navarrete@...>
license?
>> TCP -Mm 1024
>> S= DB Port
>> H Host
>> *Jose C Gomez*
>> *Software Engineer*
>> E: jose@...
instances,
using on
I'm
it
why
directory -
>> > for
and
from
>> > > Carl
Behalf
>> > Of
>> > > cubcrafters_it
with
>> > Data
key
>> > for
>> > > Crystal Reports.
Jose
licence
>> > > codes
>> > > > *Jose C Gomez*
>> > > > *Software Engineer*
>> > > > E: jose@
>> > Jose
>> > > > > > Sure,
to
>> > > your
>> > > > > > server
for
>> > > > > example
>> > > > > > end.
>> > > > > > Save your file
Progress
>> > > > > Program
what
>> > you
>> > > > > want.
time in
>> > a
>> > > few
>> > > > > > minutes.
>> > > > > > *Jose C Gomez*
>> > > > > > *Software Engineer*
>> > > > > > E: jose@
>> > > > > ...>wrote:
>> > > > > > > We are progress.
>> > > > > > > Progress or SQL?
>> > think)
>> > > > > > > *Jose C Gomez*
>> > > > > > > *Software Engineer*
>> > > > > > > E: jose@
<chriselectrix@
>> > > > > > > >wrote:
>> > > > > > > > Hi All
You
>> > > must
>> > > > > have
access.
>> > > Builder
>> > > > > and
goto:
Links
with the software.
Kevin Simon
cubcrafters_it
license?
> TCP -Mm 1024
> S= DB Port
> H Host
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
instances,
using on
I'm
it
why
> > for
from
> > > Carl
Behalf
> > Of
> > > cubcrafters_it
with
> > Data
key
> > for
> > > Crystal Reports.
licence
> > > codes
> > > > *Jose C Gomez*
> > > > *Software Engineer*
> > > > E: jose@
> > Jose
> > > > > > Sure,
to
> > > your
> > > > > > server
for
> > > > > example
> > > > > > end.
> > > > > > Save your file
Progress
> > > > > Program
> > you
> > > > > want.
in
> > a
> > > few
> > > > > > minutes.
> > > > > > *Jose C Gomez*
> > > > > > *Software Engineer*
> > > > > > E: jose@
> > > > > ...>wrote:
> > > > > > > We are progress.
> > > > > > > Progress or SQL?
> > think)
> > > > > > > *Jose C Gomez*
> > > > > > > *Software Engineer*
> > > > > > > E: jose@
<chriselectrix@
> > > > > > > >wrote:
> > > > > > > > Hi All
You
> > > must
> > > > > have
access.
> > > Builder
> > > > > and
goto:
