OpenEdge 4GL Lite
I'm not sure if it applies to 9.04, but I would be surprised if it didn't. I'm not sure how it would affect the SQL version since the Progress DB in the SQL version is just a schema holder. The license is a special 4gl OpenEdge developers license for Epicor. It allows you to directly add, delete, and update the Progress databases from 4gl without having to go through the business objects.
Â
My first project with it in 8.03 was a BPM that would automatically add a "dropship" shipto address to the customer from the process command in Demand for incoming EDI orders. This way our Customer Service department didn't have to manually add the shipto address to the order after processing the EDI demand, thus saving time. Without the new license I would have had to use Service Connect to add the shipto address, a much more complicated and time consuming process. Of course in 9.04 you don't have this problem since it supports the use of one time shipto address, but you get the idea.
Sent: Tue, April 27, 2010 5:26:00 PM
Subject: [Vantage] Re: OpenEdge 4GL Lite
Â
Can you tell me a little more about the "new" license? What do you mean direct Add/Updates to tables? Does this only apply to Progess DB version? I see both OpenEdge 10.1b and 10.1c mentioned so does this apply to both 8.03 and 9.04?
Jared
--- In vantage@yahoogroups .com, Joe Rojas <jrojas@...> wrote:
> So I got the license codes for the new OpenEdge licensing that allows
> for direct Adds and Updates to Vantage/Epicor tables.
> What the document didn't say was how to install the new licenses. Anyone
> using this new license? If so, how did you install it?
> Joe Rojas | Director of Information Technology | Mats Inc
> dir: 781-573-0291 | cell: 781-408-1264 | fax: 781-341-5694
> jrojas@... | www.matsinc. com Ask us about our clean, green and beautiful matting and flooring
> This message is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake. Please note that any views or opinions presented in this email are solely those of the author and do not necessarily represent those of the company.
jrojas@... | www.matsinc.com Ask us about our clean, green and beautiful matting and flooring
Joe,
I am running the new OpenEdge licensing for 10.1b. I only had to replace the
progess.cfg file then stopped and restarted progress for the new license to
take effect.
Steve
Sent: Monday, April 26, 2010 7:47 PM
Subject: [Vantage] OpenEdge 4GL Lite
jrojas@matsinc. <mailto:jrojas%40matsinc.com> com | www.matsinc.com Ask us
of the company.
The best way to do it is on a separate server. If you call the help desk, you may be able to find someone to help. You first have to uninstall openedge if it is installed, and then install it from your Vantage CD. Use the advanced options and the new license you received. After the installation, make a backup of your progress.cfg found on your live server (epicor\oe101b\progress.cfg), shut down the services, databases, and Adminservice for OpenEdge. Copy the progress.cfg from the first server to your live server then start everything back up on your live server.
Sent: Mon, April 26, 2010 8:47:22 PM
Â
jrojas@matsinc. com | www.matsinc. com Ask us about our clean, green and beautiful matting and flooring
I have use the following, too, to upgrade a run-time Progress license to the 4GL Development license.
Summary:
Start server in safe mode -- press F8 when booting up – Just a suggestion
Create the following directories on your X drive – Replace X with your Disk Id
X:\epi-backup\properties
X:\epi-backup\config
Copy the following files for backup
Copy X:\epicor\oe101b\properties\*.* X:\epi-backup\properties
Copy X:\epicor\mfgsys803\server\config\*.* X:\epi-backup\config
Copy X:\epicor\oe101b\startup.pf X:\epi-backup
Insert Progress 10.1B disk in CD drive
Type in the serial number and control numbers when prompted
Use X:\epicor\oe101b as the directory for Progress
Use X:\epicor\oe101b_wrk as work directory
Follow the prompts until installed
Install Progress Service Pack(s)
Copy back the properties, config, and startup.pf files
Copy X:\epi-backup\properties\*.* X:\epicor\oe101b\properties
Copy X:\epi-backup\\config\*.* X:\epicor\mfgsys803\server\config
Copy X:\epi-backup\startup.pf X:\epicor\oe101b
Be careful.
Carl Peterson
Nexus Software, Inc.
1-734-453-3101
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Steven Gotschall
Sent: Tuesday, April 27, 2010 8:29 AM
Subject: Re: [Vantage] OpenEdge 4GL Lite
From: Joe Rojas <jrojas@... <mailto:jrojas%40matsinc.com> >
Joe,
Progress apparently made no provision to add incremental licensing capabilities after you get started on Progress/Vantage. I found that (doing it on a test server 1st), I had to backup the database, stop the app and database server, uninstall Vantage and uninstall OpenEdge. Now Re-install OpenEdge but armed with this new license, add it in, re-install service pack & hotfixes, re-install Vantage with patches and then reload the database and with fingers crossed start the database and app servers.
A royal pain just to add that licensing ability. If Steve E is right that he just edited the cfg file, and did none of the above, that will really tick me off!! :)
-Karl
Sent: Mon, April 26, 2010 5:47:22 PM
Â
Where did you get the new progress.cfg file?
Brian W. Spolarich ~ Manager, Information Services ~ Advanced Photonix / Picometrix
    bspolarich@... ~ 734-864-5618 ~ www.advancedphotonix.com
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Steve_E
Sent: Tuesday, April 27, 2010 8:18 AM
Subject: RE: [Vantage] OpenEdge 4GL Lite
Joe,
take effect.
Steve
of the company.
The only thing I received from Epicor was a PDF that had the new code in
it.
Of Brian W. Spolarich
Sent: Tuesday, April 27, 2010 11:36 AM
Picometrix
bspolarich@...
<mailto:bspolarich%40advancedphotonix.com> ~ 734-864-5618 ~
Behalf Of Steve_E
Joe,
the
to
take effect.
Steve
From: Joe Rojas [mailto:jrojas@... <mailto:jrojas%40matsinc.com>
us
the
e-mail.
this
those
of the company.
I was able to get the progress.cfg file from support. All you have to do is
rename the old file and place the new file in its location and stop and
restart progress.
Steve
Sent: Tuesday, April 27, 2010 10:36 AM
Picometrix
bspolarich@advanced <mailto:bspolarich%40advancedphotonix.com>
photonix.com ~ 734-864-5618 ~ www.advancedphotonix.com
From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
[mailto:vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com] On
Behalf Of Steve_E
To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
Joe,
take effect.
Steve
From: Joe Rojas [mailto:jrojas@matsinc. <mailto:jrojas%40matsinc.com> com]
of the company.
http://groups. <http://groups.yahoo.com/group/vantage/linksYahoo>
I just called support and they won't give me the progress.cfg file
because it doesn't always work.
He said I would have to uninstall and reinstall OpenEdge.
To be honest, I don't know if I want to do that.... :(
Of Steve_E
Sent: Tuesday, April 27, 2010 11:52 AM
is
restart progress.
Steve
<mailto:bspolarich%40advancedphotonix.com> ]
Picometrix
Behalf Of Steve_E
Joe,
the
to
take effect.
Steve
com]
us
the
e-mail.
this
those
of the company.
have
and
<http://groups.yahoo.com/group/vantage/files/> >
You need to make sure you back up all your Vantage and Progress config property files first or you will lose your Progress server settings if you try to do an incremental Progress upgrade. The progress.cfg file is located in your oe101b or oe10c directory and contains a list of all the Progress licenses YOUR company has purchased. It is a .txt file but not modifiable. This file is updated when you load your new Progress license.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Karl Dash
Sent: Tuesday, April 27, 2010 11:09 AM
Joe,
-Karl
And if I rember correctly, you run setup out of the OE folder on the disc, not the setup in the root of the disc.
> Joe,
> -Karl
There is a MUCH MUCH easier way to do this. Go to 'add components' in the
start menu under 'open edge' it will start the setup program, you can enter
the new codes and be back online in 15 minutes.
You will need to take the DB offline while you do this, but it's pretty
quick and painless.
> --- In vantage@yahoogroups.com <vantage%40yahoogroups.com>, "Carl
> > From: vantage@yahoogroups.com <vantage%40yahoogroups.com> [mailto:
> vantage@yahoogroups.com <vantage%40yahoogroups.com>] On Behalf Of Karl
> Dash
> > To: vantage@yahoogroups.com <vantage%40yahoogroups.com>
> > Joe,
> tick me off!! :)
> > -Karl
> > From: Joe Rojas <jrojas@... <mailto:jrojas%40matsinc.com<jrojas%2540matsinc.com>>
> > To: vantage@yahoogroups.com <vantage%40yahoogroups.com> <mailto:
> vantage%40yahoogroups.com <vantage%2540yahoogroups.com>>
WOW.
Did you do this, specifically, to add the "new" OpenEdge license?
If it's this simple, why doesn't Epicor now about it?
Of Waffqle Driggers
Sent: Tuesday, April 27, 2010 12:58 PM
Subject: Re: [Vantage] Re: OpenEdge 4GL Lite
the
enter
quick and painless.
disc,
config
you
located
Progress
modifiable.
> Dash
> > Joe,
(doing
and
Re-install
service pack
database and
that
really
> tick me off!! :)
> > -Karl
allows
Anyone
and
not
this
received
presented in
represent
Do not get me going, Joe!
I look forward to your call!
Sent from my iPhone
1-734-812-9532 - cell#
On Apr 27, 2010, at 1:03 PM, Joe Rojas <jrojas@...> wrote:
> WOW.
> Behalf
> Of Waffqle Driggers
> the
> enter
> pretty
> quick and painless.
> disc,
> config
> settings if
> you
> located
> Progress
> modifiable.
> Karl
> > Dash
> > > Joe,
> (doing
> and
> Re-install
> service pack
> database and
> right
> that
> really
> > tick me off!! :)
> > > -Karl
> allows
> Anyone
> green
> and
> not
> this
> received
> presented in
> represent
> access. )
When I was talking to tech support about this, we tried the "Add Components" and it didn't work. The tech told me most of the time it won't work to add this license, but he has seen it work in a few cases. Must be dependent on what license you started with.
Sent: Tue, April 27, 2010 12:57:52 PM
quick and painless.
> Dash
> > Joe,
> tick me off!! :)
> > -Karl
Useful links for the Yahoo!Groups Vantage Board are: ( Note:Â You must have already linked your email address to a yahoo id to enable access. )
(1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/.%c2%a0
Jared
