Mattec MES integration
Has anyone done this that can offer some insight? Anyone aware of a manual that details this?
Not very helpful:
External MES Fields
Navigate to this sheet/program:
Site Configuration Control > Modules > Production Management > External MES
Some fields on the interface have a context menu, which is indicated by a triangle in the upper right corner of the field. To open the context menu, right-click on the field.
Parent topic: External MES
External MES Integration
Select this check box to enable external MES integration for this site. If you select this check box, all this fields located in this sheet activate.
External MES Type
Select the external MES with which you want this Site to integrate.
Input Location
Specifies the location for the data flow from the external MES into the Epicor application.
Input Location …
Click this button to search for and select the location for the data flow from the external MES into the Epicor application.
Output Location
Specifies the location for the data flow from the Epicor application into the external MES.
Output Location …
Click this button to search for and select the location for the data flow from the Epicor application into the external MES.
We’ve used the MES integration for a custom application no Mattec MES. The external MES and Epicor communicate via csv files in defined drop folder locations.
Here’s a [link]
(https://epicweb.epicor.com/doc/Docs/Epicor10_MattecMES_DataIntegration_1007004.pdf#search=mattec) to a pdf detailing the setup between Mattec and Epicor.
Thanks for the input and the link!
