Need help on a Method Directive setting defaults on the PartPlant table from part entry.
What I have. Pre-Processing on the ttPart table with alt least one updated row that leads to a post directive.
Post Directive
Condition Enabled from PreProcessing directive above
Msg box “post Process Started” passed
Invoke BO Method Erp.Part.Update
Msg Box “Details from Part plant table” all passed
Set Field ttPartPlant.LeadTime All Rows value 7
Msg box Details from Set field passed
At this point in the UI the LeadTime field on the Part > Sites > Detail tab shows 7 days, but if I close out or refresh it resets to 0. What am I missing?
I agree the Set field needs to be before the update. Maybe try calling the UpdateExt method. Your most likely running into trouble b/c you on the ttPart table when making the update so that’s the temp table that you have available but you’re trying to update the Part Plant Table. You might have better luck if you make some update on the part plant table and then set the field at that time.
