Method directive, Post-processing, ABL sending email is slow
The BPM Action process is running and it creates the log file
here is the log entries for the time the BPM was fired but no email came tru
05/30/13 13:18:20 BPM Action Process - Processing
05/30/13 13:18:20 BPM Action Process - AblActionType #8 - Starting action
05/30/13 13:18:21 BPM Action Process - AblActionType #8 - Action completed
05/30/13 13:18:21 BPM Action Process - Completed
On Wed, May 29, 2013 at 3:11 PM, Ephraim Feldman <effgroups@...>wrote:
> 9.05.701
> On 2013-05-29 2:40 PM, "Miguel Santillan" <msantillan@...> wrote:
>> Ephraim, what version you running?
>> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf
>> Of upworth
>> Sent: Wednesday, May 29, 2013 11:00 AM
>> To: vantage@yahoogroups.com
>> Subject: [Vantage] Re: Method directive, Post-processing, ABL sending
>> email is slow
>> If the only change you are making is from synch to asynch, then it should
>> work. You may want to verify that the BPM Asynch process is actually
>> running. Open your System Monitor, select 'Actions-->Display All Tasks',
>> then look under the 'Scheduled Tasks' tab. You should see the task there,
>> probably called 'BPM Action Process'. Every time it runs, it reschedules
>> based on the time Delay you specified. If it's not there, then it's not
>> running continuously.
>> Jonathan
>> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>,
>> Ephraim Feldman <effgroups@...<mailto:effgroups@...>> wrote:
>> > Thanks Jonathan
>> > I have tested it and it works when run synchronously but when i set it
>> to
>> > async it doesn't even though the BPM action process is started.
>> > Could it be possible the reason because I have a pop up message as part
>> of
>> > the BPM?
>> > Ephraim
>> > On 2013-05-29 8:39 AM, "upworth" <Upworth@...<mailto:Upworth@...>>
>> wrote:
>> > > If you haven't dont so, I would suggest that you first run the ABL
>> > > synchronously to verify that it works. I have found troubleshooting
>> to be
>> > > more efficient this way. Once the email is sending like you want it,
>> then
>> > > change it to send asynchronously. (Forgive me, if you've already done
>> this.)
>> > > My situation was that the emails worked synchronously but not
>> > > asynchronously. The fix (per a recommendation from Greg in this
>> forum) was
>> > > to run 'System Management-->Business Process Management-->General
>> > > Operations-->Action Process'. My admin took care of this for me and
>> set
>> > > this process to run on startup and "fire" every 5 mins. So, now,
>> every 5
>> > > mins the 'Action Process' runs and sends any emails that were queued
>> via my
>> > > ABL code.
>> > > However, if you are having trouble sending email synchronously, let me
>> > > know and I'll post the ABL code I used.
>> > > Jonathan
>> > > Business Process Manager
>> Ephraim Feldman <effgroups@> wrote:
>> > > > Can you please detail me how you did it
>> > > > I did the same but my emails doesn't get send.
>> > > > On 2013-05-28 9:06 AM, "upworth" <Upworth@> wrote:
>> > > > > PROBLEM SOLVED! My Admin started the 'BPM Action process' and the
>> > > emails
>> > > > > send asynch now. Thanks, Greg!
>> > > > > > Thanks, Greg. I'll check with my Admin about that. It sounds
>> like
>> > > this
>> > > > > could be the solution I'm looking for. I'll let you know.
>> > > > > > Jonathan
>> Greg Payne <gpayne@> wrote:
>> > > > > > > For async to work you need the BPM Action process running at
>> > > startup.
>> > > > > In 9.05 is it under Sys management > business Process Management
>> > GO.
>> > > > > > > The time delay is the conversation with the email server, so
>> if you
>> > > > > control the email side you can work on the settings to go faster.
>> > > Another
>> > > > > option is to use IIS or another email server to offload the
>> message and
>> > > > > then relay for Epicor to the primary email server.
>> > > > > > > Greg Payne
>> > > > > > > From: vantage@yahoogroups.com<mailto:
>> vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:
>> vantage%40yahoogroups.com>] On
>> > > > > Behalf Of upworth
>> > > > > > > Sent: Friday, May 24, 2013 10:07 AM
>> > > > > > > To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>
>> > > > > > > Subject: [Vantage] Method directive, Post-processing, ABL
>> sending
>> > > > > email is slow
>> > > > > > > I have created a post-processing method directive that is
>> working
>> > > as
>> > > > > intended except it takes too long. I will be grateful for any
>> help you
>> > > can
>> > > > > provide to speed this up. Below is the situation.
>> > > > > > > The 'Action' is executing ABL code. I have narrowed the
>> performance
>> > > > > problem down to the "run SendEmail" line (see below). I know this
>> > > because I
>> > > > > substituted the "run SendEmail" command with a "display message
>> to the
>> > > > > screen" command and the performance is significantly better.
>> > > > > > > speed test:
>> > > > > > > -No method directive : <2 secs
>> > > > > > > -With 'show message' line : 3-4 secs
>> > > > > > > -With 'send email' line : 11-12 secs
>> > > > > > > (I am not satisfied with costing the users almost 10 secs
>> every
>> > > time
>> > > > > this executes.)
>> > > > > > > Here are the relevant lines in the ABL code:
>> > > > > > > [start]
>> > > > > > > define variable hEmailEx as handle no-undo.
>> > > > > > > run Bpm/BpmEmail.p persistent set hEmailEx.
>> > > > > > > run SendEmail in hEmailEx (
>> > > > > > > false,
>> > > > > > > CUR-COMP,
>> > > > > > > vFrom,
>> > > > > > > vTo,
>> > > > > > > vCC,
>> > > > > > > vSubject,
>> > > > > > > vBody,
>> > > > > > > "":U
>> > > > > > > [end]
>> > > > > > > I found the code above - and all the other lines not
>> displayed - on
>> > > > > this message board. I am not doing anything out of the ordinary
>> with
>> > > this.
>> > > > > I am simply updating the vSubject and vBody variables and sending
>> an
>> > > email.
>> > > > > I am running this synchronously. It doesn't work at all if I try
>> to
>> > > run it
>> > > > > asynchronously. Using the Action 'send email based on designed
>> > > template'
>> > > > > will not work for me in this case.
>> > > > > > > Is there another method for sending email using ABL code?
>> Should
>> > > this
>> > > > > work asynchronously and should I spend time troubleshooting why
>> it's
>> > > not
>> > > > > working?
>> > > > > > > Thanks in advance for your ideas,
>> > > > > > > Jonathan Tompkins
>> > > > > > > Alabama Specialty Products, Inc.
>> > > > > > > http://www.alspi.com
>> > > > > > > ________________________________
>> > > > > > > CONFIDENTIALITY NOTICE
>> > > > > > > The information contained in this communication, including
>> > > > > attachments, is privileged and confidential. It is intended only
>> for
>> > > the
>> > > > > exclusive use of the addressee. If the reader of this message is
>> not
>> > > the
>> > > > > intended recipient, or the employee or agent responsible for
>> > > delivering it
>> > > > > to the intended recipient, you are hereby notified that any
>> > > dissemination,
>> > > > > distribution or copying of this communication is strictly
>> prohibited.
>> > > If
>> > > > > you have received this communication in error, please notify us at
>> > > > > 727-578-6280 and immediately delete the communication.
>> > > > > > > "This (document/presentation) may contain technical data as
>> > > defined in
>> > > > > the International Traffic In Arms Regulations (ITAR) 22 CFR
>> 120.10.
>> > > Export
>> > > > > of this material is restricted by the Arms Export Control Act (22
>> > > U.S.C.
>> > > > > 2751 et seq.) and may not be exported to foreign persons without
>> prior
>> > > > > approval form the U.S. Department of State."
>> > > > > > > [Non-text portions of this message have been removed]
I have created a post-processing method directive that is working as intended except it takes too long. I will be grateful for any help you can provide to speed this up. Below is the situation.
The 'Action' is executing ABL code. I have narrowed the performance problem down to the "run SendEmail" line (see below). I know this because I substituted the "run SendEmail" command with a "display message to the screen" command and the performance is significantly better.
speed test:
(I am not satisfied with costing the users almost 10 secs every time this executes.)
[start]
false,
CUR-COMP,
vFrom,
vTo,
vCC,
vSubject,
vBody,
"":U
[end]
I found the code above - and all the other lines not displayed - on this message board. I am not doing anything out of the ordinary with this. I am simply updating the vSubject and vBody variables and sending an email. I am running this synchronously. It doesn't work at all if I try to run it asynchronously. Using the Action 'send email based on designed template' will not work for me in this case.
Is there another method for sending email using ABL code? Should this work asynchronously and should I spend time troubleshooting why it's not working?
Jonathan Tompkins
I'm not sure if this will help but when I've created Method Directives
for Pre-Processing under ACTIONS I change send email to asynchronously
instead of synchronously to in other words give the user the screen back
and send the email in the background without holding up the program.
Patrick Winter
Of upworth
Sent: Friday, May 24, 2013 09:07
Subject: [Vantage] Method directive, Post-processing, ABL sending email
is slow
better.
speed test:
this executes.)
[start]
false,
CUR-COMP,
vFrom,
vTo,
vCC,
vSubject,
vBody,
"":U
[end]
working?
Jonathan Tompkins
For async to work you need the BPM Action process running at startup. In 9.05 is it under Sys management > business Process Management > GO.
The time delay is the conversation with the email server, so if you control the email side you can work on the settings to go faster. Another option is to use IIS or another email server to offload the message and then relay for Epicor to the primary email server.
Greg Payne
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of upworth
Subject: [Vantage] Method directive, Post-processing, ABL sending email is slow
speed test:
[start]
false,
CUR-COMP,
vFrom,
vTo,
vCC,
vSubject,
vBody,
"":U
[end]
Jonathan Tompkins
The information contained in this communication, including attachments, is privileged and confidential. It is intended only for the exclusive use of the addressee. If the reader of this message is not the intended recipient, or the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us at 727-578-6280 and immediately delete the communication.
Thanks, Patrick. That is helpful in that I know it should work asynchronously. My ABL code doesn't work (i.e., doesn't send the email) if I run it async.
Any ideas about that?
Jonathan
> Patrick Winter
> Of upworth
> is slow
> better.
> speed test:
> this executes.)
> [start]
> false,
> CUR-COMP,
> vFrom,
> vTo,
> vCC,
> vSubject,
> vBody,
> "":U
> [end]
> working?
> Jonathan Tompkins
Thanks, Greg. I'll check with my Admin about that. It sounds like this could be the solution I'm looking for. I'll let you know.
Jonathan
> Greg Payne
> speed test:
> [start]
> false,
> CUR-COMP,
> vFrom,
> vTo,
> vCC,
> vSubject,
> vBody,
> "":U
> [end]
> Jonathan Tompkins
PROBLEM SOLVED! My Admin started the 'BPM Action process' and the emails send asynch now. Thanks, Greg!
> Jonathan
> > Greg Payne
> > speed test:
> > [start]
> > false,
> > CUR-COMP,
> > vFrom,
> > vTo,
> > vCC,
> > vSubject,
> > vBody,
> > "":U
> > [end]
> > Jonathan Tompkins
> > Jonathan
> > > Greg Payne
> Behalf Of upworth
> email is slow
> > > speed test:
> this executes.)
> > > [start]
> > > false,
> > > CUR-COMP,
> > > vFrom,
> > > vTo,
> > > vCC,
> > > vSubject,
> > > vBody,
> > > "":U
> > > [end]
> working?
> > > Jonathan Tompkins
If you haven't dont so, I would suggest that you first run the ABL synchronously to verify that it works. I have found troubleshooting to be more efficient this way. Once the email is sending like you want it, then change it to send asynchronously. (Forgive me, if you've already done this.)
My situation was that the emails worked synchronously but not asynchronously. The fix (per a recommendation from Greg in this forum) was to run 'System Management-->Business Process Management-->General Operations-->Action Process'. My admin took care of this for me and set this process to run on startup and "fire" every 5 mins. So, now, every 5 mins the 'Action Process' runs and sends any emails that were queued via my ABL code.
However, if you are having trouble sending email synchronously, let me know and I'll post the ABL code I used.
Jonathan
> > > Jonathan
> > > > Greg Payne
> > Behalf Of upworth
> > email is slow
> > > > speed test:
> > this executes.)
> > > > [start]
> > > > false,
> > > > CUR-COMP,
> > > > vFrom,
> > > > vTo,
> > > > vCC,
> > > > vSubject,
> > > > vBody,
> > > > "":U
> > > > [end]
> > working?
> > > > Jonathan Tompkins
Do I have to fire it all the time or does it just in the background? Similar to Global Emails.
Sent: Wednesday, May 29, 2013 5:39 AM
Subject: [Vantage] Re: Method directive, Post-processing, ABL sending email is slow
Jonathan
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Ephraim Feldman <effgroups@...<mailto:effgroups@...>> wrote:
> > --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, "upworth" <Upworth@> wrote:
> > > Jonathan
> > > --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Greg Payne <gpayne@> wrote:
> > > > Greg Payne
> > > > From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On
> > Behalf Of upworth
> > email is slow
> > > > speed test:
> > this executes.)
> > > > [start]
> > > > false,
> > > > CUR-COMP,
> > > > vFrom,
> > > > vTo,
> > > > vCC,
> > > > vSubject,
> > > > vBody,
> > > > "":U
> > > > [end]
> > working?
> > > > Jonathan Tompkins
It runs in the background and automatically fires at the time interval you specify in the 'Continuous Processing Delay' field when you activate the BPM Async process. My admin chose a 5 min delay, but you can specify a delay you are comfortable with.
Jonathan
> Jonathan
> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Ephraim Feldman <effgroups@<mailto:effgroups@>> wrote:
> > > > Jonathan
> > > > > Greg Payne
> > > Behalf Of upworth
> > > email is slow
> > > > > speed test:
> > > this executes.)
> > > > > [start]
> > > > > false,
> > > > > CUR-COMP,
> > > > > vFrom,
> > > > > vTo,
> > > > > vCC,
> > > > > vSubject,
> > > > > vBody,
> > > > > "":U
> > > > > [end]
> > > working?
> > > > > Jonathan Tompkins
By the way, we are on 9.05.701.
> Jonathan
> > Jonathan
> > > > > Jonathan
> > > > > > Greg Payne
> > > > Behalf Of upworth
> > > > email is slow
> > > > > > speed test:
> > > > this executes.)
> > > > > > [start]
> > > > > > false,
> > > > > > CUR-COMP,
> > > > > > vFrom,
> > > > > > vTo,
> > > > > > vCC,
> > > > > > vSubject,
> > > > > > vBody,
> > > > > > "":U
> > > > > > [end]
> > > > working?
> > > > > > Jonathan Tompkins
Thanks Jonathan
I have tested it and it works when run synchronously but when i set it to
Could it be possible the reason because I have a pop up message as part of
the BPM?
Ephraim
> ABL code.
> Jonathan
> emails
> this
> > > > Jonathan
> startup.
> Another
> > > > > Greg Payne
> > > Behalf Of upworth
> > > email is slow
> as
> can
> because I
> > > > > speed test:
> time
> > > this executes.)
> > > > > [start]
> > > > > false,
> > > > > CUR-COMP,
> > > > > vFrom,
> > > > > vTo,
> > > > > vCC,
> > > > > vSubject,
> > > > > vBody,
> > > > > "":U
> > > > > [end]
> this.
> email.
> run it
> template'
> this
> not
> > > working?
> > > > > Jonathan Tompkins
> the
> the
> delivering it
> dissemination,
> If
> defined in
> Export
> U.S.C.
If the only change you are making is from synch to asynch, then it should work. You may want to verify that the BPM Asynch process is actually running. Open your System Monitor, select 'Actions-->Display All Tasks', then look under the 'Scheduled Tasks' tab. You should see the task there, probably called 'BPM Action Process'. Every time it runs, it reschedules based on the time Delay you specified. If it's not there, then it's not running continuously.
Jonathan
> Thanks Jonathan
> the BPM?
> Ephraim
> > ABL code.
> > Jonathan
> > emails
> > this
> > > > > Jonathan
> > startup.
> > Another
> > > > > > Greg Payne
> > > > Behalf Of upworth
> > > > email is slow
> > as
> > can
> > because I
> > > > > > speed test:
> > time
> > > > this executes.)
> > > > > > [start]
> > > > > > false,
> > > > > > CUR-COMP,
> > > > > > vFrom,
> > > > > > vTo,
> > > > > > vCC,
> > > > > > vSubject,
> > > > > > vBody,
> > > > > > "":U
> > > > > > [end]
> > this.
> > email.
> > run it
> > template'
> > this
> > not
> > > > working?
> > > > > > Jonathan Tompkins
> > the
> > the
> > delivering it
> > dissemination,
> > If
> > defined in
> > Export
> > U.S.C.
Jonathan
> Thanks Jonathan
> the BPM?
> Ephraim
> > ABL code.
> > Jonathan
> > --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Ephraim Feldman <effgroups@> wrote:
> > emails
> > this
> > > > > Jonathan
> > startup.
> > Another
> > > > > > Greg Payne
> > > > Behalf Of upworth
> > > > email is slow
> > as
> > can
> > because I
> > > > > > speed test:
> > time
> > > > this executes.)
> > > > > > [start]
> > > > > > false,
> > > > > > CUR-COMP,
> > > > > > vFrom,
> > > > > > vTo,
> > > > > > vCC,
> > > > > > vSubject,
> > > > > > vBody,
> > > > > > "":U
> > > > > > [end]
> > this.
> > email.
> > run it
> > template'
> > this
> > not
> > > > working?
> > > > > > Jonathan Tompkins
> > the
> > the
> > delivering it
> > dissemination,
> > If
> > defined in
> > Export
> > U.S.C.
9.05.701
> Of upworth
> email is slow
> Jonathan
> > Thanks Jonathan
> of
> > the BPM?
> > Ephraim
> be
> then
> this.)
> was
> 5
> via my
> > > ABL code.
> > > Jonathan
> > > emails
> > > this
> > > > > > Jonathan
> > > startup.
> GO.
> if you
> > > Another
> message and
> > > > > > > Greg Payne
> > > > > Behalf Of upworth
> sending
> > > > > email is slow
> working
> > > as
> you
> > > can
> performance
> > > because I
> the
> > > > > > > speed test:
> > > time
> > > > > this executes.)
> > > > > > > [start]
> > > > > > > false,
> > > > > > > CUR-COMP,
> > > > > > > vFrom,
> > > > > > > vTo,
> > > > > > > vCC,
> > > > > > > vSubject,
> > > > > > > vBody,
> > > > > > > "":U
> > > > > > > [end]
> - on
> with
> > > this.
> an
> > > email.
> > > run it
> > > template'
> Should
> > > this
> it's
> > > not
> > > > > working?
> > > > > > > Jonathan Tompkins
> for
> > > the
> not
> > > the
> > > delivering it
> > > dissemination,
> prohibited.
> > > If
> > > defined in
> > > Export
> > > U.S.C.
> prior
