Hello,
I have set an e-mail alert for whenever a new price is inserted.
One of the members is not receiving any e-mail lately, but the rest do.
What could possibly be the problem? I have checked the alert settings, the .p file that is loaded within Business Activity Manager, the user's membership for this particular group. Everything looks fine.
I was also checking the System Monitor and I have noticed that on history tasks there is an error for "Global Alerts \ Email Process.
Here is what it says in detail:
Type:3
Program:agent/RunTask.p
Method:Main-Block
Table:
Field:
Rowid:
Message:Program si/sim100.p rasied the 4GL Stop condition with the following message:
Can anyone help me?
Thank you!
....\epicor\EpicorData\GlobalAlertsEmail.log
....\epicor\oe XXXX _wrk\epicor-smtp.log.txt
....\epicor\ XXXXX \Server\Logs\ XXXX server.log
>> 4GL Stop condition with the following message:For .p error messages like this, I usually see more details in the server log.
And for mail processing errors, the other two logs can sometimes provide clues.
if you look in the sever log when this happens are there more details on the error? You can put message statements in the bam program to track values and progress thru the code.
One thing I found is that the subject can only be 60 characters. I had a case where I added the part number and description to the subject. A short part description would be fine, but a long one would error out.
Greg
Sent: Wednesday, November 25, 2015 2:59 PM
Subject: [Vantage] not receiving e-mail alerts with Vantage 8.03
Hello,
Type:3
Method:Main-Block
Table:
Field:
Rowid:
Can anyone help me?
Thank you!
CONFIDENTIALITY NOTICE
The information contained in this communication, including attachments, is privileged and confidential. It is intended only for the exclusive use of the addressee. If the reader of this message is not the intended recipient, or the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us at 727-578-6240 and immediately delete the communication.
-Jeff
Sent: Wednesday, November 25, 2015 12:52 PM
Subject: [Vantage] Re: not receiving e-mail alerts with Vantage 8.03
I have checked the logs and everything seems ok(perhaps I am missing something).
Here is a part of epicor-smtp.log:
LocalHostName = server's name
11/23/15 09:13:14 opening socket
11/23/15 09:13:14 Socket Connection Established.
11/23/15 09:13:15 vstate 1
cSMTPResponse 220 EX12-v. Microsoft ESMTP MAIL Service ready at Mon, 23 Nov 2015 09:13:14 -0600
iReponseLength96
11/23/15 09:13:15 cLast-Command nothing
11/23/15 09:13:15 SendCommand: HELO server's name
11/23/15 09:13:15 SendCommand Finished:
11/23/15 09:13:16 vstate 1
cSMTPResponse 250 EX12-v. Hello [192.168.0.8]
iReponseLength46
11/23/15 09:13:16 cLast-Command HELO
11/23/15 09:13:16 SendCommand: MAIL From: <vantage@>
11/23/15 09:13:16 SendCommand Finished:
11/23/15 09:13:17 vstate 1
cSMTPResponse 250 2.1.0 Sender OK
iReponseLength21
11/23/15 09:13:17 cLast-Command MAIL
11/23/15 09:13:17 SendCommand: RCPT TO: <DG-PriceInsertedIntoSalesOrder@>
11/23/15 09:13:17 SendCommand Finished:
11/23/15 09:13:18 vstate 1
cSMTPResponse 250 2.1.5 Recipient OK
iReponseLength24
11/23/15 09:13:18 cLast-Command RCPT
11/23/15 09:13:18 SendCommand: DATA
11/23/15 09:13:18 SendCommand Finished:
11/23/15 09:13:19 vstate 1
cSMTPResponse 354 Start mail input; end with <CRLF>.<CRLF>
iReponseLength46
11/23/15 09:13:19 cLast-Command DATA
11/23/15 09:13:19 SendCommand: From: vantage@
To: DG-PriceInsertedIntoSalesOrder@ <DG-PriceInsertedIntoSalesOrder@>
Subject: Price Inserted into a New Order
Date: 23 Nov 2015 09:13:19 -0600
11/23/15 09:13:19 SendCommand Finished:
11/23/15 09:13:19 SendCommand: MIME-Version: 1.0
Content-type: multipart/mixed;
boundary="MAIL_BOUNDARY"
Content-Transfer-Encoding: 8bit
This is a multi-part MIME Encoded message
>>3 members of that group. 1 of them stopped receiving e-mails last weekDid you mean 2 receipts and 1 no receipt?
If so, I wonder if something might be going on outside of Epicor
Have you successfully sent a test message from an email client to that group address?
Occasionally I run into problems at the mail server, AV/Spam filters.
When I suspect external issues with email...
I might set up a "dummy" Person/Contact in Epicor that uses the email address in question.
Then open that record in a tracker, right-click on the email address & select "Email" from the context menu. Immediate feedback compared to testing with a BAM for some types of email address/setup problems
Has been known to get email running as expected again.
<div id="ygrps-yiv-271023183yiv3359619163ygrp-text">
<div>Yes, I did reboot, but that did not solve the problem..</div>
</div>
<div style="color:#fff;height:0;"></div></div>
#ygrps-yiv-271023183 #ygrps-yiv-271023183yiv3359619163 #ygrps-yiv-271023183yiv3359619163ygrp-mkp hr {
border:1px solid #d8d8d8;}
#ygrps-yiv-271023183 #ygrps-yiv-271023183yiv3359619163 #ygrps-yiv-271023183yiv3359619163ygrp-mkp #ygrps-yiv-271023183yiv3359619163hd {
color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}
#ygrps-yiv-271023183 #ygrps-yiv-271023183yiv3359619163 #ygrps-yiv-271023183yiv3359619163ygrp-mkp #ygrps-yiv-271023183yiv3359619163ads {
margin-bottom:10px;}
#ygrps-yiv-271023183 #ygrps-yiv-271023183yiv3359619163 #ygrps-yiv-271023183yiv3359619163ygrp-mkp .ygrps-yiv-271023183yiv3359619163ad {
padding:0 0;}
#ygrps-yiv-271023183 #ygrps-yiv-271023183yiv3359619163 #ygrps-yiv-271023183yiv3359619163ygrp-mkp .ygrps-yiv-271023183yiv3359619163ad p {
margin:0;}
#ygrps-yiv-271023183 #ygrps-yiv-271023183yiv3359619163 #ygrps-yiv-271023183yiv3359619163ygrp-mkp .ygrps-yiv-271023183yiv3359619163ad a {
color:#0000ff;text-decoration:none;}
#ygrps-yiv-271023183 #ygrps-yiv-271023183yiv3359619163 #ygrps-yiv-271023183yiv3359619163ygrp-sponsor #ygrps-yiv-271023183yiv3359619163ygrp-lc {
font-family:Arial;}
#ygrps-yiv-271023183 #ygrps-yiv-271023183yiv3359619163 #ygrps-yiv-271023183yiv3359619163ygrp-sponsor #ygrps-yiv-271023183yiv3359619163ygrp-lc #ygrps-yiv-271023183yiv3359619163hd {
margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}
#ygrps-yiv-271023183 #ygrps-yiv-271023183yiv3359619163 #ygrps-yiv-271023183yiv3359619163ygrp-sponsor #ygrps-yiv-271023183yiv3359619163ygrp-lc .ygrps-yiv-271023183yiv3359619163ad {
margin-bottom:10px;padding:0 0;}
#ygrps-yiv-271023183 #ygrps-yiv-271023183yiv3359619163 #ygrps-yiv-271023183yiv3359619163actions {
font-family:Verdana;font-size:11px;padding:10px 0;}
#ygrps-yiv-271023183 #ygrps-yiv-271023183yiv3359619163 #ygrps-yiv-271023183yiv3359619163activity {
background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}
#ygrps-yiv-271023183 #ygrps-yiv-271023183yiv3359619163 #ygrps-yiv-271023183yiv3359619163activity span {
font-weight:700;}
#ygrps-yiv-271023183 #ygrps-yiv-271023183yiv3359619163 #ygrps-yiv-271023183yiv3359619163activity span:first-child {
text-transform:uppercase;}
#ygrps-yiv-271023183 #ygrps-yiv-271023183yiv3359619163 #ygrps-yiv-271023183yiv3359619163activity span a {
color:#5085b6;text-decoration:none;}
#ygrps-yiv-271023183 #ygrps-yiv-271023183yiv3359619163 #ygrps-yiv-271023183yiv3359619163activity span span {
color:#ff7900;}
#ygrps-yiv-271023183 #ygrps-yiv-271023183yiv3359619163 #ygrps-yiv-271023183yiv3359619163activity span .ygrps-yiv-271023183yiv3359619163underline {
text-decoration:underline;}
#ygrps-yiv-271023183 #ygrps-yiv-271023183yiv3359619163 .ygrps-yiv-271023183yiv3359619163attach {
clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}
#ygrps-yiv-271023183 #ygrps-yiv-271023183yiv3359619163 .ygrps-yiv-271023183yiv3359619163attach div a {
#ygrps-yiv-271023183 #ygrps-yiv-271023183yiv3359619163 .ygrps-yiv-271023183yiv3359619163attach img {
border:none;padding-right:5px;}
#ygrps-yiv-271023183 #ygrps-yiv-271023183yiv3359619163 .ygrps-yiv-271023183yiv3359619163attach label {
display:block;margin-bottom:5px;}
#ygrps-yiv-271023183 #ygrps-yiv-271023183yiv3359619163 .ygrps-yiv-271023183yiv3359619163attach label a {
#ygrps-yiv-271023183 #ygrps-yiv-271023183yiv3359619163 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-271023183 #ygrps-yiv-271023183yiv3359619163 .ygrps-yiv-271023183yiv3359619163bold {
font-family:Arial;font-size:13px;font-weight:700;}
#ygrps-yiv-271023183 #ygrps-yiv-271023183yiv3359619163 .ygrps-yiv-271023183yiv3359619163bold a {
#ygrps-yiv-271023183 #ygrps-yiv-271023183yiv3359619163 dd.ygrps-yiv-271023183yiv3359619163last p a {
font-family:Verdana;font-weight:700;}
#ygrps-yiv-271023183 #ygrps-yiv-271023183yiv3359619163 dd.ygrps-yiv-271023183yiv3359619163last p span {
margin-right:10px;font-family:Verdana;font-weight:700;}
#ygrps-yiv-271023183 #ygrps-yiv-271023183yiv3359619163 dd.ygrps-yiv-271023183yiv3359619163last p span.ygrps-yiv-271023183yiv3359619163yshortcuts {
margin-right:0;}
#ygrps-yiv-271023183 #ygrps-yiv-271023183yiv3359619163 div.ygrps-yiv-271023183yiv3359619163attach-table div div a {
#ygrps-yiv-271023183 #ygrps-yiv-271023183yiv3359619163 div.ygrps-yiv-271023183yiv3359619163attach-table {
width:400px;}
#ygrps-yiv-271023183 #ygrps-yiv-271023183yiv3359619163 div.ygrps-yiv-271023183yiv3359619163file-title a, #ygrps-yiv-271023183 #ygrps-yiv-271023183yiv3359619163 div.ygrps-yiv-271023183yiv3359619163file-title a:active, #ygrps-yiv-271023183 #ygrps-yiv-271023183yiv3359619163 div.ygrps-yiv-271023183yiv3359619163file-title a:hover, #ygrps-yiv-271023183 #ygrps-yiv-271023183yiv3359619163 div.ygrps-yiv-271023183yiv3359619163file-title a:visited {
#ygrps-yiv-271023183 #ygrps-yiv-271023183yiv3359619163 div.ygrps-yiv-271023183yiv3359619163photo-title a, #ygrps-yiv-271023183 #ygrps-yiv-271023183yiv3359619163 div.ygrps-yiv-271023183yiv3359619163photo-title a:active, #ygrps-yiv-271023183 #ygrps-yiv-271023183yiv3359619163 div.ygrps-yiv-271023183yiv3359619163photo-title a:hover, #ygrps-yiv-271023183 #ygrps-yiv-271023183yiv3359619163 div.ygrps-yiv-271023183yiv3359619163photo-title a:visited {
#ygrps-yiv-271023183 #ygrps-yiv-271023183yiv3359619163 div#ygrps-yiv-271023183yiv3359619163ygrp-mlmsg #ygrps-yiv-271023183yiv3359619163ygrp-msg p a span.ygrps-yiv-271023183yiv3359619163yshortcuts {
font-family:Verdana;font-size:10px;font-weight:normal;}
#ygrps-yiv-271023183 #ygrps-yiv-271023183yiv3359619163 .ygrps-yiv-271023183yiv3359619163green {
color:#628c2a;}
#ygrps-yiv-271023183 #ygrps-yiv-271023183yiv3359619163 .ygrps-yiv-271023183yiv3359619163MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-271023183 #ygrps-yiv-271023183yiv3359619163 o {
font-size:0;}
#ygrps-yiv-271023183 #ygrps-yiv-271023183yiv3359619163 #ygrps-yiv-271023183yiv3359619163photos div {
float:left;width:72px;}
#ygrps-yiv-271023183 #ygrps-yiv-271023183yiv3359619163 #ygrps-yiv-271023183yiv3359619163photos div div {
border:1px solid #666666;height:62px;overflow:hidden;width:62px;}
#ygrps-yiv-271023183 #ygrps-yiv-271023183yiv3359619163 #ygrps-yiv-271023183yiv3359619163photos div label {
color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}
#ygrps-yiv-271023183 #ygrps-yiv-271023183yiv3359619163 #ygrps-yiv-271023183yiv3359619163reco-category {
font-size:77%;}
#ygrps-yiv-271023183 #ygrps-yiv-271023183yiv3359619163 #ygrps-yiv-271023183yiv3359619163reco-desc {
font-size:77%;}
#ygrps-yiv-271023183 #ygrps-yiv-271023183yiv3359619163 .ygrps-yiv-271023183yiv3359619163replbq {
margin:4px;}
#ygrps-yiv-271023183 #ygrps-yiv-271023183yiv3359619163 #ygrps-yiv-271023183yiv3359619163ygrp-actbar div a:first-child {
margin-right:2px;padding-right:5px;}
#ygrps-yiv-271023183 #ygrps-yiv-271023183yiv3359619163 #ygrps-yiv-271023183yiv3359619163ygrp-mlmsg {
font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}
#ygrps-yiv-271023183 #ygrps-yiv-271023183yiv3359619163 #ygrps-yiv-271023183yiv3359619163ygrp-mlmsg table {
font-size:inherit;font:100%;}
#ygrps-yiv-271023183 #ygrps-yiv-271023183yiv3359619163 #ygrps-yiv-271023183yiv3359619163ygrp-mlmsg select, #ygrps-yiv-271023183 #ygrps-yiv-271023183yiv3359619163 input, #ygrps-yiv-271023183 #ygrps-yiv-271023183yiv3359619163 textarea {
font:99% Arial, Helvetica, clean, sans-serif;}
#ygrps-yiv-271023183 #ygrps-yiv-271023183yiv3359619163 #ygrps-yiv-271023183yiv3359619163ygrp-mlmsg pre, #ygrps-yiv-271023183 #ygrps-yiv-271023183yiv3359619163 code {
font:115% monospace;}
#ygrps-yiv-271023183 #ygrps-yiv-271023183yiv3359619163 #ygrps-yiv-271023183yiv3359619163ygrp-mlmsg * {
line-height:1.22em;}
#ygrps-yiv-271023183 #ygrps-yiv-271023183yiv3359619163 #ygrps-yiv-271023183yiv3359619163ygrp-mlmsg #ygrps-yiv-271023183yiv3359619163logo {
padding-bottom:10px;}
#ygrps-yiv-271023183 #ygrps-yiv-271023183yiv3359619163 #ygrps-yiv-271023183yiv3359619163ygrp-msg p a {
font-family:Verdana;}
#ygrps-yiv-271023183 #ygrps-yiv-271023183yiv3359619163 #ygrps-yiv-271023183yiv3359619163ygrp-msg p#ygrps-yiv-271023183yiv3359619163attach-count span {
color:#1E66AE;font-weight:700;}
#ygrps-yiv-271023183 #ygrps-yiv-271023183yiv3359619163 #ygrps-yiv-271023183yiv3359619163ygrp-reco #ygrps-yiv-271023183yiv3359619163reco-head {
color:#ff7900;font-weight:700;}
#ygrps-yiv-271023183 #ygrps-yiv-271023183yiv3359619163 #ygrps-yiv-271023183yiv3359619163ygrp-reco {
margin-bottom:20px;padding:0px;}
#ygrps-yiv-271023183 #ygrps-yiv-271023183yiv3359619163 #ygrps-yiv-271023183yiv3359619163ygrp-sponsor #ygrps-yiv-271023183yiv3359619163ov li a {
font-size:130%;text-decoration:none;}
#ygrps-yiv-271023183 #ygrps-yiv-271023183yiv3359619163 #ygrps-yiv-271023183yiv3359619163ygrp-sponsor #ygrps-yiv-271023183yiv3359619163ov li {
font-size:77%;list-style-type:square;padding:6px 0;}
#ygrps-yiv-271023183 #ygrps-yiv-271023183yiv3359619163 #ygrps-yiv-271023183yiv3359619163ygrp-sponsor #ygrps-yiv-271023183yiv3359619163ov ul {
margin:0;padding:0 0 0 8px;}
#ygrps-yiv-271023183 #ygrps-yiv-271023183yiv3359619163 #ygrps-yiv-271023183yiv3359619163ygrp-text {
font-family:Georgia;}
#ygrps-yiv-271023183 #ygrps-yiv-271023183yiv3359619163 #ygrps-yiv-271023183yiv3359619163ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-271023183 #ygrps-yiv-271023183yiv3359619163 #ygrps-yiv-271023183yiv3359619163ygrp-text tt {
font-size:120%;}
#ygrps-yiv-271023183 #ygrps-yiv-271023183yiv3359619163 #ygrps-yiv-271023183yiv3359619163ygrp-vital ul li:last-child {
border-right:none !important;}
In 8.03.409xx I remember having an issue with a BAM email that I never could resolve.
Since then, whenever possible, I use BPM's instead of a BAM's.
Aracely
Exchange has a setting on both distro groups and users that all mail has to from an authenticated user. Epicor is not authenticated, so the check box has to be unchecked. I believe it is in the mailflow settings.
Greg
Sent: Monday, January 18, 2016 1:44 PM
Good morning,
Were you able to resolve this issue? I'm having the same problem with a Global Alert, where one of the recipients is not getting the e-mail (let's call him "X"). The rest get the notification just fine. In my case, X is new with the company and has never received these notifications.
I tried changing his e-mail address from the CC: box to the TO: box, and nothing. Also tried creating a dummy e-mail address that forwards to his real e-mail address, and it didn't work either.
I just added a new user to the Global Alert and he got the e-mail just fine, but X still didn't get it.
I'll be checking the settings for distribution lists in Exchange, but wanted to see first if you have had any luck solving this.
Aracely
<div id="ygrps-yiv-912695523yiv9401890812ygrp-text">
<div>
Aracely
</div>
<div class="ygrps-yiv-912695523yiv9401890812yqt3611798491" id="ygrps-yiv-912695523yiv9401890812yqt54269"><div style="color:#fff;height:0;"></div></div>
#ygrps-yiv-912695523 #ygrps-yiv-912695523yiv9401890812 #ygrps-yiv-912695523yiv9401890812ygrp-mkp hr {
#ygrps-yiv-912695523 #ygrps-yiv-912695523yiv9401890812 #ygrps-yiv-912695523yiv9401890812ygrp-mkp #ygrps-yiv-912695523yiv9401890812hd {
#ygrps-yiv-912695523 #ygrps-yiv-912695523yiv9401890812 #ygrps-yiv-912695523yiv9401890812ygrp-mkp #ygrps-yiv-912695523yiv9401890812ads {
#ygrps-yiv-912695523 #ygrps-yiv-912695523yiv9401890812 #ygrps-yiv-912695523yiv9401890812ygrp-mkp .ygrps-yiv-912695523yiv9401890812ad {
padding:0 0;}
#ygrps-yiv-912695523 #ygrps-yiv-912695523yiv9401890812 #ygrps-yiv-912695523yiv9401890812ygrp-mkp .ygrps-yiv-912695523yiv9401890812ad p {
margin:0;}
#ygrps-yiv-912695523 #ygrps-yiv-912695523yiv9401890812 #ygrps-yiv-912695523yiv9401890812ygrp-mkp .ygrps-yiv-912695523yiv9401890812ad a {
#ygrps-yiv-912695523 #ygrps-yiv-912695523yiv9401890812 #ygrps-yiv-912695523yiv9401890812ygrp-sponsor #ygrps-yiv-912695523yiv9401890812ygrp-lc {
font-family:Arial;}
#ygrps-yiv-912695523 #ygrps-yiv-912695523yiv9401890812 #ygrps-yiv-912695523yiv9401890812ygrp-sponsor #ygrps-yiv-912695523yiv9401890812ygrp-lc #ygrps-yiv-912695523yiv9401890812hd {
#ygrps-yiv-912695523 #ygrps-yiv-912695523yiv9401890812 #ygrps-yiv-912695523yiv9401890812ygrp-sponsor #ygrps-yiv-912695523yiv9401890812ygrp-lc .ygrps-yiv-912695523yiv9401890812ad {
#ygrps-yiv-912695523 #ygrps-yiv-912695523yiv9401890812 #ygrps-yiv-912695523yiv9401890812actions {
#ygrps-yiv-912695523 #ygrps-yiv-912695523yiv9401890812 #ygrps-yiv-912695523yiv9401890812activity {
#ygrps-yiv-912695523 #ygrps-yiv-912695523yiv9401890812 #ygrps-yiv-912695523yiv9401890812activity span {
font-weight:700;}
#ygrps-yiv-912695523 #ygrps-yiv-912695523yiv9401890812 #ygrps-yiv-912695523yiv9401890812activity span:first-child {
#ygrps-yiv-912695523 #ygrps-yiv-912695523yiv9401890812 #ygrps-yiv-912695523yiv9401890812activity span a {
#ygrps-yiv-912695523 #ygrps-yiv-912695523yiv9401890812 #ygrps-yiv-912695523yiv9401890812activity span span {
color:#ff7900;}
#ygrps-yiv-912695523 #ygrps-yiv-912695523yiv9401890812 #ygrps-yiv-912695523yiv9401890812activity span .ygrps-yiv-912695523yiv9401890812underline {
#ygrps-yiv-912695523 #ygrps-yiv-912695523yiv9401890812 .ygrps-yiv-912695523yiv9401890812attach {
#ygrps-yiv-912695523 #ygrps-yiv-912695523yiv9401890812 .ygrps-yiv-912695523yiv9401890812attach div a {
#ygrps-yiv-912695523 #ygrps-yiv-912695523yiv9401890812 .ygrps-yiv-912695523yiv9401890812attach img {
#ygrps-yiv-912695523 #ygrps-yiv-912695523yiv9401890812 .ygrps-yiv-912695523yiv9401890812attach label {
#ygrps-yiv-912695523 #ygrps-yiv-912695523yiv9401890812 .ygrps-yiv-912695523yiv9401890812attach label a {
#ygrps-yiv-912695523 #ygrps-yiv-912695523yiv9401890812 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-912695523 #ygrps-yiv-912695523yiv9401890812 .ygrps-yiv-912695523yiv9401890812bold {
#ygrps-yiv-912695523 #ygrps-yiv-912695523yiv9401890812 .ygrps-yiv-912695523yiv9401890812bold a {
#ygrps-yiv-912695523 #ygrps-yiv-912695523yiv9401890812 dd.ygrps-yiv-912695523yiv9401890812last p a {
#ygrps-yiv-912695523 #ygrps-yiv-912695523yiv9401890812 dd.ygrps-yiv-912695523yiv9401890812last p span {
#ygrps-yiv-912695523 #ygrps-yiv-912695523yiv9401890812 dd.ygrps-yiv-912695523yiv9401890812last p span.ygrps-yiv-912695523yiv9401890812yshortcuts {
margin-right:0;}
#ygrps-yiv-912695523 #ygrps-yiv-912695523yiv9401890812 div.ygrps-yiv-912695523yiv9401890812attach-table div div a {
#ygrps-yiv-912695523 #ygrps-yiv-912695523yiv9401890812 div.ygrps-yiv-912695523yiv9401890812attach-table {
width:400px;}
#ygrps-yiv-912695523 #ygrps-yiv-912695523yiv9401890812 div.ygrps-yiv-912695523yiv9401890812file-title a, #ygrps-yiv-912695523 #ygrps-yiv-912695523yiv9401890812 div.ygrps-yiv-912695523yiv9401890812file-title a:active, #ygrps-yiv-912695523 #ygrps-yiv-912695523yiv9401890812 div.ygrps-yiv-912695523yiv9401890812file-title a:hover, #ygrps-yiv-912695523 #ygrps-yiv-912695523yiv9401890812 div.ygrps-yiv-912695523yiv9401890812file-title a:visited {
#ygrps-yiv-912695523 #ygrps-yiv-912695523yiv9401890812 div.ygrps-yiv-912695523yiv9401890812photo-title a, #ygrps-yiv-912695523 #ygrps-yiv-912695523yiv9401890812 div.ygrps-yiv-912695523yiv9401890812photo-title a:active, #ygrps-yiv-912695523 #ygrps-yiv-912695523yiv9401890812 div.ygrps-yiv-912695523yiv9401890812photo-title a:hover, #ygrps-yiv-912695523 #ygrps-yiv-912695523yiv9401890812 div.ygrps-yiv-912695523yiv9401890812photo-title a:visited {
#ygrps-yiv-912695523 #ygrps-yiv-912695523yiv9401890812 div#ygrps-yiv-912695523yiv9401890812ygrp-mlmsg #ygrps-yiv-912695523yiv9401890812ygrp-msg p a span.ygrps-yiv-912695523yiv9401890812yshortcuts {
#ygrps-yiv-912695523 #ygrps-yiv-912695523yiv9401890812 .ygrps-yiv-912695523yiv9401890812green {
color:#628c2a;}
#ygrps-yiv-912695523 #ygrps-yiv-912695523yiv9401890812 .ygrps-yiv-912695523yiv9401890812MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-912695523 #ygrps-yiv-912695523yiv9401890812 o {
font-size:0;}
#ygrps-yiv-912695523 #ygrps-yiv-912695523yiv9401890812 #ygrps-yiv-912695523yiv9401890812photos div {
#ygrps-yiv-912695523 #ygrps-yiv-912695523yiv9401890812 #ygrps-yiv-912695523yiv9401890812photos div div {
#ygrps-yiv-912695523 #ygrps-yiv-912695523yiv9401890812 #ygrps-yiv-912695523yiv9401890812photos div label {
#ygrps-yiv-912695523 #ygrps-yiv-912695523yiv9401890812 #ygrps-yiv-912695523yiv9401890812reco-category {
font-size:77%;}
#ygrps-yiv-912695523 #ygrps-yiv-912695523yiv9401890812 #ygrps-yiv-912695523yiv9401890812reco-desc {
font-size:77%;}
#ygrps-yiv-912695523 #ygrps-yiv-912695523yiv9401890812 .ygrps-yiv-912695523yiv9401890812replbq {
margin:4px;}
#ygrps-yiv-912695523 #ygrps-yiv-912695523yiv9401890812 #ygrps-yiv-912695523yiv9401890812ygrp-actbar div a:first-child {
#ygrps-yiv-912695523 #ygrps-yiv-912695523yiv9401890812 #ygrps-yiv-912695523yiv9401890812ygrp-mlmsg {
#ygrps-yiv-912695523 #ygrps-yiv-912695523yiv9401890812 #ygrps-yiv-912695523yiv9401890812ygrp-mlmsg table {
#ygrps-yiv-912695523 #ygrps-yiv-912695523yiv9401890812 #ygrps-yiv-912695523yiv9401890812ygrp-mlmsg select, #ygrps-yiv-912695523 #ygrps-yiv-912695523yiv9401890812 input, #ygrps-yiv-912695523 #ygrps-yiv-912695523yiv9401890812 textarea {
#ygrps-yiv-912695523 #ygrps-yiv-912695523yiv9401890812 #ygrps-yiv-912695523yiv9401890812ygrp-mlmsg pre, #ygrps-yiv-912695523 #ygrps-yiv-912695523yiv9401890812 code {
#ygrps-yiv-912695523 #ygrps-yiv-912695523yiv9401890812 #ygrps-yiv-912695523yiv9401890812ygrp-mlmsg * {
#ygrps-yiv-912695523 #ygrps-yiv-912695523yiv9401890812 #ygrps-yiv-912695523yiv9401890812ygrp-mlmsg #ygrps-yiv-912695523yiv9401890812logo {
#ygrps-yiv-912695523 #ygrps-yiv-912695523yiv9401890812 #ygrps-yiv-912695523yiv9401890812ygrp-msg p a {
#ygrps-yiv-912695523 #ygrps-yiv-912695523yiv9401890812 #ygrps-yiv-912695523yiv9401890812ygrp-msg p#ygrps-yiv-912695523yiv9401890812attach-count span {
#ygrps-yiv-912695523 #ygrps-yiv-912695523yiv9401890812 #ygrps-yiv-912695523yiv9401890812ygrp-reco #ygrps-yiv-912695523yiv9401890812reco-head {
#ygrps-yiv-912695523 #ygrps-yiv-912695523yiv9401890812 #ygrps-yiv-912695523yiv9401890812ygrp-reco {
#ygrps-yiv-912695523 #ygrps-yiv-912695523yiv9401890812 #ygrps-yiv-912695523yiv9401890812ygrp-sponsor #ygrps-yiv-912695523yiv9401890812ov li a {
#ygrps-yiv-912695523 #ygrps-yiv-912695523yiv9401890812 #ygrps-yiv-912695523yiv9401890812ygrp-sponsor #ygrps-yiv-912695523yiv9401890812ov li {
#ygrps-yiv-912695523 #ygrps-yiv-912695523yiv9401890812 #ygrps-yiv-912695523yiv9401890812ygrp-sponsor #ygrps-yiv-912695523yiv9401890812ov ul {
#ygrps-yiv-912695523 #ygrps-yiv-912695523yiv9401890812 #ygrps-yiv-912695523yiv9401890812ygrp-text {
#ygrps-yiv-912695523 #ygrps-yiv-912695523yiv9401890812 #ygrps-yiv-912695523yiv9401890812ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-912695523 #ygrps-yiv-912695523yiv9401890812 #ygrps-yiv-912695523yiv9401890812ygrp-text tt {
font-size:120%;}
#ygrps-yiv-912695523 #ygrps-yiv-912695523yiv9401890812 #ygrps-yiv-912695523yiv9401890812ygrp-vital ul li:last-child {
does the conversation between the server and exchange look different for this user in epicor-smtp.log.txt
Sent: Monday, January 18, 2016 3:32 PM
Subject: Re: [Vantage] Re: not receiving e-mail alerts with Vantage 8.03
I verified that and the box is not checked.
On Monday, January 18, 2016 1:13 PM, "Greg Payne gpayne@... [vantage]" <vantage@yahoogroups.com> wrote:
Greg
Good morning,
Aracely
<div id="ygrps-yiv-2082309084yiv1981364950ygrp-text">
<div>
Aracely
</div>
<div class="ygrps-yiv-2082309084yiv1981364950yqt5604985325" id="ygrps-yiv-2082309084yiv1981364950yqt64359"><div style="color:#fff;height:0;"></div></div>
#ygrps-yiv-2082309084 #ygrps-yiv-2082309084yiv1981364950 #ygrps-yiv-2082309084yiv1981364950ygrp-mkp hr {
#ygrps-yiv-2082309084 #ygrps-yiv-2082309084yiv1981364950 #ygrps-yiv-2082309084yiv1981364950ygrp-mkp #ygrps-yiv-2082309084yiv1981364950hd {
#ygrps-yiv-2082309084 #ygrps-yiv-2082309084yiv1981364950 #ygrps-yiv-2082309084yiv1981364950ygrp-mkp #ygrps-yiv-2082309084yiv1981364950ads {
#ygrps-yiv-2082309084 #ygrps-yiv-2082309084yiv1981364950 #ygrps-yiv-2082309084yiv1981364950ygrp-mkp .ygrps-yiv-2082309084yiv1981364950ad {
padding:0 0;}
#ygrps-yiv-2082309084 #ygrps-yiv-2082309084yiv1981364950 #ygrps-yiv-2082309084yiv1981364950ygrp-mkp .ygrps-yiv-2082309084yiv1981364950ad p {
margin:0;}
#ygrps-yiv-2082309084 #ygrps-yiv-2082309084yiv1981364950 #ygrps-yiv-2082309084yiv1981364950ygrp-mkp .ygrps-yiv-2082309084yiv1981364950ad a {
#ygrps-yiv-2082309084 #ygrps-yiv-2082309084yiv1981364950 #ygrps-yiv-2082309084yiv1981364950ygrp-sponsor #ygrps-yiv-2082309084yiv1981364950ygrp-lc {
font-family:Arial;}
#ygrps-yiv-2082309084 #ygrps-yiv-2082309084yiv1981364950 #ygrps-yiv-2082309084yiv1981364950ygrp-sponsor #ygrps-yiv-2082309084yiv1981364950ygrp-lc #ygrps-yiv-2082309084yiv1981364950hd {
#ygrps-yiv-2082309084 #ygrps-yiv-2082309084yiv1981364950 #ygrps-yiv-2082309084yiv1981364950ygrp-sponsor #ygrps-yiv-2082309084yiv1981364950ygrp-lc .ygrps-yiv-2082309084yiv1981364950ad {
#ygrps-yiv-2082309084 #ygrps-yiv-2082309084yiv1981364950 #ygrps-yiv-2082309084yiv1981364950actions {
#ygrps-yiv-2082309084 #ygrps-yiv-2082309084yiv1981364950 #ygrps-yiv-2082309084yiv1981364950activity {
#ygrps-yiv-2082309084 #ygrps-yiv-2082309084yiv1981364950 #ygrps-yiv-2082309084yiv1981364950activity span {
font-weight:700;}
#ygrps-yiv-2082309084 #ygrps-yiv-2082309084yiv1981364950 #ygrps-yiv-2082309084yiv1981364950activity span:first-child {
#ygrps-yiv-2082309084 #ygrps-yiv-2082309084yiv1981364950 #ygrps-yiv-2082309084yiv1981364950activity span a {
#ygrps-yiv-2082309084 #ygrps-yiv-2082309084yiv1981364950 #ygrps-yiv-2082309084yiv1981364950activity span span {
color:#ff7900;}
#ygrps-yiv-2082309084 #ygrps-yiv-2082309084yiv1981364950 #ygrps-yiv-2082309084yiv1981364950activity span .ygrps-yiv-2082309084yiv1981364950underline {
#ygrps-yiv-2082309084 #ygrps-yiv-2082309084yiv1981364950 .ygrps-yiv-2082309084yiv1981364950attach {
#ygrps-yiv-2082309084 #ygrps-yiv-2082309084yiv1981364950 .ygrps-yiv-2082309084yiv1981364950attach div a {
#ygrps-yiv-2082309084 #ygrps-yiv-2082309084yiv1981364950 .ygrps-yiv-2082309084yiv1981364950attach img {
#ygrps-yiv-2082309084 #ygrps-yiv-2082309084yiv1981364950 .ygrps-yiv-2082309084yiv1981364950attach label {
#ygrps-yiv-2082309084 #ygrps-yiv-2082309084yiv1981364950 .ygrps-yiv-2082309084yiv1981364950attach label a {
#ygrps-yiv-2082309084 #ygrps-yiv-2082309084yiv1981364950 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-2082309084 #ygrps-yiv-2082309084yiv1981364950 .ygrps-yiv-2082309084yiv1981364950bold {
#ygrps-yiv-2082309084 #ygrps-yiv-2082309084yiv1981364950 .ygrps-yiv-2082309084yiv1981364950bold a {
#ygrps-yiv-2082309084 #ygrps-yiv-2082309084yiv1981364950 dd.ygrps-yiv-2082309084yiv1981364950last p a {
#ygrps-yiv-2082309084 #ygrps-yiv-2082309084yiv1981364950 dd.ygrps-yiv-2082309084yiv1981364950last p span {
#ygrps-yiv-2082309084 #ygrps-yiv-2082309084yiv1981364950 dd.ygrps-yiv-2082309084yiv1981364950last p span.ygrps-yiv-2082309084yiv1981364950yshortcuts {
margin-right:0;}
#ygrps-yiv-2082309084 #ygrps-yiv-2082309084yiv1981364950 div.ygrps-yiv-2082309084yiv1981364950attach-table div div a {
#ygrps-yiv-2082309084 #ygrps-yiv-2082309084yiv1981364950 div.ygrps-yiv-2082309084yiv1981364950attach-table {
width:400px;}
#ygrps-yiv-2082309084 #ygrps-yiv-2082309084yiv1981364950 div.ygrps-yiv-2082309084yiv1981364950file-title a, #ygrps-yiv-2082309084 #ygrps-yiv-2082309084yiv1981364950 div.ygrps-yiv-2082309084yiv1981364950file-title a:active, #ygrps-yiv-2082309084 #ygrps-yiv-2082309084yiv1981364950 div.ygrps-yiv-2082309084yiv1981364950file-title a:hover, #ygrps-yiv-2082309084 #ygrps-yiv-2082309084yiv1981364950 div.ygrps-yiv-2082309084yiv1981364950file-title a:visited {
#ygrps-yiv-2082309084 #ygrps-yiv-2082309084yiv1981364950 div.ygrps-yiv-2082309084yiv1981364950photo-title a, #ygrps-yiv-2082309084 #ygrps-yiv-2082309084yiv1981364950 div.ygrps-yiv-2082309084yiv1981364950photo-title a:active, #ygrps-yiv-2082309084 #ygrps-yiv-2082309084yiv1981364950 div.ygrps-yiv-2082309084yiv1981364950photo-title a:hover, #ygrps-yiv-2082309084 #ygrps-yiv-2082309084yiv1981364950 div.ygrps-yiv-2082309084yiv1981364950photo-title a:visited {
#ygrps-yiv-2082309084 #ygrps-yiv-2082309084yiv1981364950 div#ygrps-yiv-2082309084yiv1981364950ygrp-mlmsg #ygrps-yiv-2082309084yiv1981364950ygrp-msg p a span.ygrps-yiv-2082309084yiv1981364950yshortcuts {
#ygrps-yiv-2082309084 #ygrps-yiv-2082309084yiv1981364950 .ygrps-yiv-2082309084yiv1981364950green {
color:#628c2a;}
#ygrps-yiv-2082309084 #ygrps-yiv-2082309084yiv1981364950 .ygrps-yiv-2082309084yiv1981364950MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-2082309084 #ygrps-yiv-2082309084yiv1981364950 o {
font-size:0;}
#ygrps-yiv-2082309084 #ygrps-yiv-2082309084yiv1981364950 #ygrps-yiv-2082309084yiv1981364950photos div {
#ygrps-yiv-2082309084 #ygrps-yiv-2082309084yiv1981364950 #ygrps-yiv-2082309084yiv1981364950photos div div {
#ygrps-yiv-2082309084 #ygrps-yiv-2082309084yiv1981364950 #ygrps-yiv-2082309084yiv1981364950photos div label {
#ygrps-yiv-2082309084 #ygrps-yiv-2082309084yiv1981364950 #ygrps-yiv-2082309084yiv1981364950reco-category {
font-size:77%;}
#ygrps-yiv-2082309084 #ygrps-yiv-2082309084yiv1981364950 #ygrps-yiv-2082309084yiv1981364950reco-desc {
font-size:77%;}
#ygrps-yiv-2082309084 #ygrps-yiv-2082309084yiv1981364950 .ygrps-yiv-2082309084yiv1981364950replbq {
margin:4px;}
#ygrps-yiv-2082309084 #ygrps-yiv-2082309084yiv1981364950 #ygrps-yiv-2082309084yiv1981364950ygrp-actbar div a:first-child {
#ygrps-yiv-2082309084 #ygrps-yiv-2082309084yiv1981364950 #ygrps-yiv-2082309084yiv1981364950ygrp-mlmsg {
#ygrps-yiv-2082309084 #ygrps-yiv-2082309084yiv1981364950 #ygrps-yiv-2082309084yiv1981364950ygrp-mlmsg table {
#ygrps-yiv-2082309084 #ygrps-yiv-2082309084yiv1981364950 #ygrps-yiv-2082309084yiv1981364950ygrp-mlmsg select, #ygrps-yiv-2082309084 #ygrps-yiv-2082309084yiv1981364950 input, #ygrps-yiv-2082309084 #ygrps-yiv-2082309084yiv1981364950 textarea {
#ygrps-yiv-2082309084 #ygrps-yiv-2082309084yiv1981364950 #ygrps-yiv-2082309084yiv1981364950ygrp-mlmsg pre, #ygrps-yiv-2082309084 #ygrps-yiv-2082309084yiv1981364950 code {
#ygrps-yiv-2082309084 #ygrps-yiv-2082309084yiv1981364950 #ygrps-yiv-2082309084yiv1981364950ygrp-mlmsg * {
#ygrps-yiv-2082309084 #ygrps-yiv-2082309084yiv1981364950 #ygrps-yiv-2082309084yiv1981364950ygrp-mlmsg #ygrps-yiv-2082309084yiv1981364950logo {
#ygrps-yiv-2082309084 #ygrps-yiv-2082309084yiv1981364950 #ygrps-yiv-2082309084yiv1981364950ygrp-msg p a {
#ygrps-yiv-2082309084 #ygrps-yiv-2082309084yiv1981364950 #ygrps-yiv-2082309084yiv1981364950ygrp-msg p#ygrps-yiv-2082309084yiv1981364950attach-count span {
#ygrps-yiv-2082309084 #ygrps-yiv-2082309084yiv1981364950 #ygrps-yiv-2082309084yiv1981364950ygrp-reco #ygrps-yiv-2082309084yiv1981364950reco-head {
#ygrps-yiv-2082309084 #ygrps-yiv-2082309084yiv1981364950 #ygrps-yiv-2082309084yiv1981364950ygrp-reco {
#ygrps-yiv-2082309084 #ygrps-yiv-2082309084yiv1981364950 #ygrps-yiv-2082309084yiv1981364950ygrp-sponsor #ygrps-yiv-2082309084yiv1981364950ov li a {
#ygrps-yiv-2082309084 #ygrps-yiv-2082309084yiv1981364950 #ygrps-yiv-2082309084yiv1981364950ygrp-sponsor #ygrps-yiv-2082309084yiv1981364950ov li {
#ygrps-yiv-2082309084 #ygrps-yiv-2082309084yiv1981364950 #ygrps-yiv-2082309084yiv1981364950ygrp-sponsor #ygrps-yiv-2082309084yiv1981364950ov ul {
#ygrps-yiv-2082309084 #ygrps-yiv-2082309084yiv1981364950 #ygrps-yiv-2082309084yiv1981364950ygrp-text {
#ygrps-yiv-2082309084 #ygrps-yiv-2082309084yiv1981364950 #ygrps-yiv-2082309084yiv1981364950ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-2082309084 #ygrps-yiv-2082309084yiv1981364950 #ygrps-yiv-2082309084yiv1981364950ygrp-text tt {
font-size:120%;}
#ygrps-yiv-2082309084 #ygrps-yiv-2082309084yiv1981364950 #ygrps-yiv-2082309084yiv1981364950ygrp-vital ul li:last-child {
