Microsoft Sign in error
Many users here are getting this Microsoft Sign in error which seems to have started today:
Sometimes a refresh fixes it, sometimes not. I am using Edge. Any ideas what could be causing it or how to fix it?
The error indicates that the URI shown in the error message is not configured as a Redirect URI in the Entra ID App Registration associated with the Application ID referenced in the error.
Because Redirect URIs are case-sensitive, copy the exact URI shown between the single quotes in the error message and add it to the App Registration > Authentication > Redirect URIs section. Be sure the value matches exactly, including letter casing, as any differences will cause the redirect validation to fail.
Where is this screen from? Thanks
From Entra ID in your MSO365 tenant.
Jim, there are instructions on this when you set up SSO with Entra/Azure AD. You can look them up in Kinetic help. They will walk you through it all.
Understanding Azure AD Authentication – Kinetic Help
This may be due to the linux change too: Kinetic on Linux · GitHub
Linux Container Migration: Let’s Consolidate the Chaos - Kinetic ERP - Epicor User Help Forum
