Migration from 9 to 10
I am hoping that the product will remain solid and less bugs.  This should happen since it is just one platform and more concentration on one version for testing.
From: vantage@yahoogroups.com [vantage@yahoogroups.com]
Sent: Friday, December 12, 2014 10:49 AM
To: Vantage
Subject: Re: [Vantage] Migration from 9 to 10
If you have a vanilla epicor install (minimaly customized)
The migration is painless and quick. Of-course if you have customized it heavily that is going to significantly damper your migration.
You have to re-do all BPM,s and fix customization
Re-write all your reports in SSRS (though you can get Crystal to work.. mostly)
The product is solid and its a great "TECHNICAL" improvement though very little actual functionality was changed outside of bug fixing.
Jose C Gomez
Software Engineer
T: 904.469.1524 mobile
On Fri, Dec 12, 2014 at 1:37 PM, Jeff mmartian_q36@... [vantage] <vantage@yahoogroups.com> wrote:
    Greetings,
         I am coming to the conclusion that the only way we will get the software to work correctly in the quote module is to migrate from 9.05 to version 10. Epicor tells me this is a serious upgrade in the software, as well as a fairly painless migration. However, based on my experience with them, Epicor is going to tell us whatever is best for Epicor, not what is best for us.
        So I pose a few questions to anyone in the group that has moved from 9 to 10
        1) How big of an improvement is the software upgrade?
        2) How painful was the migration?
        3) How large of a database was involved in the migration?
    Thanks in advance.
    - Jeff Stimson
MASS Precision, Inc.
Has anyone else found if you change the customer after a quote is completed it removes the quoted price. I am trying to determine if this is how the software is supposed to function or it is bug.
-Phil
Yep.  We have experienced this "feature" as well.  Here's summary of note to our personnel:
It has recently been brought to our attention that changing the Customer ID on a saved quote deletes pricing as well as “grid” quantity data . This causes the Quote printout to not agree with the quantity / pricing on the Quote line / summary data.  When this occurs, the data for quantity and price needs to get input again into the grid data on the line(s).  NOTE:  It is always good practice to compare the Quote printout Lines total price against the summary tab data, to ensure agreement between printout and quote.
<!-- #ygrps-yiv-123789862 _filtered #ygrps-yiv-123789862 {font-family:Wingdings; panose-1:5 0 0 0 0 0 0 0 0 0;} _filtered #ygrps-yiv-123789862 {font-family:Wingdings; panose-1:5 0 0 0 0 0 0 0 0 0;} _filtered #ygrps-yiv-123789862 {font-family:Calibri; panose-1:2 15 5 2 2 2 4 3 2 4;} _filtered #ygrps-yiv-123789862 {font-family:Verdana; panose-1:2 11 6 4 3 5 4 4 2 4;} _filtered #ygrps-yiv-123789862 {font-family:Consolas; panose-1:2 11 6 9 2 2 4 3 2 4;} #ygrps-yiv-123789862 #ygrps-yiv-123789862 p.ygrps-yiv-123789862MsoNormal, #ygrps-yiv-123789862 li.ygrps-yiv-123789862MsoNormal, #ygrps-yiv-123789862 div.ygrps-yiv-123789862MsoNormal {margin:0in; margin-bottom:.0001pt; font-size:12.0pt; font-family:"Times New Roman", "serif";} #ygrps-yiv-123789862 a:link, #ygrps-yiv-123789862 span.ygrps-yiv-123789862MsoHyperlink { color:blue; text-decoration:underline;} #ygrps-yiv-123789862 a:visited, #ygrps-yiv-123789862 span.ygrps-yiv-123789862MsoHyperlinkFollowed { color:purple; text-decoration:underline;} #ygrps-yiv-123789862 p {
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
font-family:“Times New Roman”, “serif”;}
#ygrps-yiv-123789862 code
font-family:“Courier New”;}
#ygrps-yiv-123789862 pre
margin:0in;
font-size:10.0pt;
#ygrps-yiv-123789862 tt
#ygrps-yiv-123789862 span.ygrps-yiv-123789862cat
#ygrps-yiv-123789862 span.ygrps-yiv-123789862ct
#ygrps-yiv-123789862 span.ygrps-yiv-123789862HTMLPreformattedChar
font-family:Consolas;}
#ygrps-yiv-123789862 p.ygrps-yiv-123789862attach, #ygrps-yiv-123789862 li.ygrps-yiv-123789862attach, #ygrps-yiv-123789862 div.ygrps-yiv-123789862attach
margin-right:0in;
margin-left:0in;
font-size:9.0pt;
font-family:“Arial”, “sans-serif”;}
#ygrps-yiv-123789862 p.ygrps-yiv-123789862bold, #ygrps-yiv-123789862 li.ygrps-yiv-123789862bold, #ygrps-yiv-123789862 div.ygrps-yiv-123789862bold
margin-right:0in;
margin-left:0in;
font-size:10.0pt;
font-weight:bold;}
#ygrps-yiv-123789862 p.ygrps-yiv-123789862green, #ygrps-yiv-123789862 li.ygrps-yiv-123789862green, #ygrps-yiv-123789862 div.ygrps-yiv-123789862green
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
color:#628C2A;}
#ygrps-yiv-123789862 p.ygrps-yiv-123789862replbq, #ygrps-yiv-123789862 li.ygrps-yiv-123789862replbq, #ygrps-yiv-123789862 div.ygrps-yiv-123789862replbq
margin:3.0pt;
font-size:12.0pt;
#ygrps-yiv-123789862 p.ygrps-yiv-123789862ad, #ygrps-yiv-123789862 li.ygrps-yiv-123789862ad, #ygrps-yiv-123789862 div.ygrps-yiv-123789862ad
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-123789862 p.ygrps-yiv-123789862underline, #ygrps-yiv-123789862 li.ygrps-yiv-123789862underline, #ygrps-yiv-123789862 div.ygrps-yiv-123789862underline
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-123789862 span.ygrps-yiv-123789862yshortcuts
#ygrps-yiv-123789862 p.ygrps-yiv-123789862ad1, #ygrps-yiv-123789862 li.ygrps-yiv-123789862ad1, #ygrps-yiv-123789862 div.ygrps-yiv-123789862ad1
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-123789862 p.ygrps-yiv-123789862ad2, #ygrps-yiv-123789862 li.ygrps-yiv-123789862ad2, #ygrps-yiv-123789862 div.ygrps-yiv-123789862ad2
margin-right:0in;
margin-bottom:7.5pt;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-123789862 p.ygrps-yiv-123789862underline1, #ygrps-yiv-123789862 li.ygrps-yiv-123789862underline1, #ygrps-yiv-123789862 div.ygrps-yiv-123789862underline1
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-123789862 span.ygrps-yiv-123789862yshortcuts1
font-family:“Verdana”, “sans-serif”;
font-weight:bold;}
#ygrps-yiv-123789862 span.ygrps-yiv-123789862yshortcuts2
font-weight:normal;}
#ygrps-yiv-123789862 span.ygrps-yiv-123789862EmailStyle36
font-family:“Calibri”, “sans-serif”;
color:#1F497D;}
#ygrps-yiv-123789862 .ygrps-yiv-123789862MsoChpDefault
font-size:10.0pt;}
margin:1.0in 1.0in 1.0in 1.0in;}
#ygrps-yiv-123789862 div.ygrps-yiv-123789862WordSection1
font-family:Symbol;}
font-family:Wingdings;}
#ygrps-yiv-123789862 ol
{margin-bottom:0in;}
#ygrps-yiv-123789862 ul
Yes, it is a huge pain in the neck! My program managers and sales people have complained to me many times. I have not reported it to Epicor as I just assumed it was designed that way (and also assuming they will not be fixing 9.05 anymore now that 10 is out since we had another major issue and that was what they told us). If you report it and get an SCR# let me know I will add my name to it!
There are several SCR’s that relate to this situation:
SCR 134551 – Sales Kit Qty breaks wrong when customer changes - Open
SCR 83449 – Line Qty breaks overwritten when customer changes - Open
SCR 131688 – Changing customer sets price to zeros for non-master parts – Fixed in 10.1
The last one for us is the biggie…
Regards,
Chris Wineinger
ERP Specialist
Interior Systems, Inc.
241 N Broadway Ste 600
Milwaukee, WI 53202
Office # 414.224.0957 X2051
Direct# 414.847.0701
Cell # 414.840.6594
IT related problem? Contact helpdesk@...
Epicor sent us a fix for this on 9.05.702a progress 64-bit... from SCR58041.
Haven't been able to test it yet; but I was told the fix was over a year old.
How about co-parts being created when getting details from previous rev parts? This doubles run time and cuts rates in half, but leaves setup time alone. Makes the price low.
Or deleting out a subassembly and it magically deletes the whole quote? Obvious issues there, lose all the work you did on a quote
Those are our two biggies. 3229811ESC is the number we have to work with, as they haven't been able to fix this yet.
Sincerely,
Jeff Stimson
Engineer/Programmer
From: "Chris Wineinger cwineinger@… [vantage]" <vantage@yahoogroups.com>
To: "vantage@yahoogroups.com" <vantage@yahoogroups.com>
Sent: Thursday, December 11, 2014 7:12 AM
Subject: [Vantage] Re: Epicor 9 702A Quoting module
<div id="ygrps-yiv-491661218yiv5479372342ygrp-text">
  <div>
Regards,
Chris Wineinger
ERP Specialist
Milwaukee, WI 53202
Cell # 414.840.6594
</div>
Was a fix a DLL file?
We are running the same setup.
Miguel A. Santillan
Compass Manufacturing Systems
Sent: Thursday, December 11, 2014 7:37 AM
I had to submit a Business Impact Reason to get the one off.
There are a whole slew of .DLLs to be replaced... which is one of the reasons I haven't tested yet.
I worked numerous Saturday nights installing, testing and then removing one-offs in the quote module. A couple are still in place, most did not work. I feel your pain and your reluctance to test.
Additionally, just getting one-offs from Epicor is like pulling teeth. Their attitude kills me. Provide us with a business reason why we should make the software work right.
EXCUSE ME???? Am I the only one that gets frustrated with Epicor and their attitude of "Why should we fix this for you?" and "Just get version 10, it fixes all of your issues"? We paid for working software in 9 and have yet to have the quote module work in an accurate, consistent and effective manner.
Sorry for the hijack, but this caught me in the middle of yet another battle with them to fix something. I am getting EXTREMELY frustrated with their company attitude.
- Jeff Stimson
From: "jbillet@... [vantage]" <vantage@yahoogroups.com>
Sent: Thursday, December 11, 2014 1:05 PM
<div id="ygrps-yiv-645197632yiv4142327808ygrp-text">
  <div></div><div id="ygrps-yiv-645197632yui_3_16_0_1_1418331044536_3548">I had to submit a Business Impact Reason to get the one off.</div><div id="ygrps-yiv-645197632yui_3_16_0_1_1418331044536_3550">There are a whole slew of .DLLs to be replaced... which is one of the reasons I haven&#39;t tested yet.<br class="ygrps-yiv-645197632yiv4142327808yui-cursor" clear="none"></div>
</div>
<div style="height:0px;color:rgb(255, 255, 255);"></div></div>
#ygrps-yiv-645197632 #ygrps-yiv-645197632yiv4142327808 #ygrps-yiv-645197632yiv4142327808 -- #ygrps-yiv-645197632yiv4142327808ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}
#ygrps-yiv-645197632 #ygrps-yiv-645197632yiv4142327808 #ygrps-yiv-645197632yiv4142327808ygrp-mkp hr {
border:1px solid #d8d8d8;}
#ygrps-yiv-645197632 #ygrps-yiv-645197632yiv4142327808 #ygrps-yiv-645197632yiv4142327808ygrp-mkp #ygrps-yiv-645197632yiv4142327808hd {
color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}
#ygrps-yiv-645197632 #ygrps-yiv-645197632yiv4142327808 #ygrps-yiv-645197632yiv4142327808ygrp-mkp #ygrps-yiv-645197632yiv4142327808ads {
margin-bottom:10px;}
#ygrps-yiv-645197632 #ygrps-yiv-645197632yiv4142327808 #ygrps-yiv-645197632yiv4142327808ygrp-mkp .ygrps-yiv-645197632yiv4142327808ad {
padding:0 0;}
#ygrps-yiv-645197632 #ygrps-yiv-645197632yiv4142327808 #ygrps-yiv-645197632yiv4142327808ygrp-mkp .ygrps-yiv-645197632yiv4142327808ad p {
margin:0;}
#ygrps-yiv-645197632 #ygrps-yiv-645197632yiv4142327808 #ygrps-yiv-645197632yiv4142327808ygrp-mkp .ygrps-yiv-645197632yiv4142327808ad a {
color:#0000ff;text-decoration:none;}
#ygrps-yiv-645197632 #ygrps-yiv-645197632yiv4142327808 #ygrps-yiv-645197632yiv4142327808ygrp-sponsor #ygrps-yiv-645197632yiv4142327808ygrp-lc {
font-family:Arial;}
#ygrps-yiv-645197632 #ygrps-yiv-645197632yiv4142327808 #ygrps-yiv-645197632yiv4142327808ygrp-sponsor #ygrps-yiv-645197632yiv4142327808ygrp-lc #ygrps-yiv-645197632yiv4142327808hd {
margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}
#ygrps-yiv-645197632 #ygrps-yiv-645197632yiv4142327808 #ygrps-yiv-645197632yiv4142327808ygrp-sponsor #ygrps-yiv-645197632yiv4142327808ygrp-lc .ygrps-yiv-645197632yiv4142327808ad {
margin-bottom:10px;padding:0 0;}
#ygrps-yiv-645197632 #ygrps-yiv-645197632yiv4142327808 #ygrps-yiv-645197632yiv4142327808actions {
font-family:Verdana;font-size:11px;padding:10px 0;}
#ygrps-yiv-645197632 #ygrps-yiv-645197632yiv4142327808 #ygrps-yiv-645197632yiv4142327808activity {
background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}
#ygrps-yiv-645197632 #ygrps-yiv-645197632yiv4142327808 #ygrps-yiv-645197632yiv4142327808activity span {
font-weight:700;}
#ygrps-yiv-645197632 #ygrps-yiv-645197632yiv4142327808 #ygrps-yiv-645197632yiv4142327808activity span:first-child {
text-transform:uppercase;}
#ygrps-yiv-645197632 #ygrps-yiv-645197632yiv4142327808 #ygrps-yiv-645197632yiv4142327808activity span a {
color:#5085b6;text-decoration:none;}
#ygrps-yiv-645197632 #ygrps-yiv-645197632yiv4142327808 #ygrps-yiv-645197632yiv4142327808activity span span {
color:#ff7900;}
#ygrps-yiv-645197632 #ygrps-yiv-645197632yiv4142327808 #ygrps-yiv-645197632yiv4142327808activity span .ygrps-yiv-645197632yiv4142327808underline {
#ygrps-yiv-645197632 #ygrps-yiv-645197632yiv4142327808 .ygrps-yiv-645197632yiv4142327808attach {
clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}
#ygrps-yiv-645197632 #ygrps-yiv-645197632yiv4142327808 .ygrps-yiv-645197632yiv4142327808attach div a {
#ygrps-yiv-645197632 #ygrps-yiv-645197632yiv4142327808 .ygrps-yiv-645197632yiv4142327808attach img {
border:none;padding-right:5px;}
#ygrps-yiv-645197632 #ygrps-yiv-645197632yiv4142327808 .ygrps-yiv-645197632yiv4142327808attach label {
display:block;margin-bottom:5px;}
#ygrps-yiv-645197632 #ygrps-yiv-645197632yiv4142327808 .ygrps-yiv-645197632yiv4142327808attach label a {
#ygrps-yiv-645197632 #ygrps-yiv-645197632yiv4142327808 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-645197632 #ygrps-yiv-645197632yiv4142327808 .ygrps-yiv-645197632yiv4142327808bold {
font-family:Arial;font-size:13px;font-weight:700;}
#ygrps-yiv-645197632 #ygrps-yiv-645197632yiv4142327808 .ygrps-yiv-645197632yiv4142327808bold a {
#ygrps-yiv-645197632 #ygrps-yiv-645197632yiv4142327808 dd.ygrps-yiv-645197632yiv4142327808last p a {
font-family:Verdana;font-weight:700;}
#ygrps-yiv-645197632 #ygrps-yiv-645197632yiv4142327808 dd.ygrps-yiv-645197632yiv4142327808last p span {
margin-right:10px;font-family:Verdana;font-weight:700;}
#ygrps-yiv-645197632 #ygrps-yiv-645197632yiv4142327808 dd.ygrps-yiv-645197632yiv4142327808last p span.ygrps-yiv-645197632yiv4142327808yshortcuts {
margin-right:0;}
#ygrps-yiv-645197632 #ygrps-yiv-645197632yiv4142327808 div.ygrps-yiv-645197632yiv4142327808attach-table div div a {
#ygrps-yiv-645197632 #ygrps-yiv-645197632yiv4142327808 div.ygrps-yiv-645197632yiv4142327808attach-table {
width:400px;}
#ygrps-yiv-645197632 #ygrps-yiv-645197632yiv4142327808 div.ygrps-yiv-645197632yiv4142327808file-title a, #ygrps-yiv-645197632 #ygrps-yiv-645197632yiv4142327808 div.ygrps-yiv-645197632yiv4142327808file-title a:active, #ygrps-yiv-645197632 #ygrps-yiv-645197632yiv4142327808 div.ygrps-yiv-645197632yiv4142327808file-title a:hover, #ygrps-yiv-645197632 #ygrps-yiv-645197632yiv4142327808 div.ygrps-yiv-645197632yiv4142327808file-title a:visited {
#ygrps-yiv-645197632 #ygrps-yiv-645197632yiv4142327808 div.ygrps-yiv-645197632yiv4142327808photo-title a, #ygrps-yiv-645197632 #ygrps-yiv-645197632yiv4142327808 div.ygrps-yiv-645197632yiv4142327808photo-title a:active, #ygrps-yiv-645197632 #ygrps-yiv-645197632yiv4142327808 div.ygrps-yiv-645197632yiv4142327808photo-title a:hover, #ygrps-yiv-645197632 #ygrps-yiv-645197632yiv4142327808 div.ygrps-yiv-645197632yiv4142327808photo-title a:visited {
#ygrps-yiv-645197632 #ygrps-yiv-645197632yiv4142327808 div#ygrps-yiv-645197632yiv4142327808ygrp-mlmsg #ygrps-yiv-645197632yiv4142327808ygrp-msg p a span.ygrps-yiv-645197632yiv4142327808yshortcuts {
font-family:Verdana;font-size:10px;font-weight:normal;}
#ygrps-yiv-645197632 #ygrps-yiv-645197632yiv4142327808 .ygrps-yiv-645197632yiv4142327808green {
color:#628c2a;}
#ygrps-yiv-645197632 #ygrps-yiv-645197632yiv4142327808 .ygrps-yiv-645197632yiv4142327808MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-645197632 #ygrps-yiv-645197632yiv4142327808 o {
font-size:0;}
#ygrps-yiv-645197632 #ygrps-yiv-645197632yiv4142327808 #ygrps-yiv-645197632yiv4142327808photos div {
float:left;width:72px;}
#ygrps-yiv-645197632 #ygrps-yiv-645197632yiv4142327808 #ygrps-yiv-645197632yiv4142327808photos div div {
border:1px solid #666666;height:62px;overflow:hidden;width:62px;}
#ygrps-yiv-645197632 #ygrps-yiv-645197632yiv4142327808 #ygrps-yiv-645197632yiv4142327808photos div label {
color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}
#ygrps-yiv-645197632 #ygrps-yiv-645197632yiv4142327808 #ygrps-yiv-645197632yiv4142327808reco-category {
font-size:77%;}
#ygrps-yiv-645197632 #ygrps-yiv-645197632yiv4142327808 #ygrps-yiv-645197632yiv4142327808reco-desc {
font-size:77%;}
#ygrps-yiv-645197632 #ygrps-yiv-645197632yiv4142327808 .ygrps-yiv-645197632yiv4142327808replbq {
margin:4px;}
#ygrps-yiv-645197632 #ygrps-yiv-645197632yiv4142327808 #ygrps-yiv-645197632yiv4142327808ygrp-actbar div a:first-child {
margin-right:2px;padding-right:5px;}
#ygrps-yiv-645197632 #ygrps-yiv-645197632yiv4142327808 #ygrps-yiv-645197632yiv4142327808ygrp-mlmsg {
font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}
#ygrps-yiv-645197632 #ygrps-yiv-645197632yiv4142327808 #ygrps-yiv-645197632yiv4142327808ygrp-mlmsg table {
font-size:inherit;font:100%;}
#ygrps-yiv-645197632 #ygrps-yiv-645197632yiv4142327808 #ygrps-yiv-645197632yiv4142327808ygrp-mlmsg select, #ygrps-yiv-645197632 #ygrps-yiv-645197632yiv4142327808 input, #ygrps-yiv-645197632 #ygrps-yiv-645197632yiv4142327808 textarea {
font:99% Arial, Helvetica, clean, sans-serif;}
#ygrps-yiv-645197632 #ygrps-yiv-645197632yiv4142327808 #ygrps-yiv-645197632yiv4142327808ygrp-mlmsg pre, #ygrps-yiv-645197632 #ygrps-yiv-645197632yiv4142327808 code {
font:115% monospace;}
#ygrps-yiv-645197632 #ygrps-yiv-645197632yiv4142327808 #ygrps-yiv-645197632yiv4142327808ygrp-mlmsg * {
line-height:1.22em;}
#ygrps-yiv-645197632 #ygrps-yiv-645197632yiv4142327808 #ygrps-yiv-645197632yiv4142327808ygrp-mlmsg #ygrps-yiv-645197632yiv4142327808logo {
padding-bottom:10px;}
#ygrps-yiv-645197632 #ygrps-yiv-645197632yiv4142327808 #ygrps-yiv-645197632yiv4142327808ygrp-msg p a {
font-family:Verdana;}
#ygrps-yiv-645197632 #ygrps-yiv-645197632yiv4142327808 #ygrps-yiv-645197632yiv4142327808ygrp-msg p#ygrps-yiv-645197632yiv4142327808attach-count span {
color:#1E66AE;font-weight:700;}
#ygrps-yiv-645197632 #ygrps-yiv-645197632yiv4142327808 #ygrps-yiv-645197632yiv4142327808ygrp-reco #ygrps-yiv-645197632yiv4142327808reco-head {
color:#ff7900;font-weight:700;}
#ygrps-yiv-645197632 #ygrps-yiv-645197632yiv4142327808 #ygrps-yiv-645197632yiv4142327808ygrp-reco {
margin-bottom:20px;padding:0px;}
#ygrps-yiv-645197632 #ygrps-yiv-645197632yiv4142327808 #ygrps-yiv-645197632yiv4142327808ygrp-sponsor #ygrps-yiv-645197632yiv4142327808ov li a {
font-size:130%;text-decoration:none;}
#ygrps-yiv-645197632 #ygrps-yiv-645197632yiv4142327808 #ygrps-yiv-645197632yiv4142327808ygrp-sponsor #ygrps-yiv-645197632yiv4142327808ov li {
font-size:77%;list-style-type:square;padding:6px 0;}
#ygrps-yiv-645197632 #ygrps-yiv-645197632yiv4142327808 #ygrps-yiv-645197632yiv4142327808ygrp-sponsor #ygrps-yiv-645197632yiv4142327808ov ul {
margin:0;padding:0 0 0 8px;}
#ygrps-yiv-645197632 #ygrps-yiv-645197632yiv4142327808 #ygrps-yiv-645197632yiv4142327808ygrp-text {
font-family:Georgia;}
#ygrps-yiv-645197632 #ygrps-yiv-645197632yiv4142327808 #ygrps-yiv-645197632yiv4142327808ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-645197632 #ygrps-yiv-645197632yiv4142327808 #ygrps-yiv-645197632yiv4142327808ygrp-text tt {
font-size:120%;}
#ygrps-yiv-645197632 #ygrps-yiv-645197632yiv4142327808 #ygrps-yiv-645197632yiv4142327808ygrp-vital ul li:last-child {
border-right:none !important;}
Here is all the changes...I need to test on my test server tomorrow.
     Server
          Server\bo\Configuration     Configuration.i
          Server\bo\Configuration     Configuration.r
          Server\bo\Configuration     Configuration_ds.i
          Server\bo\Configuration     DefaultUpdateExt.r
          Server\bo\Configuration     Sink.r
          Server\bo\JobEntry     DefaultUpdateExt.r
          Server\bo\JobEntry     JobEntry.i
          Server\bo\JobEntry     JobEntry.r
          Server\bo\JobEntry     JobEntry_ds.i
          Server\bo\JobEntry     Sink.r
          Server\bo\Quote     DefaultUpdateExt.r
          Server\bo\Quote     Quote.i
          Server\bo\Quote     Quote.r
          Server\bo\Quote     Quote_ds.i
          Server\bo\Quote     QuoteTrg.r
          Server\bo\Quote     Sink.r
          Server\bo\QuoteAsm     DefaultUpdateExt.r
          Server\bo\QuoteAsm     QuoteAsm.i
          Server\bo\QuoteAsm     QuoteAsm.r
          Server\bo\QuoteAsm     QuoteAsm_ds.i
          Server\bo\QuoteAsm     Sink.r
          Server\db\trg\quotedtl     write.r
          Server\lib     QuoteAsmDel.r
          Server\pc     GenCode.r
          Server\pc     GenConfigSequence.r
          Server\pc     GenerateMethods.r
          Server\pc     GetConfigurationSequence.r
          Server\pc     pce10-pc.r
          Server\pc     Pcp10-sf.r
     Client
          Epicor.Mfg.AD.Configuration.dll
          Epicor.Mfg.AD.Quote.dll
          Epicor.Mfg.BO.Configuration.dll
          Epicor.Mfg.BO.Quote.dll
          Epicor.Mfg.BO.QuoteAsm.dll
          Epicor.Mfg.IF.IConfiguration.dll
          Epicor.Mfg.IF.IQuote.dll
          Epicor.Mfg.IF.IQuoteAsm.dll
          Epicor.Mfg.UI.ConfigurationEntry.dll
          Epicor.Mfg.UI.QuoteEntry.dll
Sent: Thursday, December 11, 2014 1:16 PM
Subject: Re: [Vantage] Re: Epicor 9 702A Quoting module
EXCUSE ME???? Am I the only one that gets frustrated with Epicor and their attitude of "Why should we fix this for you?" and "Just get vers ion 10, it fixes all of your issues"? We paid for working software in 9 and have yet to have the quote module work in an accurate, consistent and effective manner.
- Jeff Stimson
<!-- #ygrps-yiv-25796699 _filtered #ygrps-yiv-25796699 {font-family:Wingdings; panose-1:5 0 0 0 0 0 0 0 0 0;} _filtered #ygrps-yiv-25796699 {font-family:Wingdings; panose-1:5 0 0 0 0 0 0 0 0 0;} _filtered #ygrps-yiv-25796699 {font-family:Calibri; panose-1:2 15 5 2 2 2 4 3 2 4;} _filtered #ygrps-yiv-25796699 {font-family:Tahoma; panose-1:2 11 6 4 3 5 4 4 2 4;} _filtered #ygrps-yiv-25796699 {font-family:Verdana; panose-1:2 11 6 4 3 5 4 4 2 4;} _filtered #ygrps-yiv-25796699 {font-family:Consolas; panose-1:2 11 6 9 2 2 4 3 2 4;} #ygrps-yiv-25796699 #ygrps-yiv-25796699 p.ygrps-yiv-25796699MsoNormal, #ygrps-yiv-25796699 li.ygrps-yiv-25796699MsoNormal, #ygrps-yiv-25796699 div.ygrps-yiv-25796699MsoNormal {margin:0in; margin-bottom:.0001pt; font-size:12.0pt; font-family:"Times New Roman", "serif";} #ygrps-yiv-25796699 a:link, #ygrps-yiv-25796699 span.ygrps-yiv-25796699MsoHyperlink { color:blue; text-decoration:underline;} #ygrps-yiv-25796699 a:visited, #ygrps-yiv-25796699 span.ygrps-yiv-25796699MsoHyperlinkFollowed { color:purple; text-decoration:underline;} #ygrps-yiv-25796699 p {
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-25796699 code
#ygrps-yiv-25796699 pre
margin:0in;
font-size:10.0pt;
#ygrps-yiv-25796699 tt
#ygrps-yiv-25796699 p.ygrps-yiv-25796699MsoAcetate, #ygrps-yiv-25796699 li.ygrps-yiv-25796699MsoAcetate, #ygrps-yiv-25796699 div.ygrps-yiv-25796699MsoAcetate
margin:0in;
font-size:8.0pt;
font-family:“Tahoma”, “sans-serif”;}
#ygrps-yiv-25796699 span.ygrps-yiv-25796699cat
#ygrps-yiv-25796699 span.ygrps-yiv-25796699ct
#ygrps-yiv-25796699 span.ygrps-yiv-25796699HTMLPreformattedChar
#ygrps-yiv-25796699 p.ygrps-yiv-25796699attach, #ygrps-yiv-25796699 li.ygrps-yiv-25796699attach, #ygrps-yiv-25796699 div.ygrps-yiv-25796699attach
margin-right:0in;
margin-left:0in;
font-size:9.0pt;
#ygrps-yiv-25796699 p.ygrps-yiv-25796699bold, #ygrps-yiv-25796699 li.ygrps-yiv-25796699bold, #ygrps-yiv-25796699 div.ygrps-yiv-25796699bold
margin-right:0in;
margin-left:0in;
font-size:10.0pt;
font-weight:bold;}
#ygrps-yiv-25796699 p.ygrps-yiv-25796699green, #ygrps-yiv-25796699 li.ygrps-yiv-25796699green, #ygrps-yiv-25796699 div.ygrps-yiv-25796699green
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
color:#628C2A;}
#ygrps-yiv-25796699 p.ygrps-yiv-25796699replbq, #ygrps-yiv-25796699 li.ygrps-yiv-25796699replbq, #ygrps-yiv-25796699 div.ygrps-yiv-25796699replbq
margin:3.0pt;
font-size:12.0pt;
#ygrps-yiv-25796699 p.ygrps-yiv-25796699ad, #ygrps-yiv-25796699 li.ygrps-yiv-25796699ad, #ygrps-yiv-25796699 div.ygrps-yiv-25796699ad
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-25796699 p.ygrps-yiv-25796699underline, #ygrps-yiv-25796699 li.ygrps-yiv-25796699underline, #ygrps-yiv-25796699 div.ygrps-yiv-25796699underline
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-25796699 span.ygrps-yiv-25796699yshortcuts
#ygrps-yiv-25796699 p.ygrps-yiv-25796699ad1, #ygrps-yiv-25796699 li.ygrps-yiv-25796699ad1, #ygrps-yiv-25796699 div.ygrps-yiv-25796699ad1
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-25796699 p.ygrps-yiv-25796699ad2, #ygrps-yiv-25796699 li.ygrps-yiv-25796699ad2, #ygrps-yiv-25796699 div.ygrps-yiv-25796699ad2
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-25796699 p.ygrps-yiv-25796699underline1, #ygrps-yiv-25796699 li.ygrps-yiv-25796699underline1, #ygrps-yiv-25796699 div.ygrps-yiv-25796699underline1
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-25796699 span.ygrps-yiv-25796699yshortcuts1
font-weight:bold;}
#ygrps-yiv-25796699 span.ygrps-yiv-25796699yshortcuts2
#ygrps-yiv-25796699 span.ygrps-yiv-25796699BalloonTextChar
#ygrps-yiv-25796699 span.ygrps-yiv-25796699EmailStyle38
color:#1F497D;}
#ygrps-yiv-25796699 .ygrps-yiv-25796699MsoChpDefault
font-size:10.0pt;}
#ygrps-yiv-25796699 div.ygrps-yiv-25796699WordSection1
#ygrps-yiv-25796699
#ygrps-yiv-25796699 ol
#ygrps-yiv-25796699 ul
Hi Jett – I am completely with you on this. The other thing that drives me nuts is when we find the issue and report it, to find out it is a known issue. These known issues should be provided to existing users before we run into them ourselves. We had another MAJOR issue which was a known issue which messed up all of our job costing but took us a while to discover. (and no fix for that one except “coming on vers 10 or 10.1” I just had to disable the feature in 9.05). LKuckily there was a fix to get the job costing corrected, but not to address the functional issue. 75% of my support calls are asking for fixes for things that are broken.Â
Good luck, I really hope it works for you
Sent from Yahoo Mail on Android
From:"Miguel Santillan msantillan@... [vantage]" <vantage@yahoogroups.com>
Date:Thu, Dec 11, 2014 at 7:19 PM
Subject:RE: [Vantage] Re: Epicor 9 702A Quoting module
Â
<div id="ygrps-yiv-329935539ygrp-text">
  <p>
   ServerÂ
         Server\bo\Configuration    Configuration.iÂ
         Server\bo\Configuration    Configuration.rÂ
         Server\bo\Configuration    Configuration_ds.iÂ
         Server\bo\Configuration    DefaultUpdateExt.rÂ
         Server\bo\Configuration    Sink.rÂ
         Server\bo\JobEntry    DefaultUpdateExt.rÂ
         Server\bo\JobEntry    JobEntry.iÂ
         Server\bo\JobEntry    JobEntry.rÂ
         Server\bo\JobEntry    JobEntry_ds.iÂ
         Server\bo\JobEntry    Sink.rÂ
         Server\bo\Quote    DefaultUpdateExt.rÂ
         Server\bo\Quote    Quote.iÂ
         Server\bo\Quote    Quote.rÂ
         Server\bo\Quote    Quote_ds.iÂ
         Server\bo\Quote    QuoteTrg.rÂ
         Server\bo\Quote    Sink.rÂ
         Server\bo\QuoteAsm    DefaultUpdateExt.rÂ
         Server\bo\QuoteAsm    QuoteAsm.iÂ
         Server\bo\QuoteAsm    QuoteAsm.rÂ
         Server\bo\QuoteAsm    QuoteAsm_ds.iÂ
         Server\bo\QuoteAsm    Sink.rÂ
         Server\db\trg\quotedtl    write.rÂ
         Server\lib    QuoteAsmDel.rÂ
         Server\pc    GenCode.rÂ
         Server\pc    GenConfigSequence.rÂ
         Server\pc    GenerateMethods.rÂ
         Server\pc    GetConfigurationSequence.rÂ
         Server\pc    pce10-pc.rÂ
         Server\pc    Pcp10-sf.rÂ
    ClientÂ
         Epicor.Mfg.AD.Configuration.dllÂ
         Epicor.Mfg.AD.Quote.dllÂ
         Epicor.Mfg.BO.Configuration.dllÂ
         Epicor.Mfg.BO.Quote.dllÂ
         Epicor.Mfg.BO.QuoteAsm.dllÂ
         Epicor.Mfg.IF.IConfiguration.dllÂ
         Epicor.Mfg.IF.IQuote.dllÂ
         Epicor.Mfg.IF.IQuoteAsm.dllÂ
         Epicor.Mfg.UI.ConfigurationEntry.dllÂ
Â
- Jeff Stimson
Â
Â
</div>
<div style="color:#fff;height:0;"></div></div>
Jeff Stimson I get the frustration, but at the same time we are paying for working software you’re right. It’s why we pay maintenance to get upgrades to the latest software as they fix things. From a business standpoint it doesn’t make sense for them to continually go back and keep reworking larger issues in old software. I certainly don’t want my maintenance dollars going towards fixing things in the past. I’m not saying that Epicor can’t be a pain about some of the issues especially when they have a patch for it and still give you the run around, but I get where they are coming from nothing in 9 at this point will close a business doors that I can think of.
Joshua Giese
CIO
Direct:     920.593.8299
IT Dept:   920.437.6400 Ext. 337
Site ID:    27450-E905702A-SQL64
Wisconsin Converting, Inc.
Sent: Friday, December 12, 2014 11:54 AM
Subject: Re: RE: [Vantage] Re: Epicor 9 702A Quoting module
     Server
          Server\pc     GenCode.r
     Client
- Jeff Stimson
Joshua Giese,
With all due respect, quotes for new revision parts that come out with pricing that is too low doesn't help a business keep its doors open. Enough of those will destroy a company's profitability.
I understand the point you are making on maintenance dollars, but we just went live with 9.05 this year. The migration was extremely painful, and we are very reluctant to go through another such move. Epicor says that the migration from 9 to 10 is extremely smooth, but I have learned from experience not to take anything said by Epicor as truth without significant outside confirmation.
I will send a separate email to the group asking about how the migration from 9 to 10 went.
Jeff Stimson
From: "Joshua Giese jgiese@... [vantage]" <vantage@yahoogroups.com>
Sent: Friday, December 12, 2014 9:59 AM
Subject: RE: RE: [Vantage] Re: Epicor 9 702A Quoting module
<div id="ygrps-yiv-283890932yiv5147918805ygrp-text">
  <div>
Joshua Giese
CIO
     Server
          Server\pc     GenCode.r
     Client
- Jeff Stimson
</div>
<div class="ygrps-yiv-283890932yiv5147918805yqt1350651540" id="ygrps-yiv-283890932yiv5147918805yqt39922"><div style="height:0px;color:rgb(255, 255, 255);"></div></div>
#ygrps-yiv-283890932 #ygrps-yiv-283890932yiv5147918805 #ygrps-yiv-283890932yiv5147918805 -- #ygrps-yiv-283890932yiv5147918805ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}
#ygrps-yiv-283890932 #ygrps-yiv-283890932yiv5147918805 #ygrps-yiv-283890932yiv5147918805ygrp-mkp hr {
#ygrps-yiv-283890932 #ygrps-yiv-283890932yiv5147918805 #ygrps-yiv-283890932yiv5147918805ygrp-mkp #ygrps-yiv-283890932yiv5147918805hd {
#ygrps-yiv-283890932 #ygrps-yiv-283890932yiv5147918805 #ygrps-yiv-283890932yiv5147918805ygrp-mkp #ygrps-yiv-283890932yiv5147918805ads {
#ygrps-yiv-283890932 #ygrps-yiv-283890932yiv5147918805 #ygrps-yiv-283890932yiv5147918805ygrp-mkp .ygrps-yiv-283890932yiv5147918805ad {
padding:0 0;}
#ygrps-yiv-283890932 #ygrps-yiv-283890932yiv5147918805 #ygrps-yiv-283890932yiv5147918805ygrp-mkp .ygrps-yiv-283890932yiv5147918805ad p {
margin:0;}
#ygrps-yiv-283890932 #ygrps-yiv-283890932yiv5147918805 #ygrps-yiv-283890932yiv5147918805ygrp-mkp .ygrps-yiv-283890932yiv5147918805ad a {
#ygrps-yiv-283890932 #ygrps-yiv-283890932yiv5147918805 #ygrps-yiv-283890932yiv5147918805ygrp-sponsor #ygrps-yiv-283890932yiv5147918805ygrp-lc {
font-family:Arial;}
#ygrps-yiv-283890932 #ygrps-yiv-283890932yiv5147918805 #ygrps-yiv-283890932yiv5147918805ygrp-sponsor #ygrps-yiv-283890932yiv5147918805ygrp-lc #ygrps-yiv-283890932yiv5147918805hd {
#ygrps-yiv-283890932 #ygrps-yiv-283890932yiv5147918805 #ygrps-yiv-283890932yiv5147918805ygrp-sponsor #ygrps-yiv-283890932yiv5147918805ygrp-lc .ygrps-yiv-283890932yiv5147918805ad {
#ygrps-yiv-283890932 #ygrps-yiv-283890932yiv5147918805 #ygrps-yiv-283890932yiv5147918805actions {
#ygrps-yiv-283890932 #ygrps-yiv-283890932yiv5147918805 #ygrps-yiv-283890932yiv5147918805activity {
#ygrps-yiv-283890932 #ygrps-yiv-283890932yiv5147918805 #ygrps-yiv-283890932yiv5147918805activity span {
font-weight:700;}
#ygrps-yiv-283890932 #ygrps-yiv-283890932yiv5147918805 #ygrps-yiv-283890932yiv5147918805activity span:first-child {
#ygrps-yiv-283890932 #ygrps-yiv-283890932yiv5147918805 #ygrps-yiv-283890932yiv5147918805activity span a {
#ygrps-yiv-283890932 #ygrps-yiv-283890932yiv5147918805 #ygrps-yiv-283890932yiv5147918805activity span span {
color:#ff7900;}
#ygrps-yiv-283890932 #ygrps-yiv-283890932yiv5147918805 #ygrps-yiv-283890932yiv5147918805activity span .ygrps-yiv-283890932yiv5147918805underline {
#ygrps-yiv-283890932 #ygrps-yiv-283890932yiv5147918805 .ygrps-yiv-283890932yiv5147918805attach {
#ygrps-yiv-283890932 #ygrps-yiv-283890932yiv5147918805 .ygrps-yiv-283890932yiv5147918805attach div a {
#ygrps-yiv-283890932 #ygrps-yiv-283890932yiv5147918805 .ygrps-yiv-283890932yiv5147918805attach img {
#ygrps-yiv-283890932 #ygrps-yiv-283890932yiv5147918805 .ygrps-yiv-283890932yiv5147918805attach label {
#ygrps-yiv-283890932 #ygrps-yiv-283890932yiv5147918805 .ygrps-yiv-283890932yiv5147918805attach label a {
#ygrps-yiv-283890932 #ygrps-yiv-283890932yiv5147918805 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-283890932 #ygrps-yiv-283890932yiv5147918805 .ygrps-yiv-283890932yiv5147918805bold {
#ygrps-yiv-283890932 #ygrps-yiv-283890932yiv5147918805 .ygrps-yiv-283890932yiv5147918805bold a {
#ygrps-yiv-283890932 #ygrps-yiv-283890932yiv5147918805 dd.ygrps-yiv-283890932yiv5147918805last p a {
#ygrps-yiv-283890932 #ygrps-yiv-283890932yiv5147918805 dd.ygrps-yiv-283890932yiv5147918805last p span {
#ygrps-yiv-283890932 #ygrps-yiv-283890932yiv5147918805 dd.ygrps-yiv-283890932yiv5147918805last p span.ygrps-yiv-283890932yiv5147918805yshortcuts {
margin-right:0;}
#ygrps-yiv-283890932 #ygrps-yiv-283890932yiv5147918805 div.ygrps-yiv-283890932yiv5147918805attach-table div div a {
#ygrps-yiv-283890932 #ygrps-yiv-283890932yiv5147918805 div.ygrps-yiv-283890932yiv5147918805attach-table {
width:400px;}
#ygrps-yiv-283890932 #ygrps-yiv-283890932yiv5147918805 div.ygrps-yiv-283890932yiv5147918805file-title a, #ygrps-yiv-283890932 #ygrps-yiv-283890932yiv5147918805 div.ygrps-yiv-283890932yiv5147918805file-title a:active, #ygrps-yiv-283890932 #ygrps-yiv-283890932yiv5147918805 div.ygrps-yiv-283890932yiv5147918805file-title a:hover, #ygrps-yiv-283890932 #ygrps-yiv-283890932yiv5147918805 div.ygrps-yiv-283890932yiv5147918805file-title a:visited {
#ygrps-yiv-283890932 #ygrps-yiv-283890932yiv5147918805 div.ygrps-yiv-283890932yiv5147918805photo-title a, #ygrps-yiv-283890932 #ygrps-yiv-283890932yiv5147918805 div.ygrps-yiv-283890932yiv5147918805photo-title a:active, #ygrps-yiv-283890932 #ygrps-yiv-283890932yiv5147918805 div.ygrps-yiv-283890932yiv5147918805photo-title a:hover, #ygrps-yiv-283890932 #ygrps-yiv-283890932yiv5147918805 div.ygrps-yiv-283890932yiv5147918805photo-title a:visited {
#ygrps-yiv-283890932 #ygrps-yiv-283890932yiv5147918805 div#ygrps-yiv-283890932yiv5147918805ygrp-mlmsg #ygrps-yiv-283890932yiv5147918805ygrp-msg p a span.ygrps-yiv-283890932yiv5147918805yshortcuts {
#ygrps-yiv-283890932 #ygrps-yiv-283890932yiv5147918805 .ygrps-yiv-283890932yiv5147918805green {
color:#628c2a;}
#ygrps-yiv-283890932 #ygrps-yiv-283890932yiv5147918805 .ygrps-yiv-283890932yiv5147918805MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-283890932 #ygrps-yiv-283890932yiv5147918805 o {
font-size:0;}
#ygrps-yiv-283890932 #ygrps-yiv-283890932yiv5147918805 #ygrps-yiv-283890932yiv5147918805photos div {
#ygrps-yiv-283890932 #ygrps-yiv-283890932yiv5147918805 #ygrps-yiv-283890932yiv5147918805photos div div {
#ygrps-yiv-283890932 #ygrps-yiv-283890932yiv5147918805 #ygrps-yiv-283890932yiv5147918805photos div label {
#ygrps-yiv-283890932 #ygrps-yiv-283890932yiv5147918805 #ygrps-yiv-283890932yiv5147918805reco-category {
font-size:77%;}
#ygrps-yiv-283890932 #ygrps-yiv-283890932yiv5147918805 #ygrps-yiv-283890932yiv5147918805reco-desc {
font-size:77%;}
#ygrps-yiv-283890932 #ygrps-yiv-283890932yiv5147918805 .ygrps-yiv-283890932yiv5147918805replbq {
margin:4px;}
#ygrps-yiv-283890932 #ygrps-yiv-283890932yiv5147918805 #ygrps-yiv-283890932yiv5147918805ygrp-actbar div a:first-child {
#ygrps-yiv-283890932 #ygrps-yiv-283890932yiv5147918805 #ygrps-yiv-283890932yiv5147918805ygrp-mlmsg {
#ygrps-yiv-283890932 #ygrps-yiv-283890932yiv5147918805 #ygrps-yiv-283890932yiv5147918805ygrp-mlmsg table {
#ygrps-yiv-283890932 #ygrps-yiv-283890932yiv5147918805 #ygrps-yiv-283890932yiv5147918805ygrp-mlmsg select, #ygrps-yiv-283890932 #ygrps-yiv-283890932yiv5147918805 input, #ygrps-yiv-283890932 #ygrps-yiv-283890932yiv5147918805 textarea {
#ygrps-yiv-283890932 #ygrps-yiv-283890932yiv5147918805 #ygrps-yiv-283890932yiv5147918805ygrp-mlmsg pre, #ygrps-yiv-283890932 #ygrps-yiv-283890932yiv5147918805 code {
#ygrps-yiv-283890932 #ygrps-yiv-283890932yiv5147918805 #ygrps-yiv-283890932yiv5147918805ygrp-mlmsg * {
#ygrps-yiv-283890932 #ygrps-yiv-283890932yiv5147918805 #ygrps-yiv-283890932yiv5147918805ygrp-mlmsg #ygrps-yiv-283890932yiv5147918805logo {
#ygrps-yiv-283890932 #ygrps-yiv-283890932yiv5147918805 #ygrps-yiv-283890932yiv5147918805ygrp-msg p a {
#ygrps-yiv-283890932 #ygrps-yiv-283890932yiv5147918805 #ygrps-yiv-283890932yiv5147918805ygrp-msg p#ygrps-yiv-283890932yiv5147918805attach-count span {
#ygrps-yiv-283890932 #ygrps-yiv-283890932yiv5147918805 #ygrps-yiv-283890932yiv5147918805ygrp-reco #ygrps-yiv-283890932yiv5147918805reco-head {
#ygrps-yiv-283890932 #ygrps-yiv-283890932yiv5147918805 #ygrps-yiv-283890932yiv5147918805ygrp-reco {
#ygrps-yiv-283890932 #ygrps-yiv-283890932yiv5147918805 #ygrps-yiv-283890932yiv5147918805ygrp-sponsor #ygrps-yiv-283890932yiv5147918805ov li a {
#ygrps-yiv-283890932 #ygrps-yiv-283890932yiv5147918805 #ygrps-yiv-283890932yiv5147918805ygrp-sponsor #ygrps-yiv-283890932yiv5147918805ov li {
#ygrps-yiv-283890932 #ygrps-yiv-283890932yiv5147918805 #ygrps-yiv-283890932yiv5147918805ygrp-sponsor #ygrps-yiv-283890932yiv5147918805ov ul {
#ygrps-yiv-283890932 #ygrps-yiv-283890932yiv5147918805 #ygrps-yiv-283890932yiv5147918805ygrp-text {
#ygrps-yiv-283890932 #ygrps-yiv-283890932yiv5147918805 #ygrps-yiv-283890932yiv5147918805ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-283890932 #ygrps-yiv-283890932yiv5147918805 #ygrps-yiv-283890932yiv5147918805ygrp-text tt {
font-size:120%;}
#ygrps-yiv-283890932 #ygrps-yiv-283890932yiv5147918805 #ygrps-yiv-283890932yiv5147918805ygrp-vital ul li:last-child {
    Greetings,
    Thanks in advance.
    - Jeff Stimson
Big Hurdles when jumping full versions I think.
We went from Vantage 6 to 9.04 and it was a pain.
9.04 to 9.05, was okay…then to 9.05.607A
We were on 9.05.607A for about 3 years.
607A to 702A conversion was not a huge issue, just all these little new things that are broken.
I do wish they have a WHAT IS WRONG NOW list.
Miguel A. Santillan
Sent: Friday, December 12, 2014 10:30 AM
Joshua Giese,
Jeff Stimson
Joshua Giese
CIO
     Server
          Server\pc     GenCode.r
     Client
- Jeff Stimson
If you have a vanilla epicor install (minimaly customized)Â
Jose C Gomez
Software Engineer
Â
<div>
  <p></p><div style="color:#000;background-color:#fff;font-family:HelveticaNeue-Light, Helvetica Neue Light, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif;font-size:14px;"><div><span></span></div><div style="font-family:HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif;font-size:16px;" dir="ltr">    Greetings,</div><div style="font-family:HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif;font-size:16px;" dir="ltr"><br></div><div style="font-family:HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif;font-size:16px;" dir="ltr">         I am coming to the conclusion that the only way we will get the software to work correctly in the quote module is to migrate from 9.05 to version 10. Epicor tells me this is a serious upgrade in the software, as well as a fairly painless migration. However, based on my experience with them, Epicor is going to tell us whatever is best for Epicor, not what is best for us.</div><div style="font-family:HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif;font-size:16px;" dir="ltr">        So I pose a few questions to anyone in the group that has moved from 9 to 10</div><div style="font-family:HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif;font-size:16px;" dir="ltr"><br></div><div style="font-family:HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif;font-size:16px;" dir="ltr"><br></div><div style="font-family:HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif;font-size:16px;" dir="ltr">        1) How big of an improvement is the software upgrade?</div><div style="font-family:HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif;font-size:16px;" dir="ltr">        2) How painful was the migration?</div><div style="font-family:HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif;font-size:16px;" dir="ltr">        3) How large of a database was involved in the migration? </div><div style="font-family:HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif;font-size:16px;" dir="ltr"><br></div><div style="font-family:HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif;font-size:16px;" dir="ltr">    Thanks in advance.</div><div style="font-family:HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif;font-size:16px;" dir="ltr"><br></div><div style="font-family:HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif;font-size:16px;" dir="ltr">    - Jeff Stimson</div><div style="font-family:HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif;font-size:16px;" dir="ltr">MASS Precision, Inc. <br></div><div style="font-family:HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif;font-size:16px;"> </div><div style="font-family:HelveticaNeue-Light, Helvetica Neue Light, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif;font-size:14px;"> </div>  </div><p></p>
</div>
<div style="color:#fff;min-height:0;"></div>
I have to get my 2 cents worth in.
The problem with the argument that Epicor needs to concentrate fixes on the latest version is that just about ever thing broken in our version 8.03 was reported to them long before version 9 was even off the drawing board.  I know the sales people love seeing new and flashy features because that is what sells, but having a bad reputation for buggy software and frustrating service and support is really holding them back, whether they realize it or not.
Steven G.
On Friday, December 12, 2014 1:38 PM, "Miguel Santillan msantillan@... [vantage]" <vantage@yahoogroups.com> wrote:
<div id="ygrps-yiv-355792828yiv5055157329ygrp-text">
  <div>
Miguel A. Santillan
Joshua Giese,
Jeff Stimson
Joshua Giese
CIO
     Server
          Server\pc     GenCode.r
     Client
- Jeff Stimson
</div>
<div class="ygrps-yiv-355792828yiv5055157329yqt7602635989" id="ygrps-yiv-355792828yiv5055157329yqt11127"><div style="color:#fff;height:0;"></div></div>
#ygrps-yiv-355792828 #ygrps-yiv-355792828yiv5055157329 #ygrps-yiv-355792828yiv5055157329 -- #ygrps-yiv-355792828yiv5055157329ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}
#ygrps-yiv-355792828 #ygrps-yiv-355792828yiv5055157329 #ygrps-yiv-355792828yiv5055157329ygrp-mkp hr {
#ygrps-yiv-355792828 #ygrps-yiv-355792828yiv5055157329 #ygrps-yiv-355792828yiv5055157329ygrp-mkp #ygrps-yiv-355792828yiv5055157329hd {
#ygrps-yiv-355792828 #ygrps-yiv-355792828yiv5055157329 #ygrps-yiv-355792828yiv5055157329ygrp-mkp #ygrps-yiv-355792828yiv5055157329ads {
#ygrps-yiv-355792828 #ygrps-yiv-355792828yiv5055157329 #ygrps-yiv-355792828yiv5055157329ygrp-mkp .ygrps-yiv-355792828yiv5055157329ad {
padding:0 0;}
#ygrps-yiv-355792828 #ygrps-yiv-355792828yiv5055157329 #ygrps-yiv-355792828yiv5055157329ygrp-mkp .ygrps-yiv-355792828yiv5055157329ad p {
margin:0;}
#ygrps-yiv-355792828 #ygrps-yiv-355792828yiv5055157329 #ygrps-yiv-355792828yiv5055157329ygrp-mkp .ygrps-yiv-355792828yiv5055157329ad a {
#ygrps-yiv-355792828 #ygrps-yiv-355792828yiv5055157329 #ygrps-yiv-355792828yiv5055157329ygrp-sponsor #ygrps-yiv-355792828yiv5055157329ygrp-lc {
font-family:Arial;}
#ygrps-yiv-355792828 #ygrps-yiv-355792828yiv5055157329 #ygrps-yiv-355792828yiv5055157329ygrp-sponsor #ygrps-yiv-355792828yiv5055157329ygrp-lc #ygrps-yiv-355792828yiv5055157329hd {
#ygrps-yiv-355792828 #ygrps-yiv-355792828yiv5055157329 #ygrps-yiv-355792828yiv5055157329ygrp-sponsor #ygrps-yiv-355792828yiv5055157329ygrp-lc .ygrps-yiv-355792828yiv5055157329ad {
#ygrps-yiv-355792828 #ygrps-yiv-355792828yiv5055157329 #ygrps-yiv-355792828yiv5055157329actions {
#ygrps-yiv-355792828 #ygrps-yiv-355792828yiv5055157329 #ygrps-yiv-355792828yiv5055157329activity {
#ygrps-yiv-355792828 #ygrps-yiv-355792828yiv5055157329 #ygrps-yiv-355792828yiv5055157329activity span {
font-weight:700;}
#ygrps-yiv-355792828 #ygrps-yiv-355792828yiv5055157329 #ygrps-yiv-355792828yiv5055157329activity span:first-child {
#ygrps-yiv-355792828 #ygrps-yiv-355792828yiv5055157329 #ygrps-yiv-355792828yiv5055157329activity span a {
#ygrps-yiv-355792828 #ygrps-yiv-355792828yiv5055157329 #ygrps-yiv-355792828yiv5055157329activity span span {
color:#ff7900;}
#ygrps-yiv-355792828 #ygrps-yiv-355792828yiv5055157329 #ygrps-yiv-355792828yiv5055157329activity span .ygrps-yiv-355792828yiv5055157329underline {
#ygrps-yiv-355792828 #ygrps-yiv-355792828yiv5055157329 .ygrps-yiv-355792828yiv5055157329attach {
#ygrps-yiv-355792828 #ygrps-yiv-355792828yiv5055157329 .ygrps-yiv-355792828yiv5055157329attach div a {
#ygrps-yiv-355792828 #ygrps-yiv-355792828yiv5055157329 .ygrps-yiv-355792828yiv5055157329attach img {
#ygrps-yiv-355792828 #ygrps-yiv-355792828yiv5055157329 .ygrps-yiv-355792828yiv5055157329attach label {
#ygrps-yiv-355792828 #ygrps-yiv-355792828yiv5055157329 .ygrps-yiv-355792828yiv5055157329attach label a {
#ygrps-yiv-355792828 #ygrps-yiv-355792828yiv5055157329 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-355792828 #ygrps-yiv-355792828yiv5055157329 .ygrps-yiv-355792828yiv5055157329bold {
#ygrps-yiv-355792828 #ygrps-yiv-355792828yiv5055157329 .ygrps-yiv-355792828yiv5055157329bold a {
#ygrps-yiv-355792828 #ygrps-yiv-355792828yiv5055157329 dd.ygrps-yiv-355792828yiv5055157329last p a {
#ygrps-yiv-355792828 #ygrps-yiv-355792828yiv5055157329 dd.ygrps-yiv-355792828yiv5055157329last p span {
#ygrps-yiv-355792828 #ygrps-yiv-355792828yiv5055157329 dd.ygrps-yiv-355792828yiv5055157329last p span.ygrps-yiv-355792828yiv5055157329yshortcuts {
margin-right:0;}
#ygrps-yiv-355792828 #ygrps-yiv-355792828yiv5055157329 div.ygrps-yiv-355792828yiv5055157329attach-table div div a {
#ygrps-yiv-355792828 #ygrps-yiv-355792828yiv5055157329 div.ygrps-yiv-355792828yiv5055157329attach-table {
width:400px;}
#ygrps-yiv-355792828 #ygrps-yiv-355792828yiv5055157329 div.ygrps-yiv-355792828yiv5055157329file-title a, #ygrps-yiv-355792828 #ygrps-yiv-355792828yiv5055157329 div.ygrps-yiv-355792828yiv5055157329file-title a:active, #ygrps-yiv-355792828 #ygrps-yiv-355792828yiv5055157329 div.ygrps-yiv-355792828yiv5055157329file-title a:hover, #ygrps-yiv-355792828 #ygrps-yiv-355792828yiv5055157329 div.ygrps-yiv-355792828yiv5055157329file-title a:visited {
#ygrps-yiv-355792828 #ygrps-yiv-355792828yiv5055157329 div.ygrps-yiv-355792828yiv5055157329photo-title a, #ygrps-yiv-355792828 #ygrps-yiv-355792828yiv5055157329 div.ygrps-yiv-355792828yiv5055157329photo-title a:active, #ygrps-yiv-355792828 #ygrps-yiv-355792828yiv5055157329 div.ygrps-yiv-355792828yiv5055157329photo-title a:hover, #ygrps-yiv-355792828 #ygrps-yiv-355792828yiv5055157329 div.ygrps-yiv-355792828yiv5055157329photo-title a:visited {
#ygrps-yiv-355792828 #ygrps-yiv-355792828yiv5055157329 div#ygrps-yiv-355792828yiv5055157329ygrp-mlmsg #ygrps-yiv-355792828yiv5055157329ygrp-msg p a span.ygrps-yiv-355792828yiv5055157329yshortcuts {
#ygrps-yiv-355792828 #ygrps-yiv-355792828yiv5055157329 .ygrps-yiv-355792828yiv5055157329green {
color:#628c2a;}
#ygrps-yiv-355792828 #ygrps-yiv-355792828yiv5055157329 .ygrps-yiv-355792828yiv5055157329MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-355792828 #ygrps-yiv-355792828yiv5055157329 o {
font-size:0;}
#ygrps-yiv-355792828 #ygrps-yiv-355792828yiv5055157329 #ygrps-yiv-355792828yiv5055157329photos div {
#ygrps-yiv-355792828 #ygrps-yiv-355792828yiv5055157329 #ygrps-yiv-355792828yiv5055157329photos div div {
#ygrps-yiv-355792828 #ygrps-yiv-355792828yiv5055157329 #ygrps-yiv-355792828yiv5055157329photos div label {
#ygrps-yiv-355792828 #ygrps-yiv-355792828yiv5055157329 #ygrps-yiv-355792828yiv5055157329reco-category {
font-size:77%;}
#ygrps-yiv-355792828 #ygrps-yiv-355792828yiv5055157329 #ygrps-yiv-355792828yiv5055157329reco-desc {
font-size:77%;}
#ygrps-yiv-355792828 #ygrps-yiv-355792828yiv5055157329 .ygrps-yiv-355792828yiv5055157329replbq {
margin:4px;}
#ygrps-yiv-355792828 #ygrps-yiv-355792828yiv5055157329 #ygrps-yiv-355792828yiv5055157329ygrp-actbar div a:first-child {
#ygrps-yiv-355792828 #ygrps-yiv-355792828yiv5055157329 #ygrps-yiv-355792828yiv5055157329ygrp-mlmsg {
#ygrps-yiv-355792828 #ygrps-yiv-355792828yiv5055157329 #ygrps-yiv-355792828yiv5055157329ygrp-mlmsg table {
#ygrps-yiv-355792828 #ygrps-yiv-355792828yiv5055157329 #ygrps-yiv-355792828yiv5055157329ygrp-mlmsg select, #ygrps-yiv-355792828 #ygrps-yiv-355792828yiv5055157329 input, #ygrps-yiv-355792828 #ygrps-yiv-355792828yiv5055157329 textarea {
#ygrps-yiv-355792828 #ygrps-yiv-355792828yiv5055157329 #ygrps-yiv-355792828yiv5055157329ygrp-mlmsg pre, #ygrps-yiv-355792828 #ygrps-yiv-355792828yiv5055157329 code {
#ygrps-yiv-355792828 #ygrps-yiv-355792828yiv5055157329 #ygrps-yiv-355792828yiv5055157329ygrp-mlmsg * {
#ygrps-yiv-355792828 #ygrps-yiv-355792828yiv5055157329 #ygrps-yiv-355792828yiv5055157329ygrp-mlmsg #ygrps-yiv-355792828yiv5055157329logo {
#ygrps-yiv-355792828 #ygrps-yiv-355792828yiv5055157329 #ygrps-yiv-355792828yiv5055157329ygrp-msg p a {
#ygrps-yiv-355792828 #ygrps-yiv-355792828yiv5055157329 #ygrps-yiv-355792828yiv5055157329ygrp-msg p#ygrps-yiv-355792828yiv5055157329attach-count span {
#ygrps-yiv-355792828 #ygrps-yiv-355792828yiv5055157329 #ygrps-yiv-355792828yiv5055157329ygrp-reco #ygrps-yiv-355792828yiv5055157329reco-head {
#ygrps-yiv-355792828 #ygrps-yiv-355792828yiv5055157329 #ygrps-yiv-355792828yiv5055157329ygrp-reco {
#ygrps-yiv-355792828 #ygrps-yiv-355792828yiv5055157329 #ygrps-yiv-355792828yiv5055157329ygrp-sponsor #ygrps-yiv-355792828yiv5055157329ov li a {
#ygrps-yiv-355792828 #ygrps-yiv-355792828yiv5055157329 #ygrps-yiv-355792828yiv5055157329ygrp-sponsor #ygrps-yiv-355792828yiv5055157329ov li {
#ygrps-yiv-355792828 #ygrps-yiv-355792828yiv5055157329 #ygrps-yiv-355792828yiv5055157329ygrp-sponsor #ygrps-yiv-355792828yiv5055157329ov ul {
#ygrps-yiv-355792828 #ygrps-yiv-355792828yiv5055157329 #ygrps-yiv-355792828yiv5055157329ygrp-text {
#ygrps-yiv-355792828 #ygrps-yiv-355792828yiv5055157329 #ygrps-yiv-355792828yiv5055157329ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-355792828 #ygrps-yiv-355792828yiv5055157329 #ygrps-yiv-355792828yiv5055157329ygrp-text tt {
font-size:120%;}
#ygrps-yiv-355792828 #ygrps-yiv-355792828yiv5055157329 #ygrps-yiv-355792828yiv5055157329ygrp-vital ul li:last-child {
