Glad to help. We (the users) have to stick together as Epicor is likely not going to be there for us in a sufficiently timely manner (and its not realistic to think they CAN be with the growth of the user base).
Rob Brown
Karl Dash <dashkarl@...> wrote:
Robert,
Yeah, you hit it on the head. I took your advice about inserting the JobProd table as an intermediary (thanks also to Dale Schuerman & Stephen Edginton). Small XML, quick response, looks good.
Thanks Again
-Karl-
Robert Brown <robertb_versa@...> wrote:
Isn't the JobProd table available in Crystal to create appropriate Joins to link JobHead to OrderHed?
You can then also Join in any subtables you further need if the data you wish to print on the traveler exists at the Order Line or Order Release level.
All that text manipulation code (stripping leading "0"s from the JobNum) sets you up for problems if your numbering schema (Job or Order) changes in the future (as a result of Vantage schema changes that give you new 'opportunities - or as a result of changing business needs).
Use the relational db to handle such things as it will be more likely to survive changes.
Rob Brown
We are on 803.400 and I want to modify the Job Traveler to pick up the customer PO number from OrderHed. We are also a make to order shop, so the customer order number is the first segment of the job number. I created a formula which strips the order number from the JobAsmbl table and then uses that to link to a subreport to the OrderHed to get the PO number. So far so good. But when I added the Orderhed to the report Data Definition the calculated field is not one of the links I can use to associate the OrderHed and JobAsmbl. The result is that the XML is huge and run time is three minutes to assemble a lot of unnecessary stuff. Can anyone suggest a better way to get to the same result?
Thanks, Karl
Never miss a thing. Make Yahoo your homepage.
Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now.
Rob Brown
Robert,
Thanks Again
-Karl-
Rob Brown
Thanks, Karl
