10.0.700.2
EVERY Monday Morning I get the following 2 errors when trying to save a configuration (Quote): I try all of the following and sometimes it works sometimes it doesn’t. Every time I find what I think is the answer, that fails the next Monday.
Once I get an actual save, l have no issues again until the next Monday. Another odd thing is that if I change an existing configuration, it will save, but a new configuration done right after, will not save.
1.
Deleting generated files
2.
Regenerating the Configurators
3.
Restarting the task Manager
4.
Changed the timeout settings
5.
Manually Quotes will save
This takes me all day to get back online, and I have no idea what actually makes it start working. I swear it has “magically” started saving w/out me doing anything! One Monday neither LIVE or TEST was saving and then they were this happened
simultaneously. I am out of ideas. The Only consistent factors are we reboot on Sunday and the Configurator doesn’t save on Monday.
1st:
Server Side Exception
An error occurred while updating the entries. See the inner exception for details.
Error Detail
Description: An error occurred while
Inner Exception: Timeout expired. The
timeout period elapsed prior to completion of the operation or the server is not responding.
The statement has been terminated.
The wait operation timed out
Program: System.Data.Entity.dll
Method: Update
Original Exception Type: UpdateException
Framework Method: SaveChanges
2nd:
Configuration values were not found, no PcValueGrp record was found for Configuration '_QuoteBox' on entity '[Company = 10, QuoteNum
= 12245, QuoteLine = 2]' from '[Company = 10, PartNum = Quotable Part, RevisionNum = BOX, AltMethod = ]'.
Error Detail
Description: Configuration values were
not found, no PcValueGrp record was found for Configuration '_QuoteBox' on entity '[Company = 10, QuoteNum = 12245, QuoteLine = 2]' from '[Company = 10, PartNum = Quotable Part, RevisionNum = BOX, AltMethod = ]'.
Program: Erp.Internal.PC.Configuration.dll
Method: LoadConfiguration
Brenda
