I had this problem and finally got it resolved. There are 5 files that you will you need.
Copy these files into the [Deployment Folder]\Client directory:
Epicor.Mfg.BO.Company.dll
Epicor.Mfg.IF.ICompany.dll
Copy these files into the [Deployment Folder]\Server\bo directory:
Company.r
Company.i
Company_ds.i
After you do this then copy the client folder from the server to the desktop client folder on the workstation. This will fix that desktop only. If you want it to work on every desktop then you will need to copy that folder to each workstation. Support said the next patch will fix this issue but for now that is the fix I got and it did work.
Ryan Larkin
Solid Comfort, Inc.
3931 37th Ave S.
Fargo, ND 58104
www.solidcomfort.com
Tel. 701-282-4900
Cell 701-261-7700
Fax 701-282-8925
Sent: Friday, December 22, 2006 9:07 AM
Subject: RE: [Vantage] V8.03 - Can't make changes to the Company Config!
There are 5 files support will need to send you depending on the version
8.03 you are running.
These 5 files fixed the system so we could do Company maintenance on the
server but not on the client computers.
Support is still looking on the client side problem. Having the
server work was a good enough us to continue.
Dale Schuerman
From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com [mailto: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com] On Behalf
Of Joe Rojas
Sent: Friday, December 22, 2006 8:55 AM
To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
Subject: [Vantage] V8.03 - Can't make changes to the Company Config!
Hello,
We were talking a last look at the Company Configuration in preparation
of our Go-Live on January 2nd.
We wanted to make changes to the start numbers for Sales Orders and Pack
Slips but when I go to save the changes I get the error message below.
It looks like any change to the Company Config generates this same error
message.
Of course tech support is closed today so does anyone have any ideas?
Error Detail
Input result set error: Progress.Open4GL.DynamicAPI.ClientException:
Illegal conversion of input column System.String to ROWID. Input result
set mismatches the schema in the proxy. (7187) There might be a
mismatch between an input result set and the schema in the proxy. (7228)
(7176) There might be a mismatch between an input result set and the
schema in the proxy. (7228) (7176)
Stack Trace
at Progress.Open4GL.DynamicAPI.Session.runProcedure(String requestID,
String procedureName, ParameterSet parms, Boolean persistent, Boolean
internal_Renamed, Int64 procId, MetaSchema localSchema)
String procedureName, ParameterSet parms, Object procId, MetaSchema
localSchema)
at Progress.Open4GL.DynamicAPI.PersistentProc.runProcedure(String
procedureName, ParameterSet parms, MetaSchema schema)
at Epicor.Mfg.Proxy.CompanyImpl.Update(CompanyDataSet ds)
at Epicor.Mfg.BO.Company.Epicor.Mfg.IF.ICompany.Update(CompanyDataSet
at Epicor.Mfg.UI.Adapters.CompanyAdapter.Update()
at Epicor.Mfg.UI.App.CompanyEntry.Transaction.Update(Boolean
updateConfirmation)
Joe Rojas
IT Manager
TNCO, Inc.
781-447-6661 x7506
jrojas@tnco- <mailto:jrojas%40tnco-inc.com> inc.com <mailto:jrojas%40tnco-inc.com>
Attention:
This email message is privileged and confidential. If you are not the
intended recipient please delete the message and notify the sender.
Any views or opinions presented are solely those of the author.
This email message has been scanned for Viruses and Content and cleared
by MailMarshal SMTP
For more information go to http://www.ramsys <http://www.ramsys.com> com
Company.r
Company.i
Company_ds.i
Ryan Larkin
Solid Comfort, Inc.
3931 37th Ave S.
Fargo, ND 58104
Tel. 701-282-4900
Cell 701-261-7700
Fax 701-282-8925
Dale Schuerman
Of Joe Rojas
Hello,
message.
Error Detail
Stack Trace
localSchema)
updateConfirmation)
Joe Rojas
IT Manager
TNCO, Inc.
781-447-6661 x7506
Attention:
by MailMarshal SMTP
