One reason to keep the cost on the job (not move to DMR) would be to monitor the real cost of performing the job.  If you measure your SGM from job to sales order you might want to see a lower SGM due to quaility issues on the specific job. By moving cost from MFG-DMR then to fail you are removing the cost from the offending job.  This would show a higher SGM on the offending job as well as a higher, untrue sales gross margin.Â
Another case would be for companies that have not matured to the point of accurate / realtime labor reporting (do we ever? - different discussion). If timing of transactions or quantity reporting are issues a company has then the potential for pulling the wrong cost into DMR is high.Â
Both of these examples are primarily issues in an average / actual cost environment. I could see the potential for these being a problem in a standard cost environment, but with less overall impact. In that case move cost to DMR might be a good way to capture cost of quality.
Bruce B.
Â
Does anyone have a legit reason why NOT to use the move cost to DMR from
Non-Conformance?
Toby Boogerd
Information Systems
712.324.4854 | tboogerd@... <mailto:tboogerd@...>
NOTICE: This email may contain confidential and proprietary information
of Rosenboom Machine & Tool, Inc. By opening any enclosed files, the
recipient agrees not to use, reproduce, disclose, or manufacture its
contents, in whole or in part, without prior written consent of
Please consider the environment before printing this email.
Bruce B.
Â
Non-Conformance?
Toby Boogerd
Information Systems
