MRP Defualt checked
Other than a BPM is there a way to turn off Process MRP when a new part is created?
I just want to make sure there is not another setting in Epicor.
Other than manually unchecking “Process MRP” on the parts plant/planning
tab there is no default in company configuration to determine whether a
part auto defaults to process mrp. It will always default unless you
uncheck it or use a BPM with some logic behind it
Mark Wagner
Sr. Partner
Capstone Alliance Partners 888.597.2227 Ext. 71
<888.597.2227%20Ext.%20714>2 | 904.412.6847 mwagner@capstoneap.com (cell)
| www.capstoneap.com
Thanks Mark. That is what I thought just wanted to check.
Kim
