I have an issue on Microsoft Surface Pro 3’s where when the user tries to open certain screens (Preferences is an example), an error occurs:
Application Error
Exception caught in: PresentationCore
Error Detail
Message: ‘System.Windows.Documents.Hyperlink’ is not a Visual or Visual3D.
Program: PresentationCore.dll
Method: AsVisual
Client Stack Trace
at MS.Internal.Media.VisualTreeUtils.AsVisual(DependencyObject element, Visual& visual, Visual3D& visual3D)
at MS.Internal.Media.VisualTreeUtils.AsNonNullVisual(DependencyObject element, Visual& visual, Visual3D& visual3D)
at System.Windows.Media.VisualTreeHelper.GetParent(DependencyObject reference)
at IceShell.UIHelper.FindVisualParent[T](DependencyObject child, Boolean checkCurrent)
at IceShell.SettingsApp.Tap(Object sender, InputEventArgs e)
at IceShell.BaseApp.BaseApp_Tap(Object sender, InputEventArgs e)
at IceShell.Apps.Controls.Touch.GestureTrackerManager.GestureTracker_GestureFinished(TouchGesture gesture, StylusEventArgs args)
at IceShell.Apps.Controls.Touch.GestureTracker.ProcessUp(Point location, StylusEventArgs args)
at IceShell.Apps.Controls.Touch.GestureTrackerManager.Process_TouchUp(Object sender, StylusEventArgs args)
at System.Windows.Input.StylusEventArgs.InvokeEventHandler(Delegate genericHandler, Object genericTarget)
at System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target)
at System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs)
at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised)
at System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args)
at System.Windows.ContentElement.RaiseTrustedEvent(RoutedEventArgs args)
at System.Windows.Input.InputManager.ProcessStagingArea()
at System.Windows.Input.InputManager.ProcessInput(InputEventArgs input)
at System.Windows.Input.StylusLogic.InputManagerProcessInput(Object oInput)
at System.Windows.Input.StylusLogic.PreProcessInput(Object sender, PreProcessInputEventArgs e)
at System.Windows.Input.InputProviderSite.ReportInput(InputReport inputReport)
at System.Windows.Interop.HwndMouseInputProvider.ReportInput(IntPtr hwnd, InputMode mode, Int32 timestamp, RawMouseActions actions, Int32 x, Int32 y, Int32 wheel)
at System.Windows.Interop.HwndMouseInputProvider.FilterMessage(IntPtr hwnd, WindowMessage msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at System.Windows.Interop.HwndSource.InputFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
at MS.Internal.Threading.ExceptionFilterHelper.TryCatchWhen(Object source, Delegate method, Object args, Int32 numArgs, Delegate catchHandler)
at System.Windows.Threading.Dispatcher.LegacyInvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Int32 numArgs)
at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam)
at System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG& msg)
at System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(IntPtr dwComponentID, Int32 reason, Int32 pvLoopData)
at System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context)
at System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context)
at Ice.Lib.UI.ApplicationWatcher.StartApplication(ApplicationContext context)
at Ice.Lib.UI.App.IceShellLaunch.<>c__DisplayClass2.b__1()
at Ice.Lib.UI.App.IceShellLaunch.ShowMenuForm()
at Ice.Lib.UI.App.LaunchBase.ShowDialog(String[] args)
